Testflight status
MarkusSwe
Re: Testflight status
Great! keep up the good work!
tron319
Well done and congrats for getting over at least some of the hurdles from your op.
see OP for current status
Odok76
Sweet!!!!
Will be checking my inbox shortly then!
Well done Davila, let's see them puppies
matthijst
Thanks, just got the redemption code
First impressions:
- Wow, list view
- file deletion is possible, great!
- seems to play the first view files I tried and it starts playing right away (unlike other apps that seem to buffer for 10 seconds or so).
- the ATV4 remote is not the easiest to use when scrolling (keep selecting the menu on the left when I try to scroll through a large file list, maybe it's me though). Have an old ATV2 remote laying around somewhere, think that will go better.
- would be nice to be able to configure the menu button, so a single tap means "back" and double tap means "go to the start menu".
- not sure if there are configurable buttons/taps under the touchpad (like a cursor). Would be cool to be able to press Left, right, up, down on the touchpad.
First impressions:
- Wow, list view
I find the silver atv remote works best for me, my fingers are too fat and seem to always go sideways
That and the cats walk over the touch pad and zip we are off fast forward'ing.
Amet on the other hand, loves the new remote.
neg0shEAte
i was fourth to join and no codes for me hmmmm
clairebear
non of my upnp servers are showing http://imgur.com/O2D7qBN
I can't for the life of me get the stalker plugin to work with the same settings as i have in my amazon fire tv on kodi I think because the two stalker versions are different.
Also having trouble connecting to my smb cant get past this even entering manual ip address in.
http://imgur.com/bbbHXn9
Right now the only thing I can do is access movies on my ftp server thats the only thing seem to work for me and they do play straight away with no fuss and buffering.
tron319
Well done!! Hope you get some good feedback from the beta testers and if you do need more, are able to call on those of here that are just as excited.davilla wrote:see OP for current status
Cheers
What smb server, flavor ? which smb in MrMC, there are two, direct and below that, zeroconfig.clairebear wrote:non of my upnp servers are showing http://imgur.com/O2D7qBN
