emby server 4.2.0.40 is not found
Imhotep
Post by Imhotep » 30 Jul 2019, 18:03
emby server 4.2.0.40 is not found, neither via webpin or locally
mrmc 3.8-1
There is no problem with the official emby app.
The problem is on IOS and Apple TV
Can someone help, thank you?
Re: emby server 4.2.0.40 is not found
Post by amet » 30 Jul 2019, 18:22
Debuglog please
Imhotep
Post by Imhotep » 30 Jul 2019, 19:41
Here are the lines created after trying to find emby on the browse, is that enough?
21:36:25.955 T:6136492032   DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
21:36:26.090 T:6136492032   DEBUG: ------ Window Deinit (SettingsSystemInfo.xml) ------
21:36:26.090 T:6136492032   DEBUG: CGUIWindowManager::PreviousWindow: Activate new
21:36:26.090 T:6136492032   DEBUG: ------ Window Init (Settings.xml) ------
21:36:32.785 T:6136492032   DEBUG: Activating window ID: 10018
21:36:32.910 T:6136492032   DEBUG: ------ Window Deinit (Settings.xml) ------
21:36:32.910 T:6136492032   DEBUG: ------ Window Init (SettingsCategory.xml) ------
21:36:38.411 T:6136492032   DEBUG: ------ Window Init (DialogNetworkSetup.xml) ------
21:36:41.272 T:6136492032    INFO: Loading skin file: FileBrowser.xml, load type: KEEP_IN_MEMORY
21:36:41.275 T:6136492032   DEBUG: ------ Window Init (FileBrowser.xml) ------
21:36:42.394 T:6137065472  NOTICE: UDP: Listening on port 7359
21:36:42.470 T:6137065472   DEBUG: CurlFile::Open(0x16dcc00e0) http://192.168.10.3:8096/emby/system/info/public
21:36:42.470 T:6137065472    INFO: easy_aquire - Created session to http://192.168.10.3
21:36:42.588 T:6136492032   ERROR: GetDirectory - Error getting emby://
21:36:42.588 T:6136492032   ERROR: CGUIDialogFileBrowser::GetDirectory(emby://) failed
21:38:05.020 T:6137065472  NOTICE: UDP: Listening on port 7359
21:38:05.102 T:6137065472   DEBUG: CurlFile::Open(0x16dcc00e0) http://192.168.10.3:8096/emby/system/info/public
21:38:05.103 T:6137065472    INFO: easy_aquire - Created session to http://192.168.10.3
21:38:05.138 T:6136492032   ERROR: GetDirectory - Error getting emby://
21:38:05.139 T:6136492032   ERROR: CGUIDialogFileBrowser::GetDirectory(emby://) failed
The IP Adress from emby Server is 192.168.10.3
21:47:06.607 T:6138212352   DEBUG: CActiveAESink::GenerateNoise - noiseFactor = 0.000010
21:47:06.608 T:6137638912   DEBUG: CActiveAE::ClearDiscardedBuffers - buffer pool deleted
21:47:06.693 T:6147960832  NOTICE: UDP: Listening on port 7359
21:47:06.697 T:6147960832   DEBUG: CurlFile::Open(0x16e7240e0) http://192.168.10.3:8096/emby/system/info/public
21:47:06.707 T:6136492032   ERROR: GetDirectory - Error getting emby://
21:47:06.707 T:6136492032   ERROR: CGUIDialogFileBrowser::GetDirectory(emby://) failed
21:47:06.876 T:6147960832  NOTICE: UDP: Listening on port 7359
