Testing MrMC 3.5.1
jrcorwin
Re: Testing MrMC 3.5.1
Post by jrcorwin »
x64Man wrote: 20 Mar 2018, 15:54 I have audio passthrough issue, just noise, reduce loud sounds off, same issue in Infuse. Don't know if broke in tvOS 11.3 beta5, Apple has broke before.
I didn’t think we could use pass through via Apple TV with MrMc.
jrcorwin
Post by jrcorwin »
FYI - I am here with my tail between my legs. I have been extremely hard, unfairly so, on MrMc on another forum, but this new update is truly wonderful. My sincere apologies. Congratulations and good work.
Post by cosmoxl »
this is normal in the betas
Post by cosmoxl »
jrcorwin wrote: 20 Mar 2018, 16:18
you can, just not HD audio.
jrcorwin
Post by jrcorwin »
cosmoxl wrote: 20 Mar 2018, 16:25
So if I leave it off, will it be handled in the same fashion as it is in Infuse? All of my 4K content are 1:1 copies with HD Audio, so I just want to make sure I’m getting the best I can from them. Thanks.
Post by cosmoxl »
jrcorwin wrote: 20 Mar 2018, 16:29
Yep, leave passthrough off so it'll decode HD audio and output PCM.
jrcorwin
Post by jrcorwin »
cosmoxl wrote: 20 Mar 2018, 16:33
Thank you
yes, broke in tvOS 11.3
( 180320.1459 @20180320-d59314c)
core: fixed possible crash with tvOS focus engine, need locks to cross threads
fixed: search for plex for kodi
fixed: Use menu to stop video playback under expert mode
depends: libffi: fix arm assembler syntax
andrenb
Post by andrenb »
Plex for Kodi-addon works great in the beta, I haven't run into a single issue after testing this extensively the last day on my Apple TV 4K.
Will the Plex for Kodi-addon support streaming from my Plex-server when I'm on a remote network with my iPhone or iPad? If yes, I´ll have to buy the MrMC Touch for my iPhone and iPad! :D
