Dolby Vision
Grencola
Re: Dolby Vision
Post by Grencola »
sahara wrote: 26 Jun 2019, 21:42
2. Selected advanced options. Left the option to copy video as I couldn't move the slider in MacOS...
in Windows, when the slider is greyed out, you just click ok and then go right back into advanced options and the slider will move, it's a bug. might be the same on Mac?
Re: Dolby Vision
Morten1969 wrote: 27 Jun 2019, 13:59
davilla wrote: 27 Jun 2019, 11:20
Morten1969 wrote: 25 Jun 2019, 13:04 Another thing is subtitle on DV it Plays but is shown up in left corner
subtitle's are in the right place for me. Describe how you are doing subtitles.
When i rip a DV file you can rip with subtitels. This subtitels show in the lett corner on the screen
sample with subtitles please :)
Morten1969
Re: Dolby Vision
Post by Morten1969 »
I have know played With the ripping part and this is my discovery.
Some bluray have no problem With ripping at 40/50 mBits but som Movies will just freeze and not play.
If i set the max bitrate to 30 Mbits all Movies play and skip forward bacward With no problem.
Sound is ac3 or eac3 both work
Re: Dolby Vision
Morten1969 wrote: 27 Jun 2019, 15:14 I have know played With the ripping part and this is my discovery.
This direct or using plex client ?
Morten1969
Re: Dolby Vision
davilla wrote: 27 Jun 2019, 15:16
Using plex client. Have not tryed direct from nas
Morten1969
Re: Dolby Vision
Davilla I have just sent you a New log file
I have played the same video encoded With 30Mbits and it Plays fine
so i have taken same moevie and encoded With 40Mbits and it wil no play just freez and sound is ratling
Morten1969
Re: Dolby Vision
I have know tested the 40mbits rip from my nas and the problem is same as with plex. IT plays for few seconds and then freze 10 sekund before IT plays again in 2-3 second.
Grencola
Re: Dolby Vision
Post by Grencola »
Morten1969 wrote: 27 Jun 2019, 16:16 I have know tested the 40mbits rip from my nas and the problem is same as with plex. IT plays for few seconds and then freze 10 sekund before IT plays again in 2-3 second.
Can you try it from usb so there's no network involved?
Re: Dolby Vision
Grencola wrote: 27 Jun 2019, 18:05
No USB on AppleTV :)
Grencola
Re: Dolby Vision
Post by Grencola »
whoa so apparently there are already movies being ripped with this method and then remuxed into mkv with the hd audio track, like what I'm wanting to do with the .ts container as I didn't think mkv would work.
Escape Room 2019 2160p DolbyVision WEB-DL DTS-HD MA 5.1 H.265-BLUTONiUM"
> NOTE: The Dolby Vision in this release is not like UHD Blu-Ray Dolby Vision where the dynamic layer is separate. This is single layer DVHE (High Efficiency Video Coding with Dolby Vision). Most if not all Dolby Vision TV's will be able to playback in Dolby Vision. This is also why it is muxable to Matroska (MKV) therefore allowing HD Audio too.
anyone have one of these rips to test in MrMC? or do you wanna try mkvtoolnix on a single layer mp4? deselect the ac3 track and add in the hd-audio one instead? :) I can try when I get home later..