21:47:06.880 T:6147960832   DEBUG: CurlFile::Open(0x16e7240e0) http://192.168.10.3:8096/emby/system/info/public
21:47:06.891 T:6136492032   ERROR: GetDirectory - Error getting emby://
21:47:06.891 T:6136492032   ERROR: CGUIDialogFileBrowser::GetDirectory(emby://) failed
21:47:09.610 T:6136492032   DEBUG: ------ Window Deinit (FileBrowser.xml) ------
21:47:13.831 T:6136492032    INFO: Loading skin file: FileBrowser.xml, load type: KEEP_IN_MEMORY
21:47:13.837 T:6136492032   DEBUG: ------ Window Init (FileBrowser.xml) ------
21:47:15.431 T:6136492032   DEBUG: ------ Window Deinit (FileBrowser.xml) ------
21:47:46.130 T:6136492032    INFO: Loading skin file: FileBrowser.xml, load type: KEEP_IN_MEMORY
21:47:46.135 T:6136492032   DEBUG: ------ Window Init (FileBrowser.xml) ------
21:47:47.051 T:6146813952  NOTICE: UDP: Listening on port 7359
21:47:47.057 T:6146813952   DEBUG: CurlFile::Open(0x16e60c0e0) http://192.168.10.3:8096/emby/system/info/public
21:47:47.057 T:6146813952    INFO: easy_aquire - Created session to http://192.168.10.3
21:47:47.068 T:6136492032   ERROR: GetDirectory - Error getting emby://
21:47:47.068 T:6136492032   ERROR: CGUIDialogFileBrowser::GetDirectory(emby://) failed
21:47:48.831 T:6136492032   DEBUG: ------ Window Deinit (FileBrowser.xml) ------
21:47:52.671 T:6136492032   DEBUG: ------ Window Deinit (DialogNetworkSetup.xml) ------
21:47:52.672 T:6136492032   DEBUG: CEmbyServices:OnSettingAction host/user are empty
21:47:52.675 T:6136492032   DEBUG: found key /userdata/profiles.xml
21:47:52.676 T:6136492032   DEBUG: Previous line repeats 1 times.
21:47:52.676 T:6136492032   DEBUG: NSUSerDefaults: compressed /userdata/profiles.xml from 923 to 324
21:47:52.676 T:6136492032   DEBUG: found key /userdata/guisettings.xml
21:47:52.680 T:6136492032   DEBUG: Previous line repeats 1 times.
21:47:52.680 T:6136492032   DEBUG: NSUSerDefaults: compressed /userdata/guisettings.xml from 35405 to 6717
Msan2000
Post by Msan2000 » 31 Jul 2019, 02:36
I have the same issue..
mrmc doesnt see the emby server any more,, 2 clients, amazon firestick and nvidia shield.
I can't post the debug log at the moment, i'll try later.. emby server v 4.2.0.40
PIN login doesnt work.. the emby website accepts the pin, but mrmc just keeps increasing the % till it hits 100% and errors out.
Manual/local signin works, but it wont display any folders/media
Nvidia Shield TV (2017) 16GB - 3 Beelink MinixMXIII II's
NAS: unRAID 6.3 Pro • Case (NZXT H440) • CPU (Xeon X3360) • RAM (4x2GB DDR2) • PSU (EVGA SUPERNOVA 650 G2) • HDD (2 x Toshiba 3TB parity, 6 x WD Red 3TB xfs, 1 x 512GB SSD cache)  • UPS APC BR1000G
Msan2000
Post by Msan2000 » 31 Jul 2019, 02:46
here is the debug log from the shield.
Content of MrMC Log
19:41:49.689 T:180530943216   DEBUG: Previous line repeats 1 times.
