Problem with HDR playback
Slice314
Post by Slice314 » 14 Feb 2018, 12:20
Hello there,
I’m having issues playing HDR enabled movies. ATM it is hit and miss, only 1 out of ten it works. I can’t reproduce the problem. My TV is a Samsung KS9500. I’m using the Nvidia Shield 2017
I come from the SPMC fork (which doesn’t present this problem using the latest Krypton build from 12/2017), I use the recommended settings for the Nvidia Shield as koying described at the github wiki.
Is there any known problem I’m not aware of? I just bought MRmC and this is the only thing stoping me from enjoying it.
Re: Problem with HDR playback
Post by amet » 14 Feb 2018, 15:49
Could you get a debuglog when MrMC fails to switch to HDR
Thanks!
Slice314
Post by Slice314 » 14 Feb 2018, 16:11
Thanks Amet :)
I understand. I tried disabling "adjust display refresh rate" and, after that, HDR kicks-in 10 out of 10 times. Seeing that might be the real issue, I tried many diferent values for the "pause during refresh change" (From 2.5 seconds to 3,4,5,6 and 10 seconds) However, nothing helps. Enabling "adjust display refresh rate" makes HDR not kicking-in most of the time.
Thanks for the quick response. Here you have a fresh log trying to play Blade Runner 2049 4K HDR:
http://pasted.co/930f8f82
Post by amet » 14 Feb 2018, 16:14
Cool, let @davilla look at it... he is the video player master :)
sdsnyr94
Post by sdsnyr94 » 16 Feb 2018, 15:32
This is the same issue I reported in the test flight 3.4.1 thread... Koying replied to it, however with everything else going on in that thread, it may have gotten lost.
https://mrmc.tv/forum/viewtopic.php?f=1 ... r94#p12498
Slice314
Post by Slice314 » 16 Feb 2018, 17:38
sdsnyr94 wrote:
16 Feb 2018, 15:32
Well I do hope this bug gets proper attention because HDR content is present and future.
sdsnyr94
Post by sdsnyr94 » 16 Feb 2018, 21:46
When I reported it, @Davilla could not duplicate the issue from his side.
Now that there are more reports than just myself, I'm sure this issue will be resolved soon.
Slice314
Post by Slice314 » 18 Feb 2018, 13:00
Well, since we have no answer at all... I am not so optimistic. @Davilla ?
Post by davilla » 18 Feb 2018, 19:39
Busy with reallife(tm) right now but this issue is only list.
Slice314
Post by Slice314 » 18 Feb 2018, 20:54
18 Feb 2018, 19:39
Thanks, at least now I know you are aware.
