It was/is enabled I assume, amet. The slider is on the right (in Amber).
EDIT:
It is enabled. Sorry for confusion. Was switching between the skins Amber and Opacity.
[CLOSED] Testing MrMC 3.7.1
- Ted377
Re: Testing MrMC 3.7.1
Okay, the "m" in pm3hd is there
FW: tvOS 17.4 ()
Front-End: MrMC 3.9.12 ()
Skin: Opacity
NAS: QNAP TS-431P3
Back-End: TVHeadend/PLEX
TUNER: Kathrein EXIP 418
FW: tvOS 17.4 ()
Skin: Opacity
NAS: QNAP TS-431P3
- Montoya
No issues found concerning multiple MrMC profile use. Switching between my 6 MrMC profiles with DVBLink, TVMosaic, Emby, Plex etc, working as expected.
Only issues I have is touchpad handling in PVR mode when using the touchpad remote concerning skip FW/BW. Using my Harmony Elite now mainly for some time already to bypass sensitivity of the touchpad, because skip FW/BW often causes to switch channel when watching Live TV or big jump FW/BW when watching a PVR recording.
This issue is present for a long time already (3.7.0 TF) and not just in latest TestFlights 3.7.1.
barong
Big thanks for whoever was responsible for adding in the Codec Info option to the OSD.
Not sure when it was added but just noticed it now
So far so good on current TestFlight version.
barong
Noticed a tiny bug...
AppleTV 4K TVOS12
Ariana skin, when pausing playback near start of movie, “scrubber” preview thumbnail covers the current time.
Proposed solution, bring clock text to front of screen or raise thumbnail to above the clock text line.
AppleTV 4K TVOS12
- logan_x50
"fix slow thumb/cover updates when entering dir"
I see a huge improvement guys in the speed of thumbnail generation. thank you
mats_o
redid the folder tests from viewtopic.php?f=6&t=4395
It's seems to be faster than 3.7.0 but it's still way slower than 3.6.2 or Kodi 17.6 on the same HW and library
jabohn
I was removed from the Testflight but I think I am having a couple minor issues with 3.7 so I sent a request email to be let back in.
Since 3.7 it seems that updating my library takes a lot longer than it used to. A few times I've watched the progress go from 1-100 and then it seems to start over and go 1-100 again several times. It used to be so quick, like 5-10 seconds, but now it can be over a minute long. (SMB share to my iMac running macOS Mojave and MySQL library)
There's also the problem I'm having with my library disappearing, which I'm keeping my eye on, mentioned in this thread:
https://forum.mrmc.tv/viewtopic.php?f=6&t=4438
I can test and post the logs once back in the Testflight.
- timstephens24
No issues since.davilla wrote: 27 Oct 2018, 15:05Revert "core: disable plex transcode serializer for thumb/image caching"
SUPERBIF
Hi I sent an email for testing 3.7.1. I sent one for Apple TV which was accepted and one for Shield which I haven't heard back from. Is that because it's only possible to test 1 device?