19:41:49.689 T:180530943216  NOTICE: special://profile/ is mapped to: special://masterprofile/
19:41:49.690 T:180530943216  NOTICE: -----------------------------------------------------------------------
19:41:49.690 T:180530943216  NOTICE: Starting MrMC (3.8-1 Git:2019-04-15-60d492d). Platform: Android ARM64 64-bit
19:41:49.690 T:180530943216  NOTICE: Using Debug MrMC x64 build
19:41:49.690 T:180530943216  NOTICE: MrMC compiled Apr 19 2019 by Clang 5.0.300080  for Android ARM64 64-bit API level 21 (API level 21)
19:41:49.690 T:180530943216  NOTICE: Running on NVIDIA SHIELD Android TV with Android 8.0.0 API level 26, kernel: Linux unknown CPU family 64-bit version 4.9.109-tegra-g4fa2f5b
19:41:49.690 T:180530943216  NOTICE: FFmpeg version: 3.8.0-mrmc-58-gfbc7256-kodi-3.3-kodi
19:41:49.690 T:180530943216  NOTICE: Host CPU: ARMv8 Processor rev 1 (v8l), 4 cores available
19:41:49.690 T:180530943216  NOTICE: Product: darcy, Device: darcy, Board: unknown - Manufacturer: NVIDIA, Brand: NVIDIA, Model: SHIELD Android TV, Hardware: darcy
19:41:49.692 T:180530943216  NOTICE: External storage path = /storage/emulated/0; status = ok
19:41:49.692 T:180530943216  NOTICE: System library paths = /system/lib64:/vendor/lib64:/vendor/odm/lib64
19:41:49.692 T:180530943216  NOTICE: App library path = /mnt/expand/df7d3279-49e5-4d9d-8210-4453306ce7ef/app/tv.mrmc.mrmc-V6-_eQTZSKpe-8UMQWiTAQ==/lib/arm64
19:41:49.692 T:180530943216  NOTICE: APK = /mnt/expand/df7d3279-49e5-4d9d-8210-4453306ce7ef/app/tv.mrmc.mrmc-V6-_eQTZSKpe-8UMQWiTAQ==/base.apk
19:41:49.693 T:180530943216  NOTICE: HasTouchScreen = no
19:41:49.693 T:180530943216  NOTICE: IsNightMode = no
19:41:49.693 T:180530943216  NOTICE: ARM Features: Neon enabled
19:41:49.693 T:180530943216  NOTICE: special://xbmc/ is mapped to: /mnt/expand/df7d3279-49e5-4d9d-8210-4453306ce7ef/user/0/tv.mrmc.mrmc/cache/apk/assets
19:41:49.693 T:180530943216  NOTICE: special://xbmcbin/ is mapped to: /mnt/expand/df7d3279-49e5-4d9d-8210-4453306ce7ef/user/0/tv.mrmc.mrmc/cache/apk/assets
19:41:49.693 T:180530943216  NOTICE: special://masterprofile/ is mapped to: /storage/emulated/0/Android/data/tv.mrmc.mrmc/files/.mrmc/userdata
19:41:49.693 T:180530943216  NOTICE: special://home/ is mapped to: /storage/emulated/0/Android/data/tv.mrmc.mrmc/files/.mrmc
19:41:49.693 T:180530943216  NOTICE: special://temp/ is mapped to: /storage/emulated/0/Android/data/tv.mrmc.mrmc/files/.mrmc/temp
19:41:49.693 T:180530943216  NOTICE: special://logs/ is mapped to: /storage/emulated/0/Android/data/tv.mrmc.mrmc/files/.mrmc/temp/
19:41:49.693 T:180530943216  NOTICE: The executable running is: /mnt/expand/df7d3279-49e5-4d9d-8210-4453306ce7ef/app/tv.mrmc.mrmc-V6-_eQTZSKpe-8UMQWiTAQ==/lib/arm64/libmrmc.so
19:41:49.694 T:180530943216  NOTICE: Local hostname: localhost
19:41:49.694 T:180530943216  NOTICE: Log File is located: /storage/emulated/0/Android/data/tv.mrmc.mrmc/files/.mrmc/temp//mrmc.log
19:41:49.694 T:180530943216  NOTICE: -----------------------------------------------------------------------
19:41:49.703 T:180530943216  NOTICE: load settings...
