What do you mean? You should have access to all libraries on your account for our serveramet wrote: 17 May 2020, 03:11I can see it fails, but no idea why ... do I have access to it? can I get access to it?snodrog742 wrote: 16 May 2020, 21:50 Debuglog: BFEEN.log
Have tried loading Movies library 5 times and each time is blank. Ideas?
Testing MrMC 3.9.7 - Apple TV
snodrog742
Re: Testing MrMC 3.9.7 - Apple TV
libraries I have are on "Dark P**** -BC" you seem to have an issue accessing the "W***** - BC"
snodrog742
Oh, both are linked to same libraries. I can invite you to W**** if needed?amet wrote: 17 May 2020, 12:01 libraries I have are on "Dark P**** -BC" you seem to have an issue accessing the "W***** - BC"
Thats the one you have issues with? I cant see any problems on Dark ***snodrog742 wrote: 17 May 2020, 16:02Oh, both are linked to same libraries. I can invite you to W**** if needed?amet wrote: 17 May 2020, 12:01 libraries I have are on "Dark P**** -BC" you seem to have an issue accessing the "W***** - BC"
snodrog742
Not sure as I usually just use W**** with it having my watch history. I invited you to it though.amet wrote: 17 May 2020, 16:06Thats the one you have issues with? I cant see any problems on Dark ***snodrog742 wrote: 17 May 2020, 16:02Oh, both are linked to same libraries. I can invite you to W**** if needed?amet wrote: 17 May 2020, 12:01 libraries I have are on "Dark P**** -BC" you seem to have an issue accessing the "W***** - BC"
ok, got it.... so.. this is a difficult problem that will take a major rework in the core.snodrog742 wrote: 17 May 2020, 16:12Not sure as I usually just use W**** with it having my watch history. I invited you to it though.amet wrote: 17 May 2020, 16:06Thats the one you have issues with? I cant see any problems on Dark ***snodrog742 wrote: 17 May 2020, 16:02
Oh, both are linked to same libraries. I can invite you to W**** if needed?![]()
whats happening now is that your server takes around 40 seconds to return all the items in movie section, there is > 7700 movies in there and the info being collected and transferred is around 30mb.
we dont have the mechanism to do the fetch in segments and thats something thats going to take a lot of core changes to implement.
EDIT: one option to try is to increase connection timeout in Settings -> System -> Internet access and see if that would help
we have a fix for it, it will be in a next testflight.snodrog742 wrote: 17 May 2020, 16:12Not sure as I usually just use W**** with it having my watch history. I invited you to it though.amet wrote: 17 May 2020, 16:06Thats the one you have issues with? I cant see any problems on Dark ***snodrog742 wrote: 17 May 2020, 16:02
3.9.7 (200520.1037)
- emby/JF: limit the number of items collected to 1000 per server hit, server will take time and we will timeout
- services: rework reporting logic
- change episode label format to Sx:Exx
@snodrog742, please see if the latest TF fixes your issue with getting the movie section.. debuglog please if it doesnt
snodrog742
Movie section looked good but we're back to getting duplicate Trakt plays reported. Debuglog GTZ1L.log. This movie was paused a few times which I'm guessing didn't get relayed to Trakt properlyamet wrote: 20 May 2020, 12:48 3.9.7 (200520.1037)
snodrog742
