Update library broken Topic is solved
Waltman
Post by Waltman » 21 Nov 2018, 07:36
In the latest TestFlight - "MrMC 3.7.1 (181118.1838)" update library is broken in Ariana.
I tested in opacity and it was working there.
pecinko
Re: Update library broken
Post by pecinko » 21 Nov 2018, 10:15
What happens for you when you click update library in Ariana?
pecinko
Post by pecinko » 21 Nov 2018, 12:16
Waltman wrote:
21 Nov 2018, 07:36
I tested in opaciteit and it was working there.
Found it. Thanks for reporting!