19:41:49.714 T:180530943216   DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/settings.xml
19:41:49.719 T:180530943216 WARNING: CSettingInt: unknown options filler "audiocdactions" of "audiocds.autoaction"
19:41:49.725 T:180530943216   DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/android.xml
19:41:49.727 T:180530943216   DEBUG: AESinkAUDIOTRACK - CHANNEL_OUT_STEREO 32000 supported
19:41:49.727 T:180530943216   DEBUG: AESinkAUDIOTRACK - CHANNEL_OUT_STEREO 44100 supported
19:41:49.731 T:180530943216   DEBUG: AESinkAUDIOTRACK - CHANNEL_OUT_STEREO 48000 supported
19:41:49.733 T:180530943216   DEBUG: AESinkAUDIOTRACK - CHANNEL_OUT_STEREO 88200 supported
19:41:49.734 T:180530943216   DEBUG: AESinkAUDIOTRACK - CHANNEL_OUT_STEREO 96000 supported
19:41:49.734 T:180530943216   DEBUG: AESinkAUDIOTRACK - CHANNEL_OUT_STEREO 176400 supported
19:41:49.735 T:180530943216   DEBUG: AESinkAUDIOTRACK - CHANNEL_OUT_STEREO 192000 supported
19:41:49.735 T:180530943216  NOTICE: Found 1 Lists of Devices
19:41:49.735 T:180530943216  NOTICE: Enumerated AUDIOTRACK devices:
19:41:49.735 T:180530943216  NOTICE:     Device 1
19:41:49.735 T:180530943216  NOTICE:         m_deviceName      : AudioTrack
19:41:49.735 T:180530943216  NOTICE:         m_displayName     : android
19:41:49.735 T:180530943216  NOTICE:         m_displayNameExtra: audiotrack
19:41:49.735 T:180530943216  NOTICE:         m_deviceType      : AE_DEVTYPE_HDMI
19:41:49.735 T:180530943216  NOTICE:         m_channels        : FL,FR,FC,LFE,BL,BR,SL,SR
19:41:49.736 T:180530943216  NOTICE:         m_sampleRates     : 32000,44100,48000,88200,96000,176400,192000
19:41:49.736 T:180530943216  NOTICE:         m_dataFormats     : AE_FMT_S16LE,AE_FMT_FLOAT,AE_FMT_RAW
19:41:49.736 T:180530943216  NOTICE:         m_streamTypes     : STREAM_TYPE_AC3,STREAM_TYPE_EAC3,STREAM_TYPE_TRUEHD,STREAM_TYPE_DTS_512,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTSHD,STREAM_TYPE_DTSHD_MA
19:41:49.737 T:180530943216   DEBUG: SECTION:LoadDLL(libcurl.so)
19:41:49.738 T:180530943216   DEBUG: Loading: /mnt/expand/df7d3279-49e5-4d9d-8210-4453306ce7ef/app/tv.mrmc.mrmc-V6-_eQTZSKpe-8UMQWiTAQ==/lib/arm64/libcurl.so
19:41:49.747 T:180530943216   DEBUG: CSkinSettings: no <skinsettings> tag found
19:41:49.748 T:180530943216  NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
19:41:49.754 T:180530943216  NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
19:41:49.755 T:180530943216  NOTICE: Default DVD Player: dvdplayer
19:41:49.755 T:180530943216  NOTICE: Default Video Player: dvdplayer
19:41:49.756 T:180530943216  NOTICE: Default Audio Player: paplayer
19:41:49.756 T:180530943216  NOTICE: Enabled debug logging due to GUI setting (2)
19:41:49.756 T:180530943216  NOTICE: Log level changed to "LOG_LEVEL_DEBUG_FREEMEM"
19:41:49.756 T:180530943216  NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
19:41:49.758 T:180530943216   ERROR: CMediaSourceSettings: error loading special://masterprofile/sources.xml: Line 0, Failed to open file
19:41:49.758 T:180530943216  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
19:41:49.759 T:180530943216   DEBUG: CPlayerCoreConfig::<ctor>: created player DVDPlayer for core 1
19:41:49.760 T:180530943216   DEBUG: CPlayerCoreConfig::<ctor>: created player oldmplayercore for core 1
19:41:49.760 T:180530943216   DEBUG: CPlayerCoreConfig::<ctor>: created player PAPlayer for core 3
19:41:49.760 T:180530943216   DEBUG: CPlayerSelectionRule::Initialize: creating rule: system rules
19:41:49.760 T:180530943216   DEBUG: CPlayerSelectionRule::Initialize: creating rule: hdhomerun/mms/udp
