sound settings for Samsung ms650 soundbar
Bigio1988
Post by Bigio1988 » 22 Apr 2019, 17:34
Hi I use mrmc with Nvidia shield and with Samsung soundbar ms650 and I have a problem with all the videos. I've tried everything but the audio is slightly ahead of the video, and it's annoying. how can i solve? any corrections in the audio settings ?? I can publish my settings if you need them
Re: sound settings for Samsung ms650 soundbar
Post by davilla » 22 Apr 2019, 18:59
Bigio1988 wrote:
22 Apr 2019, 17:34
if the a/v/ offset is the same, apply a global offset.
Bigio1988
Post by Bigio1988 » 26 Apr 2019, 21:11
sorry I didn't understand. can you explain that to me? What option should I change?
Bigio1988
Post by Bigio1988 » 27 Apr 2019, 10:10
22 Apr 2019, 18:59
Bigio1988 wrote:
22 Apr 2019, 17:34
can you explain to me what I need to change?
Post by davilla » 27 Apr 2019, 16:29
bring up OSD, go to audio, in there is a/v offset. change it to align audio with video. Scroll down, apply settings to all
Bigio1988
Post by Bigio1988 » 27 Apr 2019, 23:11
27 Apr 2019, 16:29
Ok. ok. I got it. but another thing. If you go to settings> audio output there is an option called "threshold for pitch Correction". What does it mean? That I have to put them there?
Post by davilla » 28 Apr 2019, 11:58
Bigio1988 wrote:
27 Apr 2019, 23:11
27 Apr 2019, 16:29
"threshold for pitch Correction" has nothing to do with a/v sync. Leave it alone.
Bigio1988
Post by Bigio1988 » 01 May 2019, 11:49
Ok thanks
Bigio1988
Post by Bigio1988 » 04 May 2019, 07:39
28 Apr 2019, 11:58
Bigio1988 wrote:
27 Apr 2019, 23:11
27 Apr 2019, 16:29
threshold for pitch correction how should it be set? What number should be put?
Post by davilla » 04 May 2019, 17:17
Bigio1988 wrote:
04 May 2019, 07:39
28 Apr 2019, 11:58
Bigio1988 wrote:
27 Apr 2019, 23:11
The default value.
