Thanks for the info! Hmm.. the links don't work.cosmoxl wrote: 22 Feb 2018, 16:45 1) Display is Vizio xvt3d554sv
2) colorspace is ycbcr 4:4:4 8bit. The ATV only says ycbcr but my receiver confirms it's 444 8bit.
3) Test patterns I use: https://file.io/lUrlOb and https://file.io/RTn3Ea
Testing MrMC 3.5.1
wesk05
Re: Testing MrMC 3.5.1
weird, I tested them before I posted this and they worked. I'll update the host.wesk05 wrote: 22 Feb 2018, 16:48Thanks for the info! Hmm.. the links don't work.cosmoxl wrote: 22 Feb 2018, 16:45 1) Display is Vizio xvt3d554sv
not sure I understand whats going on there, I have tested on my end again and all entries match Web UI and MrMCinariel12 wrote: 22 Feb 2018, 07:44No, I don’t have.amet wrote:Yes , recently added/in progress submenu... do you have anything else listed in the level before? Do you see a list of plex libraries before you see a list of episodes?
I know what you mean since it was testing Emby server and MySQL library before using Plex.
Right now, I logged out from Emby and I disabled MySQL even if I didn’t remove the configuration (it is just off). I attached the first screenshot obtained after selecting recently added from submenu on left side of the home view.
If I did the same going into In progress submenu, I see a list of episode ordered by “playlist” with the same order as the one into the home view.
Should I try to unistall/reinstall MrMC to start from a clean situation? Or it could be related to the content of server?
An additional information: I imported watched status from Trakt when I configured the Plex server.
Inviato dal mio iPhone utilizzando Tapatalk
lets see a debuglog please, maybe something stands out there
inariel12
Ok. I enabled debug log and restarted MrMC.amet wrote:not sure I understand whats going on there, I have tested on my end again and all entries match Web UI and MrMCinariel12 wrote: 22 Feb 2018, 07:44No, I don’t have.amet wrote:
Content of MrMC Log
20:25:28 T:6128119808 NOTICE: special://profile/ is mapped to: special://masterprofile/
20:25:28 T:6128119808 NOTICE: -----------------------------------------------------------------------
20:25:28 T:6128119808 NOTICE: Starting MrMC (3.5-1 Git:2018-02-20-a3d3a34). Platform: TVOS ARM64 64-bit
20:25:28 T:6128119808 NOTICE: Using Release MrMC x64 build
20:25:28 T:6128119808 NOTICE: MrMC compiled Feb 20 2018 by Clang 9.0.0 (clang-900.0.39.2) for TVOS ARM64 64-bit version 10.2.0 (100200)
20:25:28 T:6128119808 NOTICE: Running on Apple Inc. AppleTV6,2 with TVOS 11.2.6, kernel: Darwin ARM 64-bit version 17.4.0
20:25:28 T:6128119808 NOTICE: Host CPU: arm64 v8, 3 cores available
20:25:28 T:6128119808 NOTICE: ARM Features: Neon enabled
20:25:28 T:6128119808 NOTICE: special://xbmc/ is mapped to: /private/var/containers/Bundle/Application/FDF090A7-DC1A-4BE9-A11A-B318D680B857/MrMC.app/AppData/AppHome
20:25:28 T:6128119808 NOTICE: special://xbmcbin/ is mapped to: /private/var/containers/Bundle/Application/FDF090A7-DC1A-4BE9-A11A-B318D680B857/MrMC.app/AppData/AppHome
20:25:28 T:6128119808 NOTICE: special://masterprofile/ is mapped to: /var/mobile/Containers/Data/Application/3915B825-6696-446E-B05B-15200EC87B03/Library/Caches/home/userdata
20:25:28 T:6128119808 NOTICE: special://home/ is mapped to: /var/mobile/Containers/Data/Application/3915B825-6696-446E-B05B-15200EC87B03/Library/Caches/home
20:25:28 T:6128119808 NOTICE: special://temp/ is mapped to: /private/var/mobile/Containers/Data/Application/3915B825-6696-446E-B05B-15200EC87B03/tmp/temp
20:25:28 T:6128119808 NOTICE: special://logs/ is mapped to: /var/mobile/Containers/Data/Application/3915B825-6696-446E-B05B-15200EC87B03/Library/Caches/logs/
20:25:28 T:6128119808 NOTICE: special://frameworks/ is mapped to: /var/containers/Bundle/Application/FDF090A7-DC1A-4BE9-A11A-B318D680B857/MrMC.app/Frameworks
20:25:28 T:6128119808 NOTICE: The executable running is: /var/containers/Bundle/Application/FDF090A7-DC1A-4BE9-A11A-B318D680B857/MrMC.app/MrMC
20:25:28 T:6128119808 NOTICE: Local hostname: Camera-da-letto
20:25:28 T:6128119808 NOTICE: Log File is located: special://logs/mrmc.log
20:25:29 T:6128119808 NOTICE: load settings...