19:41:49.760 T:180530943216   DEBUG: CPlayerSelectionRule::Initialize: creating rule: lastfm/shout
19:41:49.760 T:180530943216   DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtmp
19:41:49.760 T:180530943216   DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtsp
19:41:49.760 T:180530943216   DEBUG: CPlayerSelectionRule::Initialize: creating rule: streams
19:41:49.760 T:180530943216   DEBUG: CPlayerSelectionRule::Initialize: creating rule: aacp/sdp
19:41:49.760 T:180530943216   DEBUG: CPlayerSelectionRule::Initialize: creating rule: mp2
19:41:49.760 T:180530943216   DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvd
19:41:49.761 T:180530943216   DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvdimage
19:41:49.761 T:180530943216   DEBUG: CPlayerSelectionRule::Initialize: creating rule: sdp/asf
19:41:49.761 T:180530943216   DEBUG: CPlayerSelectionRule::Initialize: creating rule: M4V
19:41:49.764 T:180530943216   DEBUG: CPlayerSelectionRule::Initialize: creating rule: nsv
19:41:49.764 T:180530943216   DEBUG: CPlayerSelectionRule::Initialize: creating rule: radio
19:41:49.764 T:180530943216  NOTICE: Loaded playercorefactory configuration
19:41:49.766 T:180530943216  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
19:41:49.769 T:180530943216  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
19:41:49.777 T:180530943216    INFO: creating subdirectories
19:41:49.778 T:180530943216    INFO: userdata folder: special://masterprofile/
19:41:49.778 T:180530943216    INFO: recording folder:
19:41:49.778 T:180530943216    INFO: screenshots folder:
19:41:49.785 T:180445222128   DEBUG: virtual void CXBMCApp::onGainFocus():
19:41:49.788 T:180556539120    INFO: CActiveAESink::OpenSink - initialize sink
19:41:49.788 T:180556539120   DEBUG: CActiveAESink::OpenSink - trying to open device AUDIOTRACK:AudioTrack
19:41:49.789 T:180556539120   DEBUG: CAESinkAUDIOTRACK::Initialize requested: sampleRate 44100; format: AE_FMT_FLOAT; type: STREAM_TYPE_NULL; channels: 2
19:41:49.790 T:180556539120   DEBUG: CAndroidFeatures::IsShieldTVDevice = yes
19:41:49.790 T:180556539120   DEBUG: AESinkAUDIOTRACK buffers: min(11352) frames(2205) res(22704)
19:41:49.793 T:180556539120  NOTICE: CAESinkAUDIOTRACK::Created with: sink# encoding: ENCODING_PCM_FLOAT, sample rate: 44100, frame size: 8, buffer size: 22704(11352) // AE# format: AE_FMT_FLOAT, method: PCM, stream-type: PCM-STREAM, m_frames: 2205 m_frameSize: 8 channels: 2 buffer (ms) 64.353741
19:41:49.793 T:180556539120   DEBUG: CActiveAESink::OpenSink - AUDIOTRACK Initialized:
19:41:49.793 T:180556539120   DEBUG:   Output Device : android
19:41:49.793 T:180556539120   DEBUG:   Sample Rate   : 44100
19:41:49.793 T:180556539120   DEBUG:   Sample Format : AE_FMT_FLOAT
19:41:49.793 T:180556539120   DEBUG:   Channel Count : 2
19:41:49.793 T:180556539120   DEBUG:   Channel Layout: FL,FR
19:41:49.793 T:180556539120   DEBUG:   Frames        : 2205
19:41:49.793 T:180556539120   DEBUG:   Frame Size    : 8
19:41:49.794 T:180556539120   DEBUG: CActiveAESink::GenerateNoise - noiseFactor = 0.000010
19:41:49.801 T:180530943216  NOTICE: Running database version Addons20
19:41:49.802 T:180530943216   DEBUG: SECTION:LoadDLL(libcpluff.so)
19:41:49.802 T:180530943216   DEBUG: Loading: /mnt/expand/df7d3279-49e5-4d9d-8210-4453306ce7ef/app/tv.mrmc.mrmc-V6-_eQTZSKpe-8UMQWiTAQ==/lib/arm64/libcpluff.so
19:41:49.805 T:180530943216    INFO: ADDON: cpluff: 'Could not read plug-in directory /storage/emulated/0/Android/data/tv.mrmc.mrmc/files/.mrmc/addons: No such file or directory'
19:41:49.854 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.ca_es has been installed.'
