logan_x50
Re: Testing MrMC 3.7.0
Post by logan_x50 »
In Ariana Skin I noticed that top level collections don't show a poster i.e if you have a collection for "Indiana Jones" movies. the movies within the collection show posters. not a big deal but maybe one for the "to do" list?
Completely in love with this skin btw
Wall View does crash for me when scrolling, while list view just fine. i'll log an issue as it must be something in my set-up otherwise there would have been other reports by now
pecinko
Post by pecinko »
guibaa wrote: 10 May 2018, 07:20 What I noticed is the startup screen, when I scroll down to Music I don't see any cover images.
Fixed now, thanks.
pecinko
Post by pecinko »
logan_x50 wrote: 10 May 2018, 08:30 In Ariana Skin I noticed that top level collections don't show a poster i.e if you have a collection for "Indiana Jones" movies. the movies within the collection show posters. not a big deal but maybe one for the "to do" list?
How can i test this? I have made a few collections on PMS but I don't have a clue how to see/get to them in mrmc??
pecinko
Post by pecinko »
logan_x50 wrote: 10 May 2018, 08:30 Wall View does crash for me when scrolling, while list view just fine. i'll log an issue as it must be something in my set-up otherwise there would have been other reports by now
As a possible workaround try by-page-scrolling : in grid view, tap left when on left edge to go PageUp, tap/click right while in rightmost column to go pageDown.
That crash seems like mrmc problem, not a skin issue.
pauabaer
Post by pauabaer »
I have an subts search issue.. in the Ariane skin I cannot search for subtitles with opensibtitles.org. I can only search local within my defined sources.
I tried to download subs in Amber skin successfully.
logan_x50
Post by logan_x50 »
pecinko wrote: 10 May 2018, 14:49
Realised i'm using the wrong term. Its Movie "Sets". Enable by going to Settings>Video>Library>Group movies in sets
Everbrave
Post by Everbrave »
pecinko wrote: 10 May 2018, 14:52
In Opacity, the Movie Sets in MrMC (not Plex) work correctly, in Ariana,, once you select the movie set (even before clicking on it), all Movie thumbnails vanish (MrMC does not crash!) and you get a blank page. You still can return to the home page and see TV Shows, e.g., but the Movie thumbnails are gone. The only way to restore the situation is to force restart MrMC and disable Movie sets.
vlaves
Post by vlaves »
pecinko wrote: 10 May 2018, 06:57
Montoya wrote: 09 May 2018, 22:05 @Pecinko, Nice work on your skin, so thank you !
I'm missing the TV button on Home Screen for the installed PVR in MrMC. Is that work in progress ?
Thanks.
PVR? Maybe.. I don't have a working setup to test on and I'm not sure about needed effort to skin so many PVR windows.
@Davilla maybe it would be possible to add the PVR Demo Client at least to TestFlight so @pecinco can make the Skin files for the PVR section?
I guess this is essential in MrMC as on ATV MrMC is the only App doing proper yadif 2x deinterlacing on the ATV 4k and that Skin will give the right look on the ATV.
logan_x50
Post by logan_x50 »
Everbrave wrote: 11 May 2018, 09:15
Confirmed. Disabled "Group movies in sets" and Icon View in Ariana now works as expected (no blank page)
(180511.354 @20180510-1f63b63)
fixed crash if 2-byte/3-byte NALs are present, need to save a copy of extradata as it can be altered via bit stream converter
added, 2-byte to 4-byte NAL length if avcC detected
add System.HasExtensions , returns true if at least one Extension is enabled
revert "ADD: HDR->SDR via GLES shaders"
changed labeling from Services -> Libraries
revert information provider browser instead of addons and they are called extensions now
add HasContent(pictures) and HasContent(files)
depreciate LIBRARY_HASSERVICES skin bool , extend plex and emby services to return if they have movie, tvshow or music libraries
fixed, tvOS light/dark/automatic needs a plist enable
sync skin.ariana, skin opacity