20:25:29 T:6128119808 WARNING: CSettingString: unknown options filler "timezonecountries" of "locale.timezonecountry"
20:25:29 T:6128119808 WARNING: CSettingString: unknown options filler "timezones" of "locale.timezone"
20:25:29 T:6128119808 WARNING: CSettingInt: unknown options filler "audiocdactions" of "audiocds.autoaction"
20:25:29 T:6128119808 WARNING: CSetting: duplicate <update> definition for "lookandfeel.soundskin"
20:25:29 T:6128119808 ERROR: CSetting: missing <control> tag of "videoscreen.vsync"
20:25:29 T:6128119808 WARNING: CSettingGroup: unable to read setting "videoscreen.vsync"
20:25:29 T:6128119808 NOTICE: Found 1 Lists of Devices
20:25:29 T:6128119808 NOTICE: Enumerated DARWINIOS devices:
20:25:29 T:6128119808 NOTICE: Device 1
20:25:29 T:6128119808 NOTICE: m_deviceName : default
20:25:29 T:6128119808 NOTICE: m_displayName : Default
20:25:29 T:6128119808 NOTICE: m_displayNameExtra:
20:25:29 T:6128119808 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
20:25:29 T:6128119808 NOTICE: m_channels : FL,FR,FC,LFE,BL,BR
20:25:29 T:6128119808 NOTICE: m_sampleRates : 44100,48000
20:25:29 T:6128119808 NOTICE: m_dataFormats : AE_FMT_RAW,AE_FMT_S16LE,AE_FMT_FLOAT
20:25:29 T:6128119808 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_EAC3,STREAM_TYPE_DTS_512,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTSHD_CORE
20:25:29 T:6128119808 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
20:25:29 T:6128119808 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
20:25:29 T:6128119808 NOTICE: Default DVD Player: dvdplayer
20:25:29 T:6128119808 NOTICE: Default Video Player: dvdplayer
20:25:29 T:6128119808 NOTICE: Default Audio Player: paplayer
20:25:29 T:6128119808 NOTICE: Disabled debug logging due to GUI setting. Level 0.
20:25:29 T:6128119808 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
20:25:29 T:6128119808 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
20:25:29 T:6128119808 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
20:25:29 T:6128119808 NOTICE: Loaded playercorefactory configuration
20:25:29 T:6128119808 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
20:25:29 T:6128119808 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
20:25:29 T:6129840128 NOTICE: bool CAAudioUnitSink::setupAudio() setting channels 2
20:25:29 T:6129840128 NOTICE: bool CAAudioUnitSink::setupAudio() setting samplerate 48000.000000
20:25:29 T:6129840128 NOTICE: bool CAAudioUnitSink::setupAudio() setting buffer duration to 0.021333
20:25:29 T:6129840128 NOTICE: bool CAAudioUnitSink::setupAudio() total latency = 0.044500
20:25:29 T:6129840128 NOTICE: bool CAAudioUnitSink::setupAudio() setup audio format: [lpcm] Mixable Interleaved 2 Channel 32-bit Floating Point LE (48000Hz)
20:25:29 T:6129840128 NOTICE: void dumpAVAudioSessionProperties() audio route = HDMIOutput
20:25:29 T:6129840128 NOTICE: void dumpAVAudioSessionProperties() sampleRate 48000.000000
20:25:29 T:6129840128 NOTICE: void dumpAVAudioSessionProperties() outputLatency 0.001833
20:25:29 T:6129840128 NOTICE: void dumpAVAudioSessionProperties() IOBufferDuration 0.021333
20:25:29 T:6129840128 NOTICE: void dumpAVAudioSessionProperties() outputNumberOfChannels 2
20:25:29 T:6129840128 NOTICE: void dumpAVAudioSessionProperties() maximumOutputNumberOfChannels 2
20:25:29 T:6128119808 NOTICE: Running database version Addons20
20:25:29 T:6128119808 NOTICE: Found possible resolution for display 0 with 1920 x 1080
20:25:29 T:6128119808 NOTICE: Checking resolution 16
20:25:29 T:6128119808 NOTICE: GL_VENDOR = Apple Inc.
20:25:29 T:6128119808 NOTICE: GL_RENDERER = Apple A10X GPU
20:25:29 T:6128119808 NOTICE: GL_VERSION = OpenGL ES 3.0 Metal - 52.1.2
20:25:29 T:6128119808 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 3.00
20:25:29 T:6128119808 NOTICE: GL_EXTENSIONS = GL_OES_standard_derivatives GL_KHR_texture_compression_astc_ldr GL_EXT_color_buffer_half_float GL_EXT_debug_label GL_EXT_debug_marker GL_EXT_pvrtc_sRGB GL_EXT_read_format_bgra GL_EXT_separate_shader_objects GL_EXT_shader_framebuffer_fetch GL_EXT_shader_texture_lod GL_EXT_shadow_samplers GL_EXT_texture_filter_anisotropic GL_APPLE_clip_distance GL_APPLE_color_buffer_packed_float GL_APPLE_copy_texture_levels GL_APPLE_rgb_422 GL_APPLE_texture_format_BGRA8888 GL_IMG_read_format GL_IMG_texture_compression_pvrtc
20:25:29 T:6131560448 NOTICE: Running database version Addons20
20:25:29 T:6131560448 NOTICE: Running database version ViewModes6
20:25:29 T:6131560448 NOTICE: Running database version Textures13
20:25:29 T:6131560448 NOTICE: Running database version MyMusic60
20:25:29 T:6131560448 NOTICE: Running database version MyVideos107
20:25:29 T:6131560448 NOTICE: Running database version TV29
20:25:29 T:6131560448 NOTICE: Running database version Epg11
20:25:29 T:6128119808 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
20:25:29 T:6128119808 NOTICE: ActiveAE DSP - starting
20:25:29 T:6128119808 NOTICE: initialize done
20:25:29 T:6128119808 NOTICE: Running the application...
