tvOS 2.3.0 released
tvOS 2.3.0 released
Post by amet » 07 Jun 2016, 03:05
Below are changes from 2.2.0 to 2.3.0
  • + picture memory hog killed and made into bacon
    + expand webserver blacklist
    + check missing dateadded sort method in AudioLibrary.GetSongs
    + subtitle manual search
    + long hold should bring playlist
    + disappearing SeekBar on chapter skip and ff/rew
    + ignore passthrough setting if audio is not routed to HDMI
    + iOS/tvOS channel mapping for transcode to ac3
    + iOS/tvOS channel mapping for iOS/tvOS for 7.1 pcm
    + keep renderer and friends from stalling
    + fix audio for wmapro
    + fixed, cpu percent used. zero out sleeping cpus
    + skin.amber, fix in progress overlay
    + fixed, smb_fstat on a directory
    + fixed, do not decode eia_608 subtitles
    + fixed, tvOS with audio set to Digital Dolby 5.1, it expects sink to use dd 5.1 channel mapping
    + changed, MediaCodec cannot handle high@5.2, kick back to ffmpeg and pray
    + use passed frame time in callback for VideoSyncAndroid
    + skin.amber, fix overlapping label
    + init ffmpeg threads like LAVFilters does
    + exclude skin re-touched from non-touchscreen devices
Re: *** tvOS 2.3.0 released ***
Post by cosmoxl » 07 Jun 2016, 12:22
The testflight thread didn't mention anything about mediacodec and kickback to ffmpeg. Anything I should look for?
I have noticed that AVC (x264) playback will stutter when instantaneous bitrates reach about 32Mb/s as reported in the codec info.
I'll test out a file I have that I know taxes the CPU all the way (near 200% as reported in codec info)
Post by davilla » 07 Jun 2016, 13:40
"mediacodec and kickback to ffmpeg." is for amazon devices.
