thanks!!cosmoxl wrote: 19 Sep 2019, 01:44long click brings up menu now and after a reboot it was in dark mode as it should be. thanks.davilla wrote: 19 Sep 2019, 01:37 3.9.2 (190918.2335)
emby: “fix” filter options
tvos: remove Favourites keymap from home, we need long hold to work for homeshelf items
tvos: set dark mode on startup, tvos 13 is handling it differently somehow
tvos: we had dark mode since version 10
Testing MrMC 3.9.2 - Apple TV
Re: Testing MrMC 3.9.2 - Apple TV
- Montoya
Confirmed fixed here:Montoya wrote: 18 Sep 2019, 17:49Problem still exits in current TF, just like it did in 3.9.0 TF and stable etc.Montoya wrote: 08 Sep 2019, 21:31Latest stable and beta Emby servers combined with this viewtopic.php?f=23&t=4708. Just flick the requested switch mentioned in topic, to see what is wrong in UI workflow, browsing Emby libraries.davilla wrote: 08 Sep 2019, 21:02 I would have to understand the exact problem, "Emby nodes" means nothing to me, they are all 'nodes' in one form or fashon in code:)
While it took almost 5 months (last save update of my main Emby server) to get most of Emby compatibility back again in MrMC, I say thank you. Now I can finally update that Emby server safely, to latest Emby stable/beta, knowing that 3.9.2 is ready for it, how me and my family use MrMC with Emby.
jpalenz77
LiveTV is broken again.
Works fine for me, anyone else see the issue? What is the problem with it?
live tv seems fine to me.
- Montoya
That post is useless without stating the PVR in use...
DC1983
No problems here with live tvamet wrote:Works fine for me, anyone else see the issue? What is the problem with it?
Sent from my moto g(7) plus using Tapatalk
- Ted377
Live TV works great here.
FW: tvOS 17.4 ()
Front-End: MrMC 3.9.12 ()
Skin: Opacity
NAS: QNAP TS-431P3
Back-End: TVHeadend/PLEX
TUNER: Kathrein EXIP 418
FW: tvOS 17.4 ()
Skin: Opacity
NAS: QNAP TS-431P3
Fair warning to to those enrolled in testflight for appletv. We will be pruning the active list to those that had 3.9.2 installed. If you have only installed 3.9.0 or have never installed, you will be removed from the testflight list.
The Management
The Management
jabohn
I had 3.9.2 installed already but I got an email invitation yesterday to test 3.9.2. Of course, putting the code in didn't do anything except say I'm already enrolled.