20:25:29 T:6128119808 NOTICE: starting zeroconf publishing
20:25:29 T:6128119808 NOTICE: WebServer: Started the webserver
20:25:29 T:6128119808 NOTICE: starting upnp client
20:25:29 T:6138343424 NOTICE: ES: Starting UDP Event server on 127.0.0.1:9777
20:25:29 T:6138343424 NOTICE: UDP: Listening on port 9777
20:25:30 T:6140014592 NOTICE: CPlexServices: Server found via plex.tv Nassone
20:25:31 T:6129266688 NOTICE: Found 1 Lists of Devices
20:25:31 T:6129266688 NOTICE: Enumerated DARWINIOS devices:
20:25:31 T:6129266688 NOTICE: Device 1
20:25:31 T:6129266688 NOTICE: m_deviceName : default
20:25:31 T:6129266688 NOTICE: m_displayName : Default
20:25:31 T:6129266688 NOTICE: m_displayNameExtra:
20:25:31 T:6129266688 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
20:25:31 T:6129266688 NOTICE: m_channels : FL,FR,FC,LFE,BL,BR
20:25:31 T:6129266688 NOTICE: m_sampleRates : 44100,48000
20:25:31 T:6129266688 NOTICE: m_dataFormats : AE_FMT_RAW,AE_FMT_S16LE,AE_FMT_FLOAT
20:25:31 T:6129266688 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_EAC3,STREAM_TYPE_DTS_512,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTSHD_CORE
20:25:31 T:6129840128 NOTICE: bool CAAudioUnitSink::setupAudio() setting channels 2
20:25:31 T:6129840128 NOTICE: bool CAAudioUnitSink::setupAudio() setting samplerate 48000.000000
20:25:31 T:6129840128 NOTICE: bool CAAudioUnitSink::setupAudio() setting buffer duration to 0.021333
20:25:31 T:6129840128 NOTICE: bool CAAudioUnitSink::setupAudio() total latency = 0.044500
20:25:31 T:6129840128 NOTICE: bool CAAudioUnitSink::setupAudio() setup audio format: [lpcm] Mixable Interleaved 2 Channel 32-bit Floating Point LE (48000Hz)
20:25:31 T:6129840128 NOTICE: void dumpAVAudioSessionProperties() audio route = HDMIOutput
20:25:31 T:6129840128 NOTICE: void dumpAVAudioSessionProperties() sampleRate 48000.000000
20:25:31 T:6129840128 NOTICE: void dumpAVAudioSessionProperties() outputLatency 0.001833
20:25:31 T:6129840128 NOTICE: void dumpAVAudioSessionProperties() IOBufferDuration 0.021333
20:25:31 T:6129840128 NOTICE: void dumpAVAudioSessionProperties() outputNumberOfChannels 2
20:25:31 T:6129840128 NOTICE: void dumpAVAudioSessionProperties() maximumOutputNumberOfChannels 2
20:25:51 T:6128119808 NOTICE: Log level changed to "LOG_LEVEL_DEBUG_FREEMEM"
20:25:51 T:6128119808 NOTICE: Enabled debug logging due to GUI setting. Level 2.
20:25:58 T:6128119808 DEBUG: found key /userdata/profiles.xml
20:25:58 T:6128119808 DEBUG: Previous line repeats 1 times.
20:25:58 T:6128119808 DEBUG: NSUSerDefaults: compressed /userdata/profiles.xml from 923 to 324
20:25:58 T:6128119808 DEBUG: found key /userdata/guisettings.xml
20:25:58 T:6128119808 DEBUG: NSUSerDefaults: compressed /userdata/guisettings.xml from 33490 to 6592
20:25:58 T:6128119808 DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
20:25:58 T:6128119808 DEBUG: ------ Window Deinit (SettingsCategory.xml) ------
20:25:58 T:6128119808 DEBUG: CGUIWindowManager::PreviousWindow: Activate new
20:25:58 T:6128119808 DEBUG: ------ Window Init (Settings.xml) ------
20:26:00 T:6128119808 DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
20:26:00 T:6128119808 DEBUG: ------ Window Deinit (Settings.xml) ------
20:26:00 T:6128119808 DEBUG: CGUIWindowManager::PreviousWindow: Activate new
20:26:00 T:6128119808 DEBUG: ------ Window Init (Home.xml) ------
20:26:00 T:6141161472 DEBUG: CHomeShelfJob::UpdateMusic() - Running HomeShelf screen update
20:26:00 T:6141161472 DEBUG: CHomeShelfJob::UpdateVideos() - Running HomeShelf screen update
20:26:00 T:6141161472 DEBUG: CurlFile::Open(0x16e0a8ad0) https://192.168.1.21:32400/library/sections/2/onDeck
20:26:00 T:6141161472 DEBUG: CurlFile::Open(0x16e0a8ad0) https://192.168.1.21:32400/library/sections/1/onDeck
20:26:00 T:6141161472 DEBUG: CurlFile::Open(0x16e0a8ac0) https://192.168.1.21:32400/library/sections/2/recentlyAdded?unwatched=1
20:26:00 T:6141161472 DEBUG: CurlFile::Open(0x16e0a8ac0) https://192.168.1.21:32400/library/sections/1/recentlyAdded?unwatched=1
