Hi can anyone help with this? It's when playing live tv it takes 4-5 seconds to start playback which means in soccer matches i get notifications before it happens on screen.SUPERBIF wrote: 02 Jun 2018, 18:43Does the debuglog show anything?SUPERBIF wrote: 31 May 2018, 20:21Here is my debug log https://pastebin.com/GDrf97kXSUPERBIF wrote: 31 May 2018, 12:51
I will try to get a debuglog asap. It's difficult to see if it's only TestFlight related, since I'm only using testflight versions.
I'll check SPMC version tonight. Am I the only one facing this problem? If so it must be something in my setup.
In Ariana when I tried to login to Plex service a short while ago the login fields was on top of the screen. Will try again after newest update.
Again thanks for the great work you guys have been doing.
SUPERBIF
Re: Testing MrMC 3.7.0
- koying
Then be aware that it only works under VTB, currently.azriel84 wrote: Apple TV 4K.
- koying
I suspect this is just normal buffering.SUPERBIF wrote: Hi can anyone help with this? It's when playing live tv it takes 4-5 seconds to start playback which means in soccer matches i get notifications before it happens on screen.
On a semi-related subject, I remember a post somewhere for last world cup on how different channels have different "latency" vs. real-time, so the best approach is probably to disable your phone notifications, anyway
- logan_x50
- pecinko
A football that is played with a round ball
- pecinko
All suggestions are being read and considered. Not all are accepted and if accepted, they need time to get implemented. Audio sync is ready for next TFlight.cosmoxl wrote: 04 Jun 2018, 22:36 1) Can there be a setting (like Opacity) to where clicking on the TV button on the home screen takes me straight to the guide instead of the lists of channels?
2) The rows and columns in the guide could be smaller IMO, making room for more info on the screen at any one time. Also, the first column with names of channels is quite wide. Perhaps there is reason for that with other uses? For me it's just wasted space. So, just a thought.
Also, when going in to adjust audio sync is it possible to have the delay/forward OSD on top with nothing covering the video playing? I can't see lips to sync the audio as it is.
Bump for the above stuff as I got no feedback on the requests or suggestions.
I also tested the problem with skipping forward/backward I posted about above in Ariana and MrMC skins. Also not working. And with Ariana there's no OSD besides the scrub bar so I also can't ff or rw. So, not skin problem. ff or rw working as it should in MrMC skin.
I need more info about FW/RW problem. Can't you FW/RW with scrub bar?
jpalenz77
azriel84
Ah there's the problem, I use only AVF. Are you going to support ambilight with AVF in a future release?
