Trying to build MrMC for Android - Issues with making ffmpeg
Any issues that are NOT Nvidia Shield or FireTV specific
Ozymandyaz
Post by Ozymandyaz » 18 Jul 2018, 13:56
Trying to build MrMC for Android and having issues with making depends, specifically ffmpeg:
(common.mak:72: recipe for target 'libswscale/arm/rgb2yuv_neon_32.o' failed)
I am using an Ubuntu 16.04 VM, Java 8, GCC/G++ 4.9 and the current SDK/NDK from google
I am able to successfully build a Kodi 17.6 APK from source, and have been playing with lots of versions of java, GCC, the SDK/NDK etc, but seem to always get hung up in the same place for ffmpeg for MrMC.
I tried to use the versions outlined in the mrmc/android readme on Github but they seem a bit old and I wanted to make sure I was using the right versions.
Re: Trying to build MrMC for Android - Issues with making ffmpeg
Post by koying » 18 Jul 2018, 14:11
You'd need to show more than the single failed line for us to be able to assist.
Please provide:
- the depends configure line
- the config.log
- the full build log
Ozymandyaz
Post by Ozymandyaz » 18 Jul 2018, 15:32
My bad, figured i just screwed up the basic dependencies... logs and info bellow:
Depends Config line:
./configure \
--with-tarballs=$HOME/android-tools/mrmc-tarballs \
--host=arm-linux-androideabi \
--with-sdk-path=$HOME/android-tools/android-sdk-linux \
--with-ndk-path=$HOME/android-tools/android-ndk-r16b \
--with-toolchain=$HOME/android-tools/arm-linux-androideabi-4.9-vanilla/android-21 \
--prefix=$HOME/android-tools/mrmc-depends
Config log (did a ffmpeg distclean and then make in target/ffmpeg)
https://pastebin.com/KL21uQfq
Make log
https://pastebin.com/JE9qGFFR
