Can't install MrMC on Shield
vonmolk
Post by vonmolk » 21 May 2018, 13:44
For the past week I cannot get MrMC to install on my shield. It does not show up on search and when I check the Google Play Store its listed as not compatible. The same with the lite version showing up as incompatible.
Re: Can't install MrMC on Shield
Post by koying » 21 May 2018, 14:15
Looks like the play store might get confused about major device updates (like going from Marshmallow to Nougat).
Try disconnecting/reconnecting the shield to your google account
vonmolk
Post by vonmolk » 21 May 2018, 14:38
Okay I removed and re-added my google play account, but it is still showing incompatible. I did have it installed previously, but got some error about unable to download obb so I removed and when I went to re-install I couldnt anymore.
Post by koying » 21 May 2018, 15:45
You're on latest Shield firmware, right?
Is it 2015, 2015 pro or 2017 model?
vonmolk
Post by vonmolk » 21 May 2018, 16:59
It is the 2017 shield and yeah latest firmware available 6.3. Its odd because I did have it installed on the device before, but for some reason now I cannot get it to install since it is showing that its not compatible.
vonmolk
Post by vonmolk » 22 May 2018, 15:58
Just did a factory reset on my shield not just for this issue, but a few other odd things and still listed as not compatible.
vonmolk
Post by vonmolk » 22 May 2018, 17:32
Now resolved. Locked the bootloader and now I can install MrMC on my Shield. So very weird.
Post by koying » 22 May 2018, 22:21
Thanks for the feedback
andersh
Post by andersh » 07 Jun 2018, 20:23
I'm seeing this problem as well.
My shield is not "compatible", and relocking my bootloader is absolutely not an option. Any other solution?
