HDR and SDR play back
mata77
Post by mata77 » 14 Dec 2017, 18:52
hi my english is no good so i will try my best, i just download MrMC Lite to try it before buy the full version, when i play HDR on my appletv from my plex server or SMB videos plays fine, but when i play SDR the dynamic range display rate dont switching so the video play as HDR and colors are wrong, i have frame match on in my apple tv, is this a problem or do i need the full version to dynamic range/display rate switching to work?
thanks in advanced
Re: HDR and SDR play back
Post by amet » 14 Dec 2017, 19:12
All sdr/hdr issues are fixed in 3.3.1, it should be out in the next few days
Post by davilla » 14 Dec 2017, 19:54
make sure avfoundation codec is enable and disable hevc/hdr under videotoolbox
make sure adjust display switch is enabled
settings -> video
you might need expert mode enabled.
mata77
Post by mata77 » 15 Dec 2017, 16:37
Yeah I try all that and still the same problem, and if I enable adjust display switch HDR Won't play at all, I guess I am going to wait for 3.31 patch
Thanks for you help
mata77
Post by mata77 » 18 Dec 2017, 19:17
HDR and SDR playback problem is fix whit the 3.3.1 patch, thanks
loekf2
Post by loekf2 » 12 Jan 2019, 22:13
14 Dec 2017, 19:54
settings -> video
@davilla:
Did you try this ?
https://www.makemkv.com/forum/viewtopic.php?t=18602
Using this tool you can mux MT2S with DV into a single stream MP4 container with DV metadata.
Tool is here:
https://github.com/DolbyLaboratories/dlb_mp4base
“The Dolby MP4 streaming muxer (dlb_mp4base) is a software implementation of a muxer of fragmented or unfragmented ISO base media file format (mp4). It supports muxing of Dolby Digital (AC-3), Dolby Digital Plus (E-AC-3), and Dolby AC-4 audio formats as well as Dolby Vision.”
On LG TVs this does the trick. So... on ATV with MrMC as well ?
AppleTV 4K 64GB, 2nd Apple TV 4 as Homekit hub, NVidia Shield ATV
loekf2
Post by loekf2 » 14 Jan 2019, 06:50
Interesting....
So with the Dolby tool you can:
- Convert a UHD DV "backup" to a single stream DV profile 5 MP4
and with x265 you could do the same, but perhaps adding the original Atmos/DTS:X track into a MKV again ? I don't know though if the latest x265 encoder has been merged into mencoder or ffmpeg (yet ?). Though maybe mkvmerge can do the trick as well.
I didn't try it yet, but are you sure MrMC can play the resulting file ? Is there any limitation for the container/file format ?
Post by davilla » 14 Jan 2019, 14:26
I'm not sure of anything yet :)
Busy working on eac3/atmos right now...
