Snowfall skin setting crashes UI navigation Topic is solved
Any Amber skin issues go here
Montoya
Post by Montoya » 12 Mar 2019, 20:31
In Amber Skin settings, setting Holiday snowfall theme enabled, crashes MRMC UI navigation (tvOS).
So once set, the average user is screwed, because no normal navigation is possible after that (even after restart of MrMC), to change that snowfall Skin Setting back to disabled.
Apple TV 4K 64GB tvOS 12.4 - Win10 Pro x64 1903 build 18362.264
Re: Snowfall skin setting crashes UI navigation
Post by amet » 12 Mar 2019, 21:04
fixed... well, removed holiday part :)
thanks!
Montoya
Post by Montoya » 12 Mar 2019, 21:11
12 Mar 2019, 21:04
thanks!
Welcome :-)
Luckily I was playing around in MrMC Test profile, so I could manually change this from true to false again in settings.xml in Amber Skin "addon_data" folder, with help of MrMC file manager, started from one of my other MrMC profiles :D
<setting id="holiday" type="bool">false</setting>
But indeed, removal from Skin is best quick fix :)
Post by amet » 13 Mar 2019, 03:55
Don’t get too attached to this skin... :)
Montoya
Post by Montoya » 13 Mar 2019, 09:15
13 Mar 2019, 03:55
As long as Opacity stays in MrMC I’m fine 8-)
And that is mainly for the PVR UI experience, in which Ariana still has a long way to go to suite my needs.
moderndayhero
Post by moderndayhero » 25 Mar 2019, 22:42
Hmmmz... And what if an average user was just messing around and selected this skin? How would he recover from that? (Help) 😉
Post by amet » 26 Mar 2019, 03:43
3.8.1 will have a fix for it, you will have to remove and reinstall MrMC until 3.8.1 is released
