davilla wrote: 23 Feb 2018, 17:07 You can do this with a custom keymap, in <FullscreenVideo> section, replace "ChapterOrBigStepBack" with "OSDSettings"
Testing MrMC 3.5.1
- timstephens24
Re: Testing MrMC 3.5.1
wesk05
I checked the new testflight build on tvOS 11.2.6. I am seeing flashing bars only upto 84 with this build. Computers app showed all bars upto 68. AVFoundation & VideoToolBox options were enabled.davilla wrote: 22 Feb 2018, 16:27 ok, made some more changes based on 11.2.6 behavior.
Using "03 black-level-v3" test pattern.
I grab a screenshot of it under itunes. (home sharing), then do the same under MrMC. Now take these two screenshots, autolevel them and compare their histograms. The histograms are identical now.
Yep, It actually is showing bars below 16 and above 235. Haven't yet checked the actual levels of the HDMI output.davilla wrote: 22 Feb 2018, 16:30 Turn off VideoToolBox decoder and use AVFoundation for both h264 and h265. AVFoundation will show the above 235, VideoToolBox will not.
- Tgxcorporation
Please update the Black Glass Nova skin with the latest commits from the jarvis-mrmc branch!
Tgx
Tgx
Yes sirTgxcorporation wrote: 26 Feb 2018, 14:37 Please update the Black Glass Nova skin with the latest commits from the jarvis-mrmc branch!![]()
Tgx
SUPERBIF
Why not just switch subtitles directly instead of going into settings menu?timstephens24 wrote: 23 Feb 2018, 17:54davilla wrote: 23 Feb 2018, 17:07 You can do this with a custom keymap, in <FullscreenVideo> section, replace "ChapterOrBigStepBack" with "OSDSettings"![]()
- timstephens24
With what?SUPERBIF wrote: 26 Feb 2018, 14:53Why not just switch subtitles directly instead of going into settings menu?timstephens24 wrote: 23 Feb 2018, 17:54davilla wrote: 23 Feb 2018, 17:07 You can do this with a custom keymap, in <FullscreenVideo> section, replace "ChapterOrBigStepBack" with "OSDSettings"![]()
snipit from xbmc/input/ButtonTranslator.cpp
{ "stepforward" , ACTION_STEP_FORWARD },
{ "stepback" , ACTION_STEP_BACK },
{ "bigstepforward" , ACTION_BIG_STEP_FORWARD },
{ "bigstepback" , ACTION_BIG_STEP_BACK },
{ "chapterorbigstepforward" , ACTION_CHAPTER_OR_BIG_STEP_FORWARD },
{ "chapterorbigstepback" , ACTION_CHAPTER_OR_BIG_STEP_BACK },
{ "osd" , ACTION_SHOW_OSD },
{ "osdsettings" , ACTION_SHOW_OSD_SETTINGS },
{ "showsubtitles" , ACTION_SHOW_SUBTITLES },
{ "nextsubtitle" , ACTION_NEXT_SUBTITLE },
{ "cyclesubtitle" , ACTION_CYCLE_SUBTITLE },
- timstephens24
I don't want to mess with that, I'll stay with the longer process since there's not a way to make the down arrow work without messing with that stuff.
- Montoya
DVBLogic has just released the first beta's of the new DVBLink Server and its called TVMosaic.
https://forum.tv-mosaic.com/viewtopic.php?f=12&t=15
There are some changes in the TVMosaic compared to DVBLink server, so that software that uses the DVBLink API, needs to be modified:
Because this way, existing DVBLink users in MrMC won't be affected by this change.
Thanks !!
Can you guys make a copy of the DVBLink PVR and call it TVMosaic PVR and incorparate the above change (which ONLY applies for the TVMosaic Server and NOT for the DVBLink server) so we can test the TVMosaic server in MrMC ?Note for products, which use DVBLink Remote API to talk to DVBLink Server. There is a change to the DVBLink Remote API: dvblink_channel_id is now a String instead of Long. Please adjust it in your products. Changing it to string is backward compatible with DVBLink.
Thanks !!
please, please can we use requests section for ... well... requests... and keep TF thread for actual testing of TestFlight builds.
as much as I think your request is valid, it will get lost in the sea of msgs in this thread.
thanks
thanks
