Audio with 5.1
Re: Audio with 5.1
I will gladly try out ANY beta versions to see if the problem gets fixed, but how are you going to be accepted as a beta tester???
Re: Audio with 5.1
first you would need mac, then Apple Configurator and configuring profile for Beta versions... if you have Apple mac, mail me using support address and lets take it from there
EDIT: and of course, you would need USB -> USB-c cable
Re: Audio with 5.1
Thank you for replying... But I don't have a mac
Re: Audio with 5.1
lets see if anyone else with same issue can test, we are on it.. just timeline is unknown
Re: Audio with 5.1
Hi everyone,
I have issues with 5.1 sound. My AV is yamaha RX-V64ORDS and I'm testing tvOS 9.2 beta. I can't get 5.1 sound using passthrough.
@amet, I can test what ever you want.
Best regards
Best regards
Re: Audio with 5.1
mrmc.log with debug enabled and did this setup work under tvOS 9.1 ?erJotas wrote:Hi everyone,
Best regards
Re: Audio with 5.1
Ok, I don't know how or why but It's working now. I just set audio settings in the apple tv to 16 bits and then back to automatic, and it's working.
In the other hand, I have also a Cambridge SoundWorks DTT 3500, It has only an optical input so I connect the appletv4 to my TV LED 32" SAMSUNG D5500 and then with an optical cable to the SoundWorks, but I can't ear nothing, maybe It's a problem with the tv output... I don't know.
Do you still want the log file?
Re: Audio with 5.1
Nah, tvOS configure issueerJotas wrote:Ok, I don't know how or why but It's working now. I just set audio settings in the apple tv to 16 bits and then back to automatic, and it's working.
I think we can detect if that setting is wrong, and kick back to two channel, have to poke.
Re: Audio with 5.1
Ok! any idea about the other config? (samsung + cambridge soundworks)
Re: Audio with 5.1
not a clue, you might see if there are any settings on the samsung you can diddle.erJotas wrote:Ok! any idea about the other config? (samsung + cambridge soundworks)
