SUPERBIF wrote: 31 Oct 2018, 11:12
Hi I sent an email for testing 3.7.1. I sent one for Apple TV which was accepted and one for Shield which I haven't heard back from. Is that because it's only possible to test 1 device?
davilla wrote: 25 Oct 2018, 02:25
(181024.2339 @20181024-a83b6d5)
smb2: sync to upstream
smb2: add browse for server shares
smb2: hide “Windows network (SMB)” if smb2 is used
Does the sync to upstream relate to the audio delay bug on smb? (I'm unable to test this version at the moment, hence the question)
not necessarily, the sync was to pick up browsing for shares and update to their current code base.
When calling the section "TV-shows“ with initial setting "unwatched“ the appearance of the cover wall is as expected. But wrapping around from "unwatched“ to "watched“ or "all videos“ all other thumbnails but those of the "watched“ ones are disappered. You can only get them back through "exit“ and enter the TV shows again (initial setting "all videos“ or "watched“. I got screenshots, but dont’t know how to upload them.
This behavior is reproducable and new to v3.7.1. The appearance of the cover wall is correct under 3.7.0.
Set-Top-Box: Apple TV 4K FW: tvOS 16.2 Front-End: MrMC 3.9.12 (210507.625) . Skin: Ariana Database:MySQL NAS: QNAP TS-451+
There is a bug in scraping TV shows. Some new TV shows can’t get scraped at all (e. g. „The Typist“, theTVDB id=344465, IMDB=tt6879486). Here the TV show info is to be found, but none of the 5 episodes.
Another example is the show „4 Blocks“ (theTVDB id=324080, IMDB=5754602). Here I added some episodes of a new season. The new season couldn’t get scraped at all, so I decided to add the first episode (S02E01) by means of an OpenElec-environment, what worked without any problems (as well as for „The Typist“). But scraping episodes 2 - 4 doesn’t work either (see attachment). I got other shows with the same result.
I haven't had any serious troubles so far with the latest test flight
only one or two things the one is when i start video i have no audio for a second or less
the thing that you got if you set the refresh rate of a video at the start
(i have this option of always )
it is not bothering never the less i thought i have to mention it
also in some very new episode shows there is no scrape
and i have to press long the button and select the option play it from here to begin the show
also not bothering problem
I encountered the problem again when scraping TV Shows, the progress goes from 1 to 100 over and over several times before it completes. When I tried to capture the logs for it though, I wasn't able to replicate the problem.
(181104.2129 @20181104-0678384)
sync: upstream, Fix crash on exit when checking of libgpg-error lock object size.
sync metadata.common.imdb.com to 3.1.3
sync metadata.tvdb.com to 2.0.16
core: fixed qualifier for eac3 max bitrate
