mediainfo on those problematic hevc's would be helpful.Everbrave wrote: 06 May 2017, 17:55 I tried several hevc media; still stuttering; lip-sync issues without transcoding. With transcoding, smooth video but frequent lip-sync problems. So, still the only way to play hevc correctly on ATV4 is Plex.
testing MrMC 3.0.4
Re: testing MrMC 3.0.4
- Everbrave
I use VLC to get the media info; is there another way from MrMC directly?davilla wrote: 06 May 2017, 19:03mediainfo on those problematic hevc's would be helpful.Everbrave wrote: 06 May 2017, 17:55 I tried several hevc media; still stuttering; lip-sync issues without transcoding. With transcoding, smooth video but frequent lip-sync problems. So, still the only way to play hevc correctly on ATV4 is Plex.
Re HEVC on the ATV4...
The HEVC files I have stutter still. It could be because they are all 10bit. Unfortunately for testing purposes I recently got rid of 2 HEVC encodes that were not 10 bit.
So, I downloaded some test files from jellyfish, 3mbit/s main and main10. Unfortunately, I couldn't get them to play. I think because there's no audio track they just sit on the first frame or something.
https://pastebin.com/SsUTKCgi
edit: version of MrMC on Shield plays the jellyfish files just fine, with AMC or ff-hevc. Downloaded the h264 3mbit/s file and it also does NOT play on the ATV4, even with VTB. So, it's the new ffmpeg demuxer or something that gets hung up with no audio in the mkv.
see -> https://mediaarea.net/en/MediaInfoEverbrave wrote: 07 May 2017, 10:14I use VLC to get the media info; is there another way from MrMC directly?davilla wrote: 06 May 2017, 19:03mediainfo on those problematic hevc's would be helpful.Everbrave wrote: 06 May 2017, 17:55 I tried several hevc media; still stuttering; lip-sync issues without transcoding. With transcoding, smooth video but frequent lip-sync problems. So, still the only way to play hevc correctly on ATV4 is Plex.
- Everbrave
1) Guardians.of.the.Galaxy.2014.HDR.1080p.IMAX.HEVC.10bit.DTS-HD.MA.7.1; 22.4Mbps; 23.976 FPS (this is a tough one!)
2) Batman Returns 1992 1080p BluRay x265 HEVC 10bit AAC 5.1; 994Kbps; 23.976 FPS (easier; playable but with clear stutter)
EDIT: pls check ABC Player for ATV4 for comparison purposes.
- Everbrave
To be honest, I gave up on HEVC 10bit playback on ATV for now, with any player! MrMC 3.0.4 has definitely improved over previous versions in this regard and other players are struggling too, with more or less success, but the playback is just not smooth enough above 720p (or sometimes even 1080p at a low rate).cosmoxl wrote: 07 May 2017, 12:49 Re HEVC on the ATV4...
Either Apple makes the API for HW acceleration publicly accessible (I wonder why not?) or the next ATV generation with A9 or A10 will solve the problem.
And third time is the charmvinomarky wrote: 04 May 2017, 09:45 It was the default 20MB buffer size, and buffer all internet
Changed to all files and 200MB, and strangely there seemed to be an even longer startup for playing (but frozen seeing all the files in the directory and the video thumbnail) and the playback was definitley less smooth
Updated to 170503.1539, and enabled debug logging
Same behaviour with 200mb and áll files'caching - long startup and GoPro video stuttering
Changed back to 20mb and internet files caching - Video startup still took a while but this time the first video frame was immediately fullscreen (frozen), and playback was again choppy after about 15 seconds of play time
The longer sample I've been using can be grabbed here;
https://dl.dropboxusercontent.com/u/472 ... r_test.MP4 (356mb)
vinomarky
Nice - look forward to testing
I figured your silence on what I wrote above meant you were busy coding to fix. Thanks!davilla wrote: 09 May 2017, 02:25And third time is the charmvinomarky wrote: 04 May 2017, 09:45 It was the default 20MB buffer size, and buffer all internet
https://dl.dropboxusercontent.com/u/472 ... r_test.MP4 (356mb)Finally tracked down the real issue. A three line fix. I've reverted the previous 'fixes', they were causing issues with other areas. All three samples (including the longer sample) now play perfectly, without any startup delays.
new version pushed up to the usual suspects.