19:41:49.854 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.mt_mt has been installed.'
19:41:49.854 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.az_az has been installed.'
19:41:49.854 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.eo has been installed.'
19:41:49.854 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.vi_vn has been installed.'
19:41:49.854 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.ja_jp has been installed.'
19:41:49.854 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.images.weathericons.default has been installed.'
19:41:49.854 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.pl_pl has been installed.'
19:41:49.854 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in webinterface.default has been installed.'
19:41:49.854 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in skin.ariana has been installed.'
19:41:49.854 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.en_au has been installed.'
19:41:49.855 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.fr_ca has been installed.'
19:41:49.855 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in kodi.audiodecoder has been installed.'
19:41:49.855 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in pvr.argustv has been installed.'
19:41:49.855 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.sr_rs has been installed.'
19:41:49.855 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.ofdb.de has been installed.'
19:41:49.855 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in metadata.themoviedb.org has been installed.'
19:41:49.855 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.fa_af has been installed.'
19:41:49.855 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in xbmc.metadata has been installed.'
19:41:49.855 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.hu_hu has been installed.'
19:41:49.855 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.bg_bg has been installed.'
19:41:49.855 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in pvr.dvblink has been installed.'
19:41:49.855 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.mk_mk has been installed.'
19:41:49.855 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.pt_pt has been installed.'
19:41:49.855 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.da_dk has been installed.'
19:41:49.855 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.nb_no has been installed.'
19:41:49.855 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.sv_se has been installed.'
19:41:49.856 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.ms_my has been installed.'
19:41:49.856 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.is_is has been installed.'
19:41:49.856 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.ru_ru has been installed.'
19:41:49.856 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in xbmc.gui has been installed.'
19:41:49.856 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in script.keymap has been installed.'
19:41:49.856 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.os_os has been installed.'
19:41:49.856 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.es_mx has been installed.'
19:41:49.856 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.nl_nl has been installed.'
19:41:49.856 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in script.advanced.wol has been installed.'
19:41:49.856 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in metadata.musicvideos.theaudiodb.com has been installed.'
19:41:49.856 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.ta_in has been installed.'
19:41:49.856 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.gl_es has been installed.'
19:41:49.856 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in skin.re-touched has been installed.'
19:41:49.856 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in pvr.tvmosaic has been installed.'
19:41:49.856 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in pvr.pctv has been installed.'
19:41:49.856 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in screensaver.xbmc.builtin.slideshow has been installed.'
19:41:49.856 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in skin.blackglassnova has been installed.'
19:41:49.856 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in pvr.iptvsimple has been installed.'
19:41:49.857 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in skin.opacity has been installed.'
19:41:49.857 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.ko_kr has been installed.'
19:41:49.857 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.fa_ir has been installed.'
19:41:49.857 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in pvr.njoy has been installed.'
19:41:49.857 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.uz_uz has been installed.'
19:41:49.857 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.movieposterdb.com has been installed.'
19:41:49.857 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.tg_tj has been installed.'
19:41:49.857 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.htbackdrops.com has been installed.'
19:41:49.857 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.my_mm has been installed.'
19:41:49.857 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in skin.ariana.touch has been installed.'
19:41:49.857 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.port.hu has been installed.'
19:41:49.857 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in skin.amber has been installed.'
19:41:49.857 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in pvr.dvbviewer has been installed.'
19:41:49.857 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.en_gb has been installed.'
19:41:49.857 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in visualization.spectrum has been installed.'
19:41:49.857 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.hr_hr has been installed.'
19:41:49.857 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in pvr.stalker has been installed.'
19:41:49.858 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.zh_tw has been installed.'
19:41:49.858 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.zh_cn has been installed.'
19:41:49.858 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.fo_fo has been installed.'
19:41:49.858 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.musicbrainz.org has been installed.'
19:41:49.858 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in metadata.local has been installed.'
19:41:49.858 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in xbmc.webinterface has been installed.'
19:41:49.858 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.ro_ro has been installed.'
