Subtitles in 4K not movable
patoune
Post by patoune » 14 Jul 2018, 09:00
If the positioning of the subtitles (external srt) works very well in HD format, it does not work in 4K where they cannot be mounted (not visible with a 2.35 screen for example). The problem is the same with Kodi.
What is the solution?
Re: Subtitles in 4K not movable
Post by davilla » 14 Jul 2018, 22:53
patoune wrote:
14 Jul 2018, 09:00
If the positioning of the subtitles (srt) works very well in HD format, it does not work in 4K where they cannot be mounted (not visible with a 2.35 screen for example). The problem is the same with Kodi.
If they are embedded subs, they cannot be moved.
patoune
Post by patoune » 15 Jul 2018, 00:26
These are external or downloaded subtitles in.srt format....
Post by koying » 15 Jul 2018, 01:11
Debuglog would help to understand the issue.
The hd, 4k, 2:35 mix I don't quite get
patoune
Post by patoune » 16 Jul 2018, 18:11
I have a projection screen in 2.35 format.
With a movie in HD (1080p) and with the "Calibration" configuration in MrMC, the subtitles are in the picture . If I play a 4K movie the subtitles stay down despite the "Calibration" setting which has no effect on the position.
Tested with Kodi it works in 1080p and 4k...
