- Ted377
Is "Recently Added" meant with swipe left? I do not know how to put it another way.
FW: tvOS 17.4 ()
Front-End: MrMC 3.9.12 ()
Skin: Opacity
NAS: QNAP TS-431P3
Back-End: TVHeadend/PLEX
TUNER: Kathrein EXIP 418
FW: tvOS 17.4 ()
Skin: Opacity
NAS: QNAP TS-431P3
sort order : ie date added.Ted377 wrote: 01 Jul 2019, 14:30 Is "Recently Added" meant with swipe left? I do not know how to put it another way.
- Ted377
Ah… okay
FW: tvOS 17.4 ()
Skin: Opacity
NAS: QNAP TS-431P3
FW: tvOS 17.4 ()
Skin: Opacity
NAS: QNAP TS-431P3
- Waltman
MrMC 3.9.0 (190630.2346)
A part of the Alphabetic A...Z slider box is visible on the right is visible in the latest TestFlight. I mean that its does not fully slide to the right into invisibility when not used, but a part is still visible even when it should not be visible. Am I making sense ?
UPDATE: i calibrated the screen, I think this one is solved.
SETTOP-BOX :Apple TV 4K
Skin: Ariana
Database: MySQL
NAS: Synolgy DS1513+
TV: LG55OLEDC8
Skin: Ariana
Database: MySQL
TV: LG55OLEDC8
diamonddog
It looks like E-ARC Atmos is not working in the tvOS 13 beta 3 (It didn't in previous betas 1 & 2 as well). When I play the file it just wouldn't load/play at all unless I turn off ATMOS in Apple TV settings.
debuglogdiamonddog wrote: 03 Jul 2019, 16:43 It looks like E-ARC Atmos is not working in the tvOS 13 beta 3 (It didn't in previous betas 1 & 2 as well). When I play the file it just wouldn't load/play at all unless I turn off ATMOS in Apple TV settings.
diamonddog
There were complaints about plex sort order missing 'date added' and sorting wrong.
Have these issues been fixed ?
diamonddog
I am not aware of those. I don’t use Plex though.
That exact file plays fine under tvOS 12.3. eac3/Atmos passes through to receiver without issue.diamonddog wrote: 03 Jul 2019, 16:43 It looks like E-ARC Atmos is not working in the tvOS 13 beta 3 (It didn't in previous betas 1 & 2 as well). When I play the file it just wouldn't load/play at all unless I turn off ATMOS in Apple TV settings.
1) Apple beta's break things all the time, one reason why I generally ignore them (beta's).
2) Once installed on an AppleTV4K, there is no way to get back to a release version.
3) Have to run a beta XCode version to get compile/debug and you can't submit for the Apple store if built from an XCode beta.
^^ three counts against beta's
