Reproduction is not smooth
david86bcn
Post by david86bcn » 20 May 2019, 14:29
Hello, when I advance a few minutes a video from USB disk or local network (1080p and 4k) and I play it, sometimes the reproduction is not smooth (the sound is correct). So if I pause and play it again, the reproduction is correct.
It is normal?
Re: Reproduction is not smooth
Post by amet » 20 May 2019, 18:09
Doesn’t sound normal, maybe debuglog has some info
david86bcn
Post by david86bcn » 21 May 2019, 16:56
20 May 2019, 18:09
I tried to paste the log in pastebin but it says: "You have exceeded the maximum size of 512 kilobytes per paste."
So I had to upload it to my google drive. I have advanced the video several times and finally the reproduction has not been smooth. Do you see any failure in the log? Thank you.
https://drive.google.com/open?id=1JbM4G ... yXINaTJ_oa
david86bcn
Post by david86bcn » 22 May 2019, 19:42
20 May 2019, 18:09
Have you seen anything in the log?
david86bcn
Post by david86bcn » 23 May 2019, 09:58
It has also happened to me when I started a video, the image is not fluid, it has quite annoying stuttering until I paused the video and resumed it. It does not always happen, only sometimes.
Can someone look at the log?
Thank you.
Post by koying » 23 May 2019, 13:00
Does this log show you doing a pause/unpause to resynchronize due to stuttering?
I don't see it, at first sight...
david86bcn
Post by david86bcn » 23 May 2019, 13:12
koying wrote:
23 May 2019, 13:00
It is true that I did not pause / unpause to resynchronize, but I advanced the video several times until the playback was not smooth. I suppose you can see it in the final part of the log.
If it is necessary another log with pause / unpause I do it.
Thank you.
Post by koying » 23 May 2019, 13:16
Well, I just need to know when, in the log, the video is not smooth, one way or another ;)
david86bcn
Post by david86bcn » 23 May 2019, 13:25
koying wrote:
23 May 2019, 13:16
The video was not smooth after the last advance, I do not remember the exact time, but if you tell me how I can locate the "advance" in the log I can look at it.
david86bcn
Post by david86bcn » 23 May 2019, 13:31
Is it possible that this is the last advance I made?
18:01:11.678 T:140814009584 DEBUG: OnKey: up (0xf080) pressed, action is ChapterOrBigStepForward
After that, I see several "Synchronize" errors in the log.
