Testing MrMC 3.3.0
Testing MrMC 3.3.0
Post by davilla » 20 Oct 2017, 23:22
How to request Testflight access: Send an email to support@mrmc.tv with the subject "I see dead people", include your email address tied to device, and which flavor (tvOS, iOS, Amazon or GooglePlay). Users that are already in testflight 3.2.0 are already in this series.
Released for iOS.
Released for tvOS.
Pending for Amazon.
Pending for GooglePlay.
(20171020-4c9a0a0)
home shelf action selector, follow the settings if user wants to see the item info, choose action or play
testing: re-enable PGS rescaling
(20171025-f7d5644)
darwin: exclude pps changes from restarting videotoolbox
(20171027-e73f9ec)
darwin: fixed crash in AVFoundation codec if CMVideoFormatDescriptionCreateFromH264ParameterSets fails
darwin: changed VideoToolBox decoder to exclude pps changes from triggering a vtb restart
darwin: changed AVFoundation decoder frame rate tracker to perfer dts over pts
player: changed, no need to hammer codec info at frame rates
removed: READ_MULTI_STREAM is silly, most content have more than two streams and READ_MULTI_STREAM only really works with two
player: silence codec skips if format is bypass, skip count > 0 is an artifact on some high frame rate content
darwin: fixed, a/v offset control for AVFoundation decoder
darwin: enable gles fence during video playback
player: fixed possible crash on stop
player: change min a/v offset from 0.25s to 0.05s
(20171101-d19d3bb)
cointoss: random stab at fixing codec info crankyness under AVFoundation codec
fixed use videotoolbox for hevc/hdr settings to match videotoolbox visability
darwin: refactor VideoToolBox parameter set handling
fixup: darwin: changed AVFoundation decoder frame rate tracker to perfer dts over pts
add “screensaver.xbmc.builtin.slideshow” , pick a folder and have images slideshow screensaver
webinterface: hide “now playing” if one of the logs is open, it covers log window
(20171101-d19d3bb)
bump pvr.mythtv to support 0.29 protocol
(20171101-d19d3bb)
pvr.mythtv missing symbol fix
(20171119-273ab06)
plex: add trailers
(20171125-b181361)
darwin: tvOS, add display rate switching
plex: fix trailers
(20171125-c4410a6)
darwin: tvOS, include dynamic range with display rate switching
(20171126-9b5c348)
fixed xcode build regarding app submittion
logan_x50
Re: Testing MrMC 3.3.0
Post by logan_x50 » 21 Oct 2017, 12:26
"(20171020-4c9a0a0)
home shelf action selector, follow the settings if user wants to see the item info, choose action or play"
Thank you guys
Itzme1234
Post by Itzme1234 » 21 Oct 2017, 13:34
Should I be seeing 3.3.0 in the tvOS TestFlight? I only have 3.2.0 from Oct 16.
Post by davilla » 21 Oct 2017, 13:56
It's still waiting for beta review, that's why it is marked ^^ pending.
Itzme1234
Post by Itzme1234 » 21 Oct 2017, 14:55
Thanks. I guess the changes Apple has made to the TVos TestFlight, having to dig into apps to look for Update or Open, is just adding overall confusion for me.
Post by timstephens24 » 21 Oct 2017, 15:09
You basically only know something is there when you get an email.
Post by davilla » 22 Oct 2017, 00:19
Should be out now.
Post by timstephens24 » 22 Oct 2017, 12:25
20 Oct 2017, 23:22
This works, glad it was added.
20 Oct 2017, 23:22
What are you looking for here?
Post by davilla » 22 Oct 2017, 14:15
timstephens24 wrote:
22 Oct 2017, 12:25
20 Oct 2017, 23:22
WIP, we raised the detection limits and restricted the rescaling to only r=g=b values. I guess we are looking to see if there are any side effects while we try to limit rescale to only hevc/hdr content.
Itzme1234
Post by Itzme1234 » 22 Oct 2017, 14:23
Home shelf... is this the "Limit Home Shelf to selected Plex servers"? If so, I want the home shelf to display the last server I was in, like before. How do I set that? Mixing content from 2 servers only confuses me.
Sometimes I'm in my local Plex Server and sometimes a friend's server.
Also for the future please clarify the term Home Shelf, is that always what we see Outside the MrMc? What's the term for area that we see when we enter the apps and simply have Movie or Tv highlighted ?
