.1. No user installed addons are supported, python or otherwise.
Testing MrMC 3.6.1
brians
Re: Testing MrMC 3.6.1
I got email last night but it’s same version 2042 that Ialready had installed.
Scoty43
I have also not get last update.
(180405.248 @20180404-f416b6e)
[droid;amc] Dynamic surface view instances
[droid] MediaSession handling (Now Playing)
[droid] handle HDMI on/off broadcast
[droid;keys] Channels to Paging
[droid] Allow to downgrade resolution
[droid] rendercapture for Surface
[droid] switch to clang & libc++
backport: variable large audio sync error
backport: demuxer, unknown streams may become valid later
changed, darwin iOS/tvOS. Drop double buffer add in totalLatency and increase audio buffer size
skin.opacity: bigger posters
sync blackglassnova to upstream
add network drives to profile settings window, users were unable to set thumbs for profiles items
Remove 1080p limitation on images and fanarts size
you get it when pushed out. the above post is a hint that it has been pushed out.
jaas66
I thought change of TVMosaic / DVBLink PVR addon would be included?
https://mrmc.tv/forum/viewtopic.php?f=11&t=3922
crap, oversight. was testing under osx and forgot to rebuild binary pvrs for tvOS.jaas66 wrote: 05 Apr 2018, 14:43 I thought change of TVMosaic / DVBLink PVR addon would be included?
- Montoya
Well, while you wait for next Testflight release, you can always use DVBLink Theater on the ATV for watching TV from your TVMosaic serverjaas66 wrote: 05 Apr 2018, 14:43 I thought change of TVMosaic / DVBLink PVR addon would be included?
Wait, how would one use the OSD to adjust sync??davilla wrote: 05 Apr 2018, 03:44 Heads up, the next TestFlight push will alter iOS/tvOS a/v sync. For me, I was running 150ms delay, now zero.
Do not use codec debug OSD to adjust a/v sync. Use test clips or actual video content.
Anyway, agree, the new testflight is better with regard to sync of 23.976 material. Perhaps even 0. Sometimes it seems a little delay is needed, then it seems to correct itself. Thanks!
