Re: Testing MrMC 3.7.0
Post by cosmoxl »
Montoya wrote: 20 Jun 2018, 17:20
cosmoxl wrote: 20 Jun 2018, 14:52 the problem I brought up yesterday of live time shift not working after watching live tv for some time does affect tvOS as well as Shield.
Here's a log.
https://paste2.org/k7gcZ3C9
Have you tried the TVMosaic PVR in MrMC with your DVBLink settings as backcheck ?
It seems to me that TVMosaic PVR is more stable concerning time shift in MrMC and noticed too that my DVBLink PVR is more sensitive to errors when using time shift. But this problem exist already for quite some time in MrMC, but couldn’t reproduce what triggers it. Most of the time it works and out of the blue it doesn’t work, resulting in minutes lost of the broadcast, when you are watching delayed and jumping FW/BW with the time shift, because it crashes the play of the live/time shifted channel.
@Devs
Does the setting of how many seconds you can jump FW/BW have something to do with it or does the PVR compensate and goes to nearest point in time of the requested time in live tv buffer of DVBLink ? Also when in time shift and jumping FW/BW, the OSD is not consistent concerning the times shown on left side of OSD.
@cosmoxl
Does restart of DVBlink server change the behavior of the problems with time shift in MrMC ?
I did purchase a tv mosaic plus upgrade last week but I haven't installed it yet. So, it's on my list to try.
I haven't tried restarting the server. I don't recall having this problem before.
Montoya
Post by Montoya »
cosmoxl wrote: 20 Jun 2018, 18:08 I did purchase a tv mosaic plus upgrade last week but I haven't installed it yet. So, it's on my list to try.
What I meant was, is to test the MrMC TVMosaic PVR (instead of the MrMC DVBLink PVR)as front end for your DVBLink server backend in MrMC, to see if that changes anything for your problems with time shift.
(180621.110 @20180620-b050db4)
FIX: WindowMedia Sources parent_redirect
FIX: GUIWindowScreensaverDim only if g_application.GetDimScreenSaverLevel() has changed
FIX: do not open CGUIDialogMuteBug on tvOS, mute is not an option
CHG: sync skins
CHG: [bluray] hide bluray menu until we get a java vm working with droid/darwin
pecinko
Post by pecinko »
Ariana:
- recordings should have OSD buttons in Ariana
- Plex playlists should be working
- Runtime and ratings added to VideoInfo
- Actors bar has been re-designed
- Home menu buttons should not be "flat"
- EPG guide now airing marker (glass overlay) should be aligned
- Progress bar should be aligned when scrubbing
- Channel thumbs in icon view should be properly aligned
- Profile button should be hidden if only one mrmc user is available
Itzme1234
Post by Itzme1234 »
Testing Ariana and Plex extension, in Plex on occasion the Continue Watching video screen shot becomes the entire Plex background. I’m talking about the same screenshot the briefly appears when you hit play.
Mark as played, exit, re-enter and the correct home screen background comes back fine.
Also, I can’t figure out how to remove a video from the playlist, or remove a playlist. I see three dots by each playlist item but can’t seem to highlight them. I can only play the videos.
Itzme1234
Post by Itzme1234 »
In Ariana the playlist view shows 0 B next to each title in the playlist.
ersan191
Post by ersan191 »
Itzme1234 wrote: 21 Jun 2018, 12:23 Testing Ariana and Plex extension, in Plex on occasion the Continue Watching video screen shot becomes the entire Plex background. I’m talking about the same screenshot the briefly appears when you hit play.
Same problem here - I posted about it twice in this same thread and attached photos as well.
It doesn’t just go away by marking things as played though, that probably is just swapping out one item for another one that is already cached properly from before switching to TF
Post by cosmoxl »
pecinko wrote: 21 Jun 2018, 11:21 Ariana:
Several fixes confirmed. Thanks.
My only question is re the ratings for videos in Ariana. If I'm in a movie library, in list view, I see the rating for each movie bottom left. But, there's no rating for tv shows in the same place, though other info is there. Opacity will show a rating for the tv show as a whole, and for each individual episode.
_roidy
Post by _roidy »
[BUG] Unable to select The Movie Database scraper for a newly added TV Show source [BUG]
Affected version:- 180701.2332 / 180624.214 / 180622.1315 / 180621.110 / 180618.1839 / 180617.6 / 180613.305
Last working version:- 180611.200
Steps to reproduce:- Goto Videos, Add Videos and add a new video source. In the Set Content dialog change the type to (TV Shows) and try to select The Movie Database as the scraper, selecting The Movie Database scraper sends you to an Extensions Unknown window. See images.
Post by cosmoxl »
I got tv-mosaic server running and I think the problems I'm seeing with live tv timeshift with dvblink not working after watching for some time are gone with tv-mosaic. So, that's good.
