4k screen and settings but wi dow is displaying quarter size in top left hand corners
Kepners
Post by Kepners » 25 Apr 2018, 22:18
Basically. Isuing mrmc for the first time and it plays flawlessly from my seedbox. However. The gui is displayed in the top quarter of the screen when I restarted the software in thr e 4k mode though the calibration of the window is the full screen. When the skin is set to 1080p I get no issue. Is it a skin problem ? What is the issue? How do I resolve it?
Re: 4k screen and settings but wi dow is displaying quarter size in top left hand corners
Post by koying » 25 Apr 2018, 23:41
Is it on Shield?
Post by koying » 26 Apr 2018, 06:15
Ok.
Is it in the corner always or only when playing video?
What do you mean by "the skin is set to 1080p"?
A debuglog would help
Kepners
Post by Kepners » 26 Apr 2018, 06:19
When you change the screen resolution down from 4k to 1080p it fills the screen. When it's 4k its in the top left hand corners. I did not try playing a film, but I will this evening and post here. I did try to calibrate the window settings and that showed the full window.
Post by koying » 26 Apr 2018, 06:54
So you mean 4k in the system resolution of the shield, right?
Did you try to reboot after changing the system resolution?
Edit: or do you mean changing the resolution inside MrMC?
Kepners
Post by Kepners » 26 Apr 2018, 07:17
I am always talking inside mrmc. I will reboot the system this evening and come back.
Post by koying » 26 Apr 2018, 09:56
Ok. Thanks. Will test changing reso inside MrMC tonight.
Kepners
Post by Kepners » 26 Apr 2018, 15:17
Restarted. It has made no difference. See attached photos. When it streams, it streams full screen.Image
BTW, i have also used the following GitHub "recommended settings" for this. I dont know if any of these had an impact?
https://github.com/koying/SPMC/wiki/Rec ... ith-4K-GUI
Post by koying » 26 Apr 2018, 19:21
I could not reproduce.
I'll definitely need a debuglog
