Plex nodes show incorrect items
Any Opacity skin issues go here
whinette
Post by whinette » 07 Jul 2019, 18:00
Hello,
I wonder if there are still works done on this skin, but if it is:
The node of my plex servers are correctly filled, but they show incorrect content:
  • film type show all films
  • tv show type show all tv
But if I go left to get recently added / ongoing, then it is filtered correctly.
Another skin (Ariana) do it correctly, so I think it is possible.
Anyhow, I still go back to this skin after a while, it is simply the best mrmc offers.
Re: Plex nodes show incorrect items
Post by amet » 07 Jul 2019, 18:28
I dont follow :(
whinette wrote:
07 Jul 2019, 18:00
films show films, tv shows show tv shows?
whinette wrote:
07 Jul 2019, 18:00
if you have selected "Tvshows" and go into left hidden menu, hit Recently Added and it should show recently added episodes.
... seems ok here
whinette
Post by whinette » 07 Jul 2019, 19:36
Sorry, I will try to be more clear with my actual case:
I have many librairies, at least two of each plex type:
In Plex:
  • TV Show type
    • TV Show
    • Docu
    • Anime
  • Film type
    • Films
    • Animation
    • Court métrages
All these nodes are listed by the skin, but on the right (were the poster are) everything is mixed:
For all the "TV Show type" nodes, the posters for "recently added" and "in progress" display a mix of all the relevant plex libraries (or to be more clear, i have posters from docu + anime + tv show on all nodes that are from "tv show type". The posters are the same for all 3 nodes). Same for the "Film type" nodes.
But if I press left from this menu and select "recently added' or "in progress", then it is not mixed and only the item from the correct plex library are displayed.
tl;dr the menus from left action are correct, but the posters (that should feed from these) are incorrect (aggregate of tv plex library or film plex library)
Is it more comprehensible? :)
Post by amet » 08 Jul 2019, 04:54
Yes, I see what you mean...
Posters for recently added and more n progress are sent to us by plex server. If you open plex webui you will see that they are laid out in the same way.
whinette
Post by whinette » 08 Jul 2019, 21:41
I see ... got it.
Indeed, what is displayed are the items "Recently Added TV" and "Recently Added Movies" that aggregates everything.
I was confused as Aviana do it better (imho), with library/node filtering (what is accessible from left action in Opacity basically).
I am not sure what would be the impact on the skin though and how are it would be to use that. I could look into it (I am a python dev myself) if it is possible somehow.
Thanks for your time amet. :)
Post by amet » 09 Jul 2019, 10:20
Items shown on opacity and Ariana are exactly the same, Amber might have different as it aggregates it from all plex servers
whinette
Post by whinette » 17 Jul 2019, 20:46
I've checked back and you're correct, this is my bad.
