Shield Remote doesn't work properly in MrMC
Benoire
Post by Benoire » 01 May 2018, 22:40
Hi
I've been using SPMC as it works better with Android TV compared to Kodi 17, thanks to Koying. I've bought the android version as SPMC is no longer to be updated and I wanted to ensure I was running a supported front end.
I've got 2 issues in that the shield remote does not work within live TV properly; pressing the 'action' button brings up the playback menu but every directional press moves the 'cursor' as well as activating something, such as subtitles etc. The second is that the left / right directional buttons do nothing on playback i.e. to skip backwards/forwards unlike SPMC/
Kodi. The remote options are stock with no software installed. This happens on both my shields in the house.
Is there a config option somewhere that I have missed?
Chris
Re: Shield Remote doesn't work properly in MrMC
Post by koying » 02 May 2018, 14:48
No clue, seems to work fine, here.
a debuglog might help