20:26:00 T:6131560448 DEBUG: CHomeShelfJob::UpdateTotal() - Running HomeShelf home screen update
20:26:00 T:6131560448 DEBUG: CurlFile::Open(0x16d781e00) https://192.168.1.21:32400/library/sections/1/all?type=1&unwatched=1
20:26:00 T:6131560448 DEBUG: CurlFile::Open(0x16d781e00) https://192.168.1.21:32400/library/sections/2/all?type=4&unwatched=1
20:26:01 T:6131560448 DEBUG: CurlFile::Open(0x16d781e00) https://192.168.1.21:32400/library/sections/2/all?type=4
20:26:01 T:6131560448 DEBUG: CurlFile::Open(0x16d781e00) https://192.168.1.21:32400/library/sections/2/all?type=2
20:26:01 T:6131560448 DEBUG: CurlFile::Open(0x16d781e00) https://192.168.1.21:32400/library/sections/2/all?type=2&unwatched=1
20:26:01 T:6131560448 DEBUG: CHomeShelfJob::UpdateTotal() - Finished
20:26:01 T:6128119808 DEBUG: Activating window ID: 10004
20:26:01 T:6128119808 DEBUG: ------ Window Deinit (Home.xml) ------
20:26:01 T:6128119808 DEBUG: ------ Window Init (Settings.xml) ------
20:26:03 T:6128119808 DEBUG: Activating window ID: 10018
20:26:03 T:6128119808 DEBUG: ------ Window Deinit (Settings.xml) ------
20:26:03 T:6128119808 DEBUG: ------ Window Init (SettingsCategory.xml) ------
20:26:33 T:6128119808 DEBUG: CTraktServices:OnSettingAction sign-out ok
20:26:33 T:6128119808 DEBUG: found key /userdata/profiles.xml
20:26:33 T:6128119808 DEBUG: Previous line repeats 1 times.
20:26:33 T:6128119808 DEBUG: NSUSerDefaults: compressed /userdata/profiles.xml from 923 to 324
20:26:33 T:6128119808 DEBUG: found key /userdata/guisettings.xml
20:26:33 T:6128119808 DEBUG: NSUSerDefaults: compressed /userdata/guisettings.xml from 33412 to 6479
20:26:44 T:6128119808 DEBUG: found key /userdata/profiles.xml
20:26:44 T:6128119808 DEBUG: Previous line repeats 1 times.
20:26:44 T:6128119808 DEBUG: NSUSerDefaults: compressed /userdata/profiles.xml from 923 to 324
20:26:44 T:6128119808 DEBUG: found key /userdata/guisettings.xml
20:26:44 T:6128119808 DEBUG: NSUSerDefaults: compressed /userdata/guisettings.xml from 33412 to 6479
20:26:44 T:6128119808 DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
20:26:44 T:6128119808 DEBUG: ------ Window Deinit (SettingsCategory.xml) ------
20:26:44 T:6128119808 DEBUG: CGUIWindowManager::PreviousWindow: Activate new
20:26:44 T:6128119808 DEBUG: ------ Window Init (Settings.xml) ------
20:26:45 T:6128119808 DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
20:26:45 T:6128119808 DEBUG: ------ Window Deinit (Settings.xml) ------
20:26:45 T:6128119808 DEBUG: CGUIWindowManager::PreviousWindow: Activate new
20:26:45 T:6128119808 DEBUG: ------ Window Init (Home.xml) ------
20:26:45 T:6130413568 DEBUG: CHomeShelfJob::UpdateMusic() - Running HomeShelf screen update
20:26:45 T:6130413568 DEBUG: CHomeShelfJob::UpdateVideos() - Running HomeShelf screen update
20:26:45 T:6130413568 DEBUG: CurlFile::Open(0x16d668ad0) https://192.168.1.21:32400/library/sections/2/onDeck
20:26:45 T:6130413568 INFO: easy_aquire - Created session to https://192.168.1.21
20:26:46 T:6130413568 DEBUG: CurlFile::Open(0x16d668ad0) https://192.168.1.21:32400/library/sections/1/onDeck
20:26:46 T:6130413568 DEBUG: CurlFile::Open(0x16d668ac0) https://192.168.1.21:32400/library/sections/2/recentlyAdded?unwatched=1
20:26:46 T:6130413568 DEBUG: CurlFile::Open(0x16d668ac0) https://192.168.1.21:32400/library/sections/1/recentlyAdded?unwatched=1
20:26:46 T:6130413568 DEBUG: CHomeShelfJob::UpdateTotal() - Running HomeShelf home screen update
20:26:46 T:6130413568 DEBUG: CurlFile::Open(0x16d669e00) https://192.168.1.21:32400/library/sections/1/all?type=1&unwatched=1
20:26:46 T:6130413568 DEBUG: CurlFile::Open(0x16d669e00) https://192.168.1.21:32400/library/sections/2/all?type=4&unwatched=1
20:26:46 T:6130413568 DEBUG: CurlFile::Open(0x16d669e00) https://192.168.1.21:32400/library/sections/2/all?type=2
20:26:46 T:6130413568 DEBUG: CurlFile::Open(0x16d669e00) https://192.168.1.21:32400/library/sections/2/all?type=2&unwatched=1
20:26:46 T:6130413568 DEBUG: CHomeShelfJob::UpdateTotal() - Finished
20:26:46 T:7118721728 DEBUG: shouldReceivePress:focusedWindowID == WINDOW_HOME
