obb file is up.
Testing MrMC 3.5.1
Re: Testing MrMC 3.5.1
No can do right now. Let me know if you still need it in a few hours.
Itzme1234
Cosmetic issue. On the Plex add-on, say your on Movie detail page, cast member,and click Menu, that’s just one scenario that brings up that overlay bar at he top (with the home and search icon on it).
That bar is ugly. It also has some text above those 2 icons that are cut off on my 59 inch plasma. It also makes me think Im focused on the orange home symbol, ready to click menu, but I’m not. So 3 issues there
jabohn
It now defaults to TV Shows which seems more logical to me. Thanks!davilla wrote: 24 Mar 2018, 14:00 As for default selection was changed to Media Sources, could be we screwed something up when adding the home 'Plex' entry. On the list.
tredman
Just got 3.5.1 on the shield and on my OnePlus5T. In both cases it crashes on first start and if you then go back to to it it's just a back screen (actually seems to get slightly lighter at bottom - see attached screen shot).
Any ideas? The Op5T is a complete new install, so I don't think it's any old setup.
gpmc01
Same also for me on my Shield with 3.5.1.
I removed the app and installed it back but no fix. App crashes immediately or black screen.
Waiting for official fix.
Nethead
just found a display(function?) bug
AppleTV 4k / tvOS / latest Testflight MRMC release
adding a source / video / browse / add net location / browse
see the following:
see the following:
if you try a different skin? same issue?
- timstephens24
Tried out the iPad version and the Plex addon is not very great on a touch screen (you called it @davilla lol). Scrolling the main screen is difficult, as it seems it doesn't exist and it just goes to where you touch. Scrolling the movies and tv section seems to actually work as gesture scrolling. The posters are truncated, so for example the poster for Anchorman shows "nchorma"
I also have no idea how to get back to the default Opacity screen when in the Plex addon.
Edit: seems the touch areas in the Plex addon settings overlap or are off. I have to touch a little above where I feel I should be touching to change settings.
Nethead
changed from default skin to MRMC skin (reminds me of Kodi) and no display issue.
