No HDMI Signal
badseed
No HDMI Signal
Post by badseed » 10 Aug 2019, 14:04
I have a problem since the last Sheild update were if I stop a playing file with pressing the back button on the remote I loose the HDMI signal on the TV?
Takes a few clicks to get back as I'm staring at a blank screen.
Here's the log
https://pastebin.com/WPtUeVRs
Re: No HDMI Signal
Post by cosmoxl » 10 Aug 2019, 15:09
I believe this is a bug with the new android P update.
badseed
Re: No HDMI Signal
Post by badseed » 10 Aug 2019, 16:11
Thought so as working perfectly before the update
supertoto1977
Re: No HDMI Signal
Post by supertoto1977 » 11 Aug 2019, 06:13
Hello,
Yes, it's one of the bug due to the new upgrade.
It happens when an app do some refresh rate changes (MrMc, Kodi or if you use the Refresh Rate Tool).
see this topic.
On the TV, i change via the remote control the HDMI Input and then go back to the shield to solve it.
I already had this bug in the 7.2 version.
And there's a worst bug, issue with audio passthrough. I had to remove it in MrMc to avoid any stutter, audio drop out and out of sync. So for the moment i use LPCM.
see this topic.
