Re: Testing MrMC 3.7.0 - [Invites Closed]
(180822.331 @20180821-1078625)
chg: core, do not include access tokens for cache seeding as they can change
fix: core/plex/photo/transcode. The Plex Photo Transcoder is not serialized and will fail on multiple access if close to same time
fix: core: log message
fix: core: fixed ret to match type
fix: core: fixed wrong usage of URIUtils::PathStarts
fix: core: modernize crc32 usage
tst: plex: increase GetIdentity timeout - tryfix
Post by cosmoxl »
davilla wrote: 23 Aug 2018, 13:34 (180822.331 @20180821-1078625)
Away right now. Back at the house Friday night. Will test asap.
Forgot to mention, best remove existing thumbs to regain space on the device. Plex/Emby tokens are removed from the local file seed reference. That's so the login token can change and we retain the existing thumbs.
Montoya
Post by Montoya »
davilla wrote: 23 Aug 2018, 15:06 Forgot to mention, best remove existing thumbs to regain space on the device. Plex/Emby tokens are removed from the local file seed reference. That's so the login token can change and we retain the existing thumbs.
Could you specify, in which MrMC settings menu, I need to remove existing thumbs in MrMC as an Emby user ?
Perhaps Plex users are also wondering where to do that.
Montoya wrote: 23 Aug 2018, 16:05
settings -> appearance -> something :) not near a box right now.
Montoya
Post by Montoya »
davilla wrote: 23 Aug 2018, 16:49
Now I know why I couldn’t find it :)
The setting is called “Regenerate thumbnails” and found in Settings/Appearance/Cached Images.
(180824.56 @20180823-b5a73eb)
fix: tvos sink, handle ac3 5.0 channels
fix: add alternate 5.0(side) channel layout for dac-ac3 decoder
fix: opensubtitle, search for certain languages
Nethead
Post by Nethead »
running latest beta (released tonight)
is audio passthrough still a known issue on with Apple TVOS (issue residing with Apple, not MrMC)?
turning off passthrough in MrMC removes the wonderful static
the static is driving us crazy (lol)
Nethead wrote: 24 Aug 2018, 04:03 running latest beta (released tonight)
Passthrough on Apple TV 4/4K is gone until Apple restores it. There is zero we can do about it except wait and see if this ever happens.
Post by timstephens24 »
I haven't run into any issues yet with the new builds, looking good.
