Re: Testing MrMC 3.7.0
Post by cosmoxl »
amet wrote: 07 May 2018, 02:50 I’ll check issues with tvdb, others reported them as well... not sure what’s happening
Speed when you copy the files into shared folder or copy via file manager? Either way, we have no control over transfer speed but I would assume latter is just a move.
Speed when adding to shared folder. The file manager manipulation is just a move.
Thanks for looking into theTVDB.
Post by cosmoxl »
@Koying
I updated the Shield to the latest build and I'm seeing a change in the image now of Sony Camping.
Highlights are very blown vs non-tonemapped image. But, the main part of the image has very little improvement. Perhaps contrast is a little better but colors are still very light.
The DV screensaver rip is still just using surface so it's not being detected properly yet.
Mitnick
Post by Mitnick »
Some Videofiles and iptv channels with Mediacodec Surface (On) Skips lots of Frames after a few seconds.
Post by koying »
@cosmoxl
Yeah. I checked what *can* be achieved via madvr and I feel ridicule, now ;)
I will demote the feature to work-in-progress and remove from 3.7.0
Post by koying »
@Mitnick
debuglog please. "Some" doesn't help much in pinpointing an issue ;)
Mitnick wrote: 07 May 2018, 04:48 Some Videofiles and iptv channels with Mediacodec Surface (On) Skips lots of Frames after a few seconds.
please note that this is a technical TestFlight thread... we need a debug log and as much information as you can offer to be able to trace the issues.
if you are not on 3.7.0 testflight build then please post the same info in a separate/new thread in a relevant section as it will get lost in the sea of issues here
thanks!
cosmoxl wrote: 07 May 2018, 03:00
no issues here with a clean library and TVDB scraping.. what issues are you seeing?
pecinko
Post by pecinko »
amet wrote: 07 May 2018, 09:20 no issues here with a clean library and TVDB scraping.. what issues are you seeing?
Stops in the middle of scanning with "TVDB is not responding"
pecinko wrote: 07 May 2018, 10:40
debuglog? I dont see it here and I cant reproduce
pecinko
Post by pecinko »
timstephens24 wrote: 06 May 2018, 17:38 -No dark mode makes me sad. I'm just not a big fan of the light icons on a light background, with another light background in the back. I see you said it'll come eventually, so I'll be patient.
-I'd like to be able to remove the extra stuff like Music videos, Pictures, Add-ons, etc and add Plex to the main screen
-Can you add the video info icons (like the resolution, rating, sound, codec), probably up at the top bar? Or at least the option to do this, it helps when using an Apple TV 4 to see if it can play that movie.
-Is there a way to change Services to show Movies or TV Shows?
-Watched/unwatched identification is good, I really like that the TV shows the number of unwatched items.
-The video info page layout is really good, but I would like to see the background picture instead of it basically being all white.
-Same as above for the subsections under a show, like if I go into the Big Bang Theory to choose the seasons and/or episode I want to watch, I would rather see more of the background image and less of the white.
Thanks for feedback!
I found some time and I have just improved home screen - labels, icons etc.
I want to make sure light theme is complete. After that, dark theme will come very swiftly. I would prefer turning home items on and off automatically, based on actual content available. We'll see.
Mrmc should play everything, regardless of codec. Media flags seem unnecessary to me. What am I missing?
What "services" do you have in mind. Please elaborate.