20:26:47 T:6125826048 NOTICE: stopping zeroconf publishing
20:26:47 T:6140014592 DEBUG: CPlexServices::Process end
20:26:54 T:7118721728 NOTICE: starting zeroconf publishing
20:26:54 T:6130987008 DEBUG: CZeroconfOSX::doPublishService identifier: servers.eventserver type: _xbmc-events._udp name:MrMC (Camera-da-letto) port:9777
20:26:54 T:6128693248 DEBUG: CPlexServices::Process bgn
20:26:54 T:6129266688 DEBUG: CActiveAE - device change event
20:26:54 T:6128693248 DEBUG: CPlexServices::Process has gateway1
20:26:54 T:6128693248 DEBUG: CurlFile::Open(0x10500a338) https://plex.tv/pms/resources?includeHttps=1
20:26:54 T:6129266688 DEBUG: EnumerateDevices:Device(default)
20:26:54 T:6129266688 NOTICE: Found 1 Lists of Devices
20:26:54 T:6129266688 NOTICE: Enumerated DARWINIOS devices:
20:26:54 T:6129266688 NOTICE: Device 1
20:26:54 T:6129266688 NOTICE: m_deviceName : default
20:26:54 T:6129266688 NOTICE: m_displayName : Default
20:26:54 T:6129266688 NOTICE: m_displayNameExtra:
20:26:54 T:6129266688 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
20:26:54 T:6129266688 NOTICE: m_channels : FL,FR,FC,LFE,BL,BR
20:26:54 T:6129266688 NOTICE: m_sampleRates : 44100,48000
20:26:54 T:6129266688 NOTICE: m_dataFormats : AE_FMT_RAW,AE_FMT_S16LE,AE_FMT_FLOAT
20:26:54 T:6129266688 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_EAC3,STREAM_TYPE_DTS_512,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTSHD_CORE
20:26:54 T:6129840128 INFO: CActiveAESink::OpenSink - initialize sink
20:26:54 T:6129840128 DEBUG: CActiveAESink::OpenSink - trying to open device DARWINIOS:default
20:26:54 T:6129840128 DEBUG: virtual bool CAESinkDARWINIOS::Initialize(AEAudioFormat &, std::string &): AudioStreamBasicDescription: [lpcm] Mixable Interleaved 2 Channel 32-bit Floating Point LE (48000Hz) pcm
20:26:54 T:6130987008 DEBUG: CZeroconfOSX::doPublishService identifier: servers.jsonrpc-http type: _xbmc-jsonrpc-h._tcp name:MrMC (Camera-da-letto) port:8080
20:26:54 T:6129840128 NOTICE: bool CAAudioUnitSink::setupAudio() setting channels 2
20:26:54 T:6129840128 NOTICE: bool CAAudioUnitSink::setupAudio() setting samplerate 48000.000000
20:26:54 T:6129840128 NOTICE: bool CAAudioUnitSink::setupAudio() setting buffer duration to 0.021333
20:26:54 T:6130987008 DEBUG: CZeroconfOSX::doPublishService identifier: servers.jsonrpc-tpc type: _xbmc-jsonrpc._tcp name:MrMC (Camera-da-letto) port:9090
20:26:54 T:6130987008 DEBUG: CZeroconfOSX::doPublishService identifier: servers.webserver type: _http._tcp name:MrMC (Camera-da-letto) port:8080
20:26:54 T:6129840128 NOTICE: bool CAAudioUnitSink::setupAudio() total latency = 0.044500
20:26:54 T:6129840128 NOTICE: bool CAAudioUnitSink::setupAudio() setup audio format: [lpcm] Mixable Interleaved 2 Channel 32-bit Floating Point LE (48000Hz)
20:26:54 T:6129840128 NOTICE: void dumpAVAudioSessionProperties() audio route = HDMIOutput
20:26:54 T:6129840128 NOTICE: void dumpAVAudioSessionProperties() sampleRate 48000.000000
20:26:54 T:6129840128 NOTICE: void dumpAVAudioSessionProperties() outputLatency 0.001833
20:26:54 T:6129840128 NOTICE: void dumpAVAudioSessionProperties() IOBufferDuration 0.021333
20:26:54 T:6129840128 NOTICE: void dumpAVAudioSessionProperties() outputNumberOfChannels 2
20:26:54 T:6129840128 NOTICE: void dumpAVAudioSessionProperties() maximumOutputNumberOfChannels 2
20:26:54 T:6129840128 DEBUG: DumpAudioDescriptions: void dumpAVAudioSessionProperties()
20:26:54 T:6129840128 DEBUG: DumpAudioDescriptions: input count = 0
20:26:54 T:6129840128 DEBUG: DumpAudioDescriptions: output count = 1
20:26:54 T:6129840128 DEBUG: DumpAudioDescriptions : portName, Camera da letto
20:26:54 T:6129840128 DEBUG: DumpAudioDescriptions: channelLabel, 1
20:26:54 T:6129840128 DEBUG: DumpAudioDescriptions: channelName , Camera da letto 1
20:26:54 T:6129840128 DEBUG: DumpAudioDescriptions: channelLabel, 2
20:26:54 T:6129840128 DEBUG: DumpAudioDescriptions: channelName , Camera da letto 2
20:26:54 T:6129840128 DEBUG: CActiveAESink::OpenSink - DARWINIOS Initialized:
20:26:54 T:6129840128 DEBUG: Output Device : Default
