testing MrMC 3.0.4
Ted377
Re: testing MrMC 3.0.4
Post by Ted377 »
Movies and Series are no longer displayed.
Plex is active and the folders are not hidden in the settings.
Before the update everything was in order.
Post by cosmoxl »
All looks great for me.
jellyfish test files work again, though even the 3mbit/s HEVC stutters. I'll just have to rely on plex transcoding for HEVC on the ATV4.
I don't see any problem with plex libraries showing.
Post by timstephens24 »
My Plex libraries are showing, and OH EM GEE I can flatten TV shows again. A++++
vinomarky
Post by vinomarky »
WIth libdsm enabled, GoPro videos still played pretty ordinary. The longer video exmaple (with the boy jumping on the rocks) showing noticebable stutter after ~20 seconds of play, and after ~30 seconds of play losing audio - I've also tried with and without ipv6 disabled - no change
Turning libdsm off and it played much much better - it did however still start some stuttering right toward the end (55 second mark)
vinomarky wrote: 10 May 2017, 09:08 WIth libdsm enabled, GoPro videos still played pretty ordinary. The longer video exmaple (with the boy jumping on the rocks) showing noticebable stutter after ~20 seconds of play, and after ~30 seconds of play losing audio - I've also tried with and without ipv6 disabled - no change
humm, all played perfect here, with and without filecaching (200MBs) enabled for all filesystems. There is no startup delay like before.
vinomarky
Post by vinomarky »
No startup delay here either - that appears to be good :-)
wired or wifi (802.11ac) ?
By the way, the issue is the GoPro SOS stream. The presence of these indicate a possible corrupted video :) At least that's what google says.
Ted377
Post by Ted377 »
Ted377 wrote: 09 May 2017, 18:25 Movies and Series are no longer displayed.
I found the mistake. It was not MrMC, but Plex himself. The moment I did the update of MrMC, the Plex server crashed. So all good 😊
bgraversen
Post by bgraversen »
I did some quick testing last night on a few items that I'm focused on.
Tests are done using plex client
1. Resuming a movie after a full stop: Direct Play doesn't resume with same issues in 3.0.3(I don't think davilla has done anything to fix this yet so this is expected) Transcode is hit or miss (failed once and worked once - I believe this suffers from similar problems as direct play but it works a little better since plex is repackaging I think)
2. Buffer is not filling as expected on transcode: This one is harder to diagnose as I've upgraded my internet speeds now. I'll play with my QOS settings on my router to see if I can see how the buffer is filling but my expectation is there hasn't been a fix for this either yet.
I'll hold tight for now. Davilla, let me know if you need any additional logs and I'll pull them together and add a pastebin link.
@bgraversen, can you verify plex playback via a web browser ?
