MrMC missing from Google Play Store Topic is solved
sdmaged99
Post by sdmaged99 » 01 May 2019, 18:30
Bought a third Shield, trying to install, but the only version that appears is the "lite" version, and not the full version i paid for?
What is going on? Tried to push it from Google Play and it tells me my device is unsupported? How can i obtain the .apk file and install manually? Pretty frustrating for a paid product and surprised not much is being said on the forum about it (i tried searching...)
Re: MrMC missing from Google Play Store
Post by amet » 02 May 2019, 05:05
We don’t distribute the apk for manual installation.
Is your bootloader unlocked?
https://mrmc.tv/forum/viewtopic.php?t=4407
sdmaged99
Post by sdmaged99 » 02 May 2019, 08:33
The shield is brand new, i'm not sure what you mean by unlocked? I've never had to do anything on other Shields i've owned
If you're saying that rooting your Shield is necessary, then i'm not willing to do that (and MrMC has always worked before)
Post by amet » 02 May 2019, 08:50
I am saying that if its rooted it won't work, so you should be good to go.
lets wait for @koying to chime in on this, he is the expert
sdmaged99
Post by sdmaged99 » 02 May 2019, 09:30
Phew! Im glad, thanks for the reply
Really weird though why it won't appear. Region is set to the UK the same as my other two as well. Odd.
sdmaged99
Post by sdmaged99 » 03 May 2019, 11:02
Anyone else have any ideas? As it stands i can't use it, and i assume you can't upgrade from the lite version to the full version from within the app
Post by davilla » 03 May 2019, 12:20
sdmaged99 wrote:
03 May 2019, 11:02
Check for other differences, versions of shield os, etc.
sdmaged99
Post by sdmaged99 » 03 May 2019, 16:15
All Shields have the following:-
Model Number - 2897
Version - 8.0.0
Shield Android TV SW Version - 7.2.3(30.6.131.170)
Build - OPR6.170623.010.3507953_1441.7411
Kernel Version - 4.9.109-tegra-g4fa2f5b
buildbrain@mobile-u64-3560 #1
sdmaged99
Post by sdmaged99 » 08 May 2019, 10:32
Anyone have any ideas here? I've got a Shield in my daughters room that i can't install MrMC on
Post by davilla » 09 May 2019, 01:07
All good at google play.
Maybe time to reset to factory.