20:26:54 T:6129840128 DEBUG: Sample Rate : 48000
20:26:54 T:6129840128 DEBUG: Sample Format : AE_FMT_FLOAT
20:26:54 T:6129840128 DEBUG: Channel Count : 2
20:26:54 T:6129840128 DEBUG: Channel Layout: FL,FR
20:26:54 T:6129840128 DEBUG: Frames : 1024
20:26:54 T:6129840128 DEBUG: Frame Size : 8
20:26:54 T:6129840128 DEBUG: CActiveAESink::GenerateNoise - noiseFactor = 0.000010
20:26:54 T:6129266688 DEBUG: CActiveAE::ClearDiscardedBuffers - buffer pool deleted
20:26:54 T:6128693248 DEBUG: CurlFile::Open(0x16d4c6350) https://192.168.1.21:32400/identity
20:26:54 T:6128693248 DEBUG: CPlexClient::Init serverName(Nassone), ipAddress(192.168.1.21), protocol(https)
20:26:54 T:6128693248 DEBUG: CurlFile::Open(0x16d4c6610) https://192.168.1.21:32400/library/sections
20:26:54 T:6128693248 DEBUG: CPlexClient::ParseSections Nassone found 1 movie sections
20:26:54 T:6128693248 DEBUG: CPlexClient::ParseSections Nassone found 1 shows sections
20:26:54 T:6128693248 DEBUG: CPlexClient::ParseSections Nassone found 0 artist sections
20:26:54 T:6128693248 DEBUG: CPlexClient::ParseSections Nassone found 0 photo sections
20:26:54 T:6128693248 NOTICE: CPlexServices: Server found via plex.tv Nassone
20:26:54 T:6130413568 DEBUG: CGUIWindowHome::Announce, type: 16, from xbmc, message UpdateRecentlyAdded
20:26:54 T:6130413568 DEBUG: CGUIWindowHome::Announce, type: 32, from xbmc, message UpdateRecentlyAdded
20:26:54 T:6130987008 DEBUG: CHomeShelfJob::UpdateVideos() - Running HomeShelf screen update
20:26:54 T:6130987008 DEBUG: CurlFile::Open(0x16d6f4ad0) https://192.168.1.21:32400/library/sections/2/onDeck
20:26:55 T:6130987008 DEBUG: CurlFile::Open(0x16d6f4ad0) https://192.168.1.21:32400/library/sections/1/onDeck
20:26:55 T:6130987008 DEBUG: CurlFile::Open(0x16d6f4ac0) https://192.168.1.21:32400/library/sections/2/recentlyAdded?unwatched=1
20:26:55 T:6130987008 DEBUG: CurlFile::Open(0x16d6f4ac0) https://192.168.1.21:32400/library/sections/1/recentlyAdded?unwatched=1
20:26:55 T:6130987008 DEBUG: CHomeShelfJob::UpdateMusic() - Running HomeShelf screen update
20:26:55 T:6130987008 DEBUG: CHomeShelfJob::UpdateTotal() - Running HomeShelf home screen update
20:26:55 T:6130987008 DEBUG: CurlFile::Open(0x16d6f5e00) https://192.168.1.21:32400/library/sections/1/all?type=1&unwatched=1
20:26:55 T:6130987008 DEBUG: CurlFile::Open(0x16d6f5e00) https://192.168.1.21:32400/library/sections/2/all?type=4&unwatched=1
20:26:55 T:6130987008 DEBUG: CurlFile::Open(0x16d6f5e00) https://192.168.1.21:32400/library/sections/2/all?type=2
20:26:55 T:6130987008 DEBUG: CurlFile::Open(0x16d6f5e00) https://192.168.1.21:32400/library/sections/2/all?type=2&unwatched=1
20:26:55 T:6130987008 DEBUG: CHomeShelfJob::UpdateTotal() - Finished
20:28:01 T:6130937856 DEBUG: webserver: request received for /
20:28:01 T:6130937856 DEBUG: webserver: request received for /css/core.css?1.3.57
20:28:01 T:6132035584 DEBUG: webserver: request received for /css/ipad.css?1.0.5
20:28:01 T:6141685760 DEBUG: webserver: request received for /images/ajax-loader.gif
20:28:01 T:6142783488 DEBUG: webserver: request received for /js/xbmc.launcher.js?v=2.1.0
20:28:01 T:6130937856 DEBUG: webserver: request received for /js/jquery-1.8.2.min.js?2.1.0
20:28:01 T:6141685760 DEBUG: webserver: request received for /js/iscroll-min.js?2.1.0
20:28:01 T:6142783488 DEBUG: webserver: request received for /js/xbmc.core.js?2.1.0
20:28:01 T:6132035584 DEBUG: webserver: request received for /js/json2.js?2.1.0
20:28:01 T:6142783488 DEBUG: webserver: request received for /js/xbmc.rpc.js?2.1.0
20:28:01 T:6141685760 DEBUG: webserver: request received for /js/MediaLibrary.js?2.1.0
20:28:01 T:6130937856 DEBUG: webserver: request received for /js/NowPlayingManager.js?2.1.0
20:28:01 T:6132035584 DEBUG: webserver: request received for /js/xbmc.init.js?2.1.0
20:28:01 T:6130937856 DEBUG: webserver: request received for /jsonrpc?Playlist.GetPlaylists
20:28:01 T:6132035584 DEBUG: webserver: request received for /jsonrpc?Player.GetActivePlayers
20:28:04 T:6130937856 DEBUG: Previous line repeats 2 times.
