I was just notified this evening that a new iOS build is available.
With the user interface as it is now for iOS are there any tricks I should know about while playing a video?
ersan191
Re: Testing MrMC 3.7.0
Just got the TestFlight - there's a few new issues with FanArt in the Plex for Kodi addon.
It seems to set the background of the home screen to fanart of whatever was recently playing, which is very ugly:
Also when selecting some items from the homescreen it will set the fanart as the background of the preplay/info screen for that item without blurring it like it always has before. When I have a predominantly white fanart this makes the white text hard to read.
I think it's just not applying a blur to the fanart sometimes when it should be.
ersan191
Also AirPlay is not in sync no matter what when playing something now. It's at least 100-200ms out of sync, I had posted that it drifted out of sync over time on the github issues page before but now it seems out of sync by default.
Not a big deal though, I've given up on AirPlay from MrMC honestly. It only seems to work properly with the built in tvOS video player, doesn't work correctly in Infuse either.
(180617.6 @20180616-577598f)
SYNC: skin.ariana
FIX: keymap editor for keyboards
FIX: do not refresh home thumbs if we are not at home
plex: add playlist duration as Label2()
plex: set all nodes/filters content to items.SetContent("filters");
Plex: clear artist(musis) and photo sections before updating them
plex: typo , clear playlist section not m_movieSections
pass m_parentRedirect, if it was set over to a new window
FIX: add PvrAddons to Media Sources
FIX: Servers on home screen
ActiveAE: Fix up Typo
pvr: force clean EPG database when stopping the PVR manager
Media Sources PostMsg(TMSG_SETPVRMANAGERSTATE) to toggle PVR manager on/off
tvOS: fix step back/Forward on Live TV
Display milliseconds in log file
fix Plex TvShow dialoginfo
SYNC: skin.ariana
ersan191
Awesome, not sure if the last fix was supposed to apply to the fanart issue I just posted about a few minutes ago but it didn't fix it if so (reinstalled MrMC and everything to test).davilla wrote: 17 Jun 2018, 04:01 (180617.6 @20180616-577598f)
SYNC: skin.ariana
inariel12
The last beta introduced some problem with OSD and video play: I continued to watch a video (low resolution) and it seems frozen for some seconds after it starts but accessing on OSD I cannot select anymore subtitle languages or audio/video setting since the click on Siri remote seems broken.
Moreover, using the menu button I come back to tvOS home instead of to exit from OSD.
Coming back to MrMC, I return to my episodes.
It is quite strange.
Attached some logs.https://www.dropbox.com/s/2vhol8z33zkro3l/logs.txt?dl=0
- pecinko
Thanks for reporting.inariel12 wrote: 17 Jun 2018, 06:55 The last beta introduced some problem with OSD and video play: I continued to watch a video (low resolution) and it seems frozen for some seconds after it starts but accessing on OSD I cannot select anymore subtitle languages or audio/video setting since the click on Siri remote seems broken.
Can you please try changing Skin to Opacity temporarily?
inariel12
Ok. I’ve just tried and it seems to work fine: swipe down for the OSD and click to select elements into the OSD.
Switching back to Ariana, I have the same issues as described before.
Let me know how I could help you.
- pecinko
You already helped. Thanks.inariel12 wrote: 17 Jun 2018, 09:15 Ok. I’ve just tried and it seems to work fine: swipe down for the OSD and click to select elements into the OSD.
Will be fixed for next TFlight.
- logan_x50
Hmmm. that "SWIPE" comment is inconsistent with the change request though innit?timstephens24 wrote: 16 Jun 2018, 20:28BUT ONE MORE SWIPE! I HAVE TO SWIPE ONE MORE TIME!amet wrote: 16 Jun 2018, 20:13
make everyone happy? hahah never going to happen....
on a serious note, to maintain usability of the older skins which might or might not be in MrMC in future, we are keeping Home shelves as they were for now.... you get what we think you need on Home![]()
It's cool, however you guys think is best. If we're nitpicking over little things like this I think MrMC is in a good spot.
