Several small problems
HomertheBest
Post by HomertheBest » 10 May 2019, 12:29
Hello, I'm with a TV shield
1) I took a subscription to MrMc (play store). How long is it?
2) In addition, update 3.8-1 no longer has the same display. I can not choose the layout or the display anymore?
3) Can we go back to an earlier version of MrMc?
Thanks in advance (france = google trad) :?
Re: Several small problems
Post by cosmoxl » 10 May 2019, 14:05
You should be able to go to settings>appearance and change the skin if you wish.