20:28:04 T:6130937856 DEBUG: webserver: request received for /jsonrpc?System.IsLite
20:28:04 T:6130937856 DEBUG: webserver: request received for /vfs%2Fspecial%3A%2F%2Flogs%2Fmrmc.log?1519327684581
20:28:04 T:6130937856 DEBUG: webserver: request received for /jsonrpc?Player.GetActivePlayers
20:29:06 T:6128119808 DEBUG: Previous line repeats 58 times.
20:29:06 T:6128119808 DEBUG: Activating window ID: 10025
20:29:06 T:6128119808 DEBUG: ------ Window Deinit (Home.xml) ------
20:29:07 T:6128119808 DEBUG: ------ Window Init (MyVideoNav.xml) ------
20:29:07 T:6128119808 INFO: Loading skin file: MyVideoNav.xml, load type: KEEP_IN_MEMORY
20:29:07 T:6130937856 DEBUG: webserver: request received for /jsonrpc?Player.GetActivePlayers
20:29:07 T:6131511296 ERROR: GetDirectory - Error getting
20:29:07 T:6128119808 DEBUG: CServicesDirectory::GetDirectory
20:29:07 T:6128119808 DEBUG: CServicesDirectory::GetDirectory strURL = services://tvshows/inprogressshows/
20:29:07 T:6131511296 DEBUG: CPlexDirectory::GetDirectory
20:29:07 T:6131511296 DEBUG: CPlexDirectory::GetDirectory strURL = plex://tvshows/inprogressshows/
20:29:07 T:6131511296 DEBUG: CPlexDirectory::GetDirectory strURL = plex://tvshows/inprogressshows/aHR0cHM6Ly8xOTIuMTY4LjEuMjE6MzI0MDAvbGlicmFyeS9zZWN0aW9ucy8yL3wmWC1QbGV4LVRva2VuPXVRY3lZcUJjbVo1dUZWRmlXQjIz
20:29:07 T:6131511296 DEBUG: CurlFile::Open(0x16d775570) https://192.168.1.21:32400/library/sections/2/onDeck
20:29:07 T:6131511296 INFO: easy_aquire - Created session to https://192.168.1.21
20:29:07 T:6131511296 DEBUG: CPlexDirectory::GetDirectory' client(Nassone), found 10 shows
20:29:08 T:6130937856 DEBUG: webserver: request received for /jsonrpc?Player.GetActivePlayers
20:29:10 T:6128119808 DEBUG: Previous line repeats 2 times.
20:29:10 T:6128119808 DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
20:29:10 T:6128119808 DEBUG: ------ Window Deinit (MyVideoNav.xml) ------
20:29:10 T:6128119808 DEBUG: CGUIWindowManager::PreviousWindow: Activate new
20:29:10 T:6128119808 DEBUG: ------ Window Init (Home.xml) ------
20:29:10 T:6140588032 DEBUG: CHomeShelfJob::UpdateMusic() - Running HomeShelf screen update
20:29:10 T:6140588032 DEBUG: CHomeShelfJob::UpdateVideos() - Running HomeShelf screen update
20:29:10 T:6140588032 DEBUG: CurlFile::Open(0x16e01cad0) https://192.168.1.21:32400/library/sections/2/onDeck
20:29:11 T:6140588032 DEBUG: CurlFile::Open(0x16e01cad0) https://192.168.1.21:32400/library/sections/1/onDeck
20:29:11 T:6140588032 DEBUG: CurlFile::Open(0x16e01cac0) https://192.168.1.21:32400/library/sections/2/recentlyAdded?unwatched=1
20:29:11 T:6130937856 DEBUG: webserver: request received for /jsonrpc?Player.GetActivePlayers
20:29:11 T:6140588032 DEBUG: CurlFile::Open(0x16e01cac0) https://192.168.1.21:32400/library/sections/1/recentlyAdded?unwatched=1
20:29:11 T:6131511296 DEBUG: CHomeShelfJob::UpdateTotal() - Running HomeShelf home screen update
20:29:11 T:6131511296 DEBUG: CurlFile::Open(0x16d775e00) https://192.168.1.21:32400/library/sections/1/all?type=1&unwatched=1
20:29:11 T:6131511296 DEBUG: CurlFile::Open(0x16d775e00) https://192.168.1.21:32400/library/sections/2/all?type=4&unwatched=1
20:29:11 T:6131511296 DEBUG: CurlFile::Open(0x16d775e00) https://192.168.1.21:32400/library/sections/2/all?type=2
20:29:11 T:6131511296 DEBUG: CurlFile::Open(0x16d775e00) https://192.168.1.21:32400/library/sections/2/all?type=2&unwatched=1
20:29:11 T:6131511296 DEBUG: CHomeShelfJob::UpdateTotal() - Finished
20:29:12 T:6130937856 DEBUG: webserver: request received for /jsonrpc?Player.GetActivePlayers
20:29:20 T:6130937856 DEBUG: Previous line repeats 7 times.
