Could you please explain what “drag the video” means, I am sorry I don’t know how to reproduce this issue.
Are you using Apple TV via wifi or lan cable?
Also, could you get us a full debuglog, don’t snip it in any way as the beginning contains info that we need.
Testing MrMC 3.3.1
Re: Testing MrMC 3.3.1
As mentioned in a post above, all tools that are creating a mkv with two streams are incomplete. They are ignoring the dolby vision parts so they only create HDR10 and an SDR streams. The 2nd stream is SDR, not the DV metadate. Give them some time and they will eventually get fixed. One issue is there are no public docs on how to correctly make a single layer dolby vision from a dual layer dolby vision.ryan19011 wrote: 08 Dec 2017, 08:42Did you test whether Dolby vision files play when they have 2 video streams? Because it appears all UHD bluray use 2 video streams 1 for HDR10 and second stream for DV metadata.three6zerocool wrote: 08 Dec 2017, 01:23 Tried out current TestFlight build.
Full range video levels seem really good now.
SDR black levels seem good so far.
Dolby Vision recognition working.
Will test further by watching some content.
I use Apple TV via wifi,drag the video for fast forward but it will go back.
https://pastebin.com/9UbahHZd
ws1115, you need to be more descriptive
Exactly what apps are you using to do a swipe on the appleTV.
DEBUG: FactoryCodec - Video: vtb - Failed
DEBUG: FactoryCodec - Video: avf- - Failed
NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
171201.2017.MAMA.Hong.Kong.Red.Carpet.1080i.IPTV.H264-JPS.ts
smells like interlaced. which deinerlacer is being used.
i use remote to swipe,i cant use any
app. same swipe method on kodi video will not go back.
It's better to just tap the edges of the remote, not click.ws1115 wrote: 08 Dec 2017, 14:47 i use remote to swipe,i cant use any
But, you may be able to adjust siri remote settings to get the handling you want.
I slide the touchpad to the right to a large extent,i dont have click the touchpad,but the video will go back.on kodi it wont appears.
just to be clear....
swipe from left -> right will FF
swipe from right ->left will REW
Kodi might have not used the same mapping we have for Siri remote
