nvidia controller and red icon volume issues
lapfrank
Post by lapfrank » 27 Dec 2018, 04:32
Hi All,
I've been having this problem for a while, but it's getting worse now. I'm using the controller more recently as the battery keeps running out on the remote and I'm tired of changing it. I'm using passthrough audio (which works fine) and control the volume through CEC with the controller. That also works fine.
Now for the problem. From time to time, the yellow/red volume bottom at the top left of the screen appears and just keeps going down to zero / muted. It just stays on the screen all the time and I can't get rid of it. It doesn't actually impact the volume, it's just very annoying. If I play around with the right round wheel, I can usually bring the volume back up and the icon disappears... but it just keeps getting back all the time.
Is there a way to fix that or simply disable what looks like the internal volume for mrmc/kodi?
Thanks,