20:29:20 T:6130937856 DEBUG: webserver: request received for /
20:29:20 T:6143881216 DEBUG: webserver: request received for /css/core.css?1.3.57
20:29:20 T:6141685760 DEBUG: webserver: request received for /css/ipad.css?1.0.5
20:29:20 T:6142783488 DEBUG: webserver: request received for /js/xbmc.launcher.js?v=2.1.0
20:29:20 T:6141685760 DEBUG: webserver: request received for /js/json2.js?2.1.0
20:29:20 T:6142783488 DEBUG: webserver: request received for /js/jquery-1.8.2.min.js?2.1.0
20:29:20 T:6143881216 DEBUG: webserver: request received for /js/xbmc.core.js?2.1.0
20:29:20 T:6130937856 DEBUG: webserver: request received for /js/iscroll-min.js?2.1.0
20:29:20 T:6141685760 DEBUG: webserver: request received for /js/MediaLibrary.js?2.1.0
20:29:20 T:6142783488 DEBUG: webserver: request received for /js/NowPlayingManager.js?2.1.0
20:29:20 T:6143881216 DEBUG: webserver: request received for /js/xbmc.init.js?2.1.0
20:29:20 T:6141685760 DEBUG: webserver: request received for /js/xbmc.rpc.js?2.1.0
20:29:20 T:6142783488 DEBUG: webserver: request received for /css/core.css?1.3.57
20:29:20 T:6130937856 DEBUG: webserver: request received for /css/ipad.css?1.0.5
20:29:20 T:6143881216 DEBUG: webserver: request received for /js/xbmc.launcher.js?v=2.1.0
20:29:20 T:6130937856 DEBUG: webserver: request received for /js/jquery-1.8.2.min.js?2.1.0
20:29:20 T:6143881216 DEBUG: webserver: request received for /js/json2.js?2.1.0
20:29:20 T:6141685760 DEBUG: webserver: request received for /js/iscroll-min.js?2.1.0
20:29:20 T:6142783488 DEBUG: webserver: request received for /js/xbmc.core.js?2.1.0
20:29:20 T:6143881216 DEBUG: webserver: request received for /js/xbmc.rpc.js?2.1.0
20:29:20 T:6130937856 DEBUG: webserver: request received for /js/MediaLibrary.js?2.1.0
20:29:20 T:6141685760 DEBUG: webserver: request received for /js/NowPlayingManager.js?2.1.0
20:29:20 T:6142783488 DEBUG: webserver: request received for /js/xbmc.init.js?2.1.0
20:29:20 T:6130937856 DEBUG: webserver: request received for /jsonrpc?Playlist.GetPlaylists
20:29:20 T:6143881216 DEBUG: webserver: request received for /jsonrpc?Player.GetActivePlayers
20:29:22 T:6130937856 DEBUG: Previous line repeats 2 times.
20:29:22 T:6130937856 DEBUG: webserver: request received for /jsonrpc?System.IsLite
20:29:22 T:6130937856 DEBUG: webserver: request received for /vfs%2Fspecial%3A%2F%2Flogs%2Fmrmc.log?1519327762366
(180222.1734 @20180222-4462bdb)
core: add zoom, stretch, non-linear stretch, vertical shift and pixel ratio to CDVDVideoCodecAVFoundation
core: change thumbs to not use file caching, fix possible format errors
core: changed rapidjson to use iterative instead of reentrant parsing to avoid stack overflows
core: remove stack doubling for tvOS, stack overflow vanished with move to rapidjason
core: add show OSD Settings on swipe down if playing fullscreen video
core: more fixes, tvOS UIView/Alpha using AVSampleBufferDisplayLayer
Testing via iOS/Android Kodi remote and others please. We would like to make sure the stack overflow crash involving json from long ago was resolved.
CDVDVideoCodecAVFoundation now supports zoom, stretch, non-linear stretch, vertical shift and pixel ratio changes.
"show OSD Settings on swipe down if playing fullscreen video", by request.
Nice. AVF levels are good and I like the swipe down to bring up OSD.davilla wrote: 22 Feb 2018, 20:05 (180222.1734 @20180222-4462bdb)
The thumbs fix - is that for the scrubber or the posters of files?
Files, We are trying to track down issues with thumbnail generation and caching. Had a email report of no thumbs getting generated yet, it works for us when we nuke and test.
I actually had something happen yesterday where MrMC acted like it had lost all cache. It took several seconds to update info from my dvblink dvr (usually it's like 2 seconds) and I had to wait a bit for thumbnails to regenerate and show up on in progress and recently added.davilla wrote: 22 Feb 2018, 20:22 Files, We are trying to track down issues with thumbnail generation and caching. Had a email report of no thumbs getting generated yet, it works for us when we nuke and test.
- timstephens24
I'd like for the Harmony remote down button to do this too and not jump back/chapter back. The add for the Siri remote is good, but I normally use the Harmony and it's still too many annoying steps to enable subtitles (even though I shouldn't have to, but viewtopic.php?f=15&t=1556 still isn't fixed).davilla wrote: 22 Feb 2018, 20:05 core: add show OSD Settings on swipe down if playing fullscreen video
What's recommended, AVFoundation or VideoToolBox?davilla wrote: 22 Feb 2018, 16:30 Turn off VideoToolBox decoder and use AVFoundation for both h264 and h265. AVFoundation will show the above 235, VideoToolBox will not.
You can do this with a custom keymap, in <FullscreenVideo> section, replace "ChapterOrBigStepBack" with "OSDSettings"timstephens24 wrote: 23 Feb 2018, 01:13 I'd like for the Harmony remote down button to do this too and not jump back/chapter back. The add for the Siri remote is good, but I normally use the Harmony and it's still too many annoying steps to enable subtitles (even though I shouldn't have to, but viewtopic.php?f=15&t=1556 still isn't fixed).
Default Settings
