Resolution switch problems
GiuseppeRed99
Post by GiuseppeRed99 » 01 May 2018, 17:45
Hello. I turned off the resolution switch because every time I played 480p or 720p files there was a black screen of a few seconds for the switch and it bothered me. but even after turning it off, keep doing it. what else should be deactivated? spmc and kodi do not give me these problems.
Re: Resolution switch problems
Post by davilla » 01 May 2018, 18:15
GiuseppeRed99
Post by GiuseppeRed99 » 01 May 2018, 18:52
it's not an error. I just want to figure out how to disable the automatic switch and stay at the default resolution (1080p 60hz)
Post by davilla » 01 May 2018, 20:11
no one said it was an error :) debuglog will show the display switch if it is occurring.