19:41:49.858 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.fi_fi has been installed.'
19:41:49.858 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.themoviedb.org has been installed.'
19:41:49.858 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.de_de has been installed.'
19:41:49.858 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.theaudiodb.com has been installed.'
19:41:49.858 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in script.xbmc.unpausejumpback has been installed.'
19:41:49.858 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.en_nz has been installed.'
19:41:49.858 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in pvr.filmon has been installed.'
19:41:49.858 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.szl has been installed.'
19:41:49.858 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.en_us has been installed.'
19:41:49.858 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.tr_tr has been installed.'
19:41:49.858 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in xbmc.json has been installed.'
19:41:49.859 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.fanart.tv has been installed.'
19:41:49.859 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in pvr.vbox has been installed.'
19:41:49.859 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in xbmc.audioencoder has been installed.'
19:41:49.859 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in metadata.mymovies.dk has been installed.'
19:41:49.859 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.th_th has been installed.'
19:41:49.859 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.id_id has been installed.'
19:41:49.859 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.sk_sk has been installed.'
19:41:49.859 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.pt_br has been installed.'
19:41:49.859 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.uisounds.mrmc has been installed.'
19:41:49.859 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.am_et has been installed.'
19:41:49.859 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in screensaver.xbmc.builtin.black has been installed.'
19:41:49.859 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.sl_si has been installed.'
19:41:49.859 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in screensaver.xbmc.builtin.system has been installed.'
19:41:49.859 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in pvr.vdr.vnsi has been installed.'
19:41:49.859 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.fr_fr has been installed.'
19:41:49.859 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.es_ar has been installed.'
19:41:49.859 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in pvr.mediaportal.tvserver has been installed.'
19:41:49.859 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.eu_es has been installed.'
19:41:49.859 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.bs_ba has been installed.'
19:41:49.860 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.sr_rs@latin has been installed.'
19:41:49.860 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.cs_cz has been installed.'
19:41:49.860 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in metadata.universal has been installed.'
19:41:49.860 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.mi has been installed.'
19:41:49.860 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in skin.mrmc has been installed.'
19:41:49.860 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in screensaver.xbmc.builtin.dim has been installed.'
19:41:49.860 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.hi_in has been installed.'
19:41:49.860 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in service.libraryautoupdate has been installed.'
19:41:49.860 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.sq_al has been installed.'
19:41:49.860 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.el_gr has been installed.'
19:41:49.860 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in pvr.wmc has been installed.'
19:41:49.860 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.ml_in has been installed.'
19:41:49.861 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in script.plex has been installed.'
19:41:49.861 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in pvr.hdhomerun has been installed.'
19:41:49.861 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.cy_gb has been installed.'
19:41:49.861 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.af_za has been installed.'
19:41:49.861 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in kodi.resource has been installed.'
19:41:49.861 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in script.module.pil has been installed.'
19:41:49.861 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.uk_ua has been installed.'
19:41:49.861 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.uisounds.tvos has been installed.'
19:41:49.861 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.hy_am has been installed.'
19:41:49.861 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in pvr.vuplus has been installed.'
19:41:49.861 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in pvr.mythtv has been installed.'
19:41:49.861 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.si_lk has been installed.'
19:41:49.861 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.it_it has been installed.'
19:41:49.861 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.lt_lt has been installed.'
19:41:49.861 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in xbmc.core has been installed.'
19:41:49.861 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.ar_sa has been installed.'
19:41:49.862 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.mn_mn has been installed.'
19:41:49.862 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in metadata.tvshows.themoviedb.org has been installed.'
19:41:49.862 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in script.module.requests has been installed.'
19:41:49.862 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.lv_lv has been installed.'
19:41:49.862 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in skin.pm3-hd has been installed.'
19:41:49.862 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.te_in has been installed.'
19:41:49.862 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.uisounds.amber has been installed.'
19:41:49.862 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in pvr.nextpvr has been installed.'
19:41:49.862 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in script.xbmcbackup has been installed.'
19:41:49.862 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in metadata.album.universal has been installed.'
19:41:49.862 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.et_ee has been installed.'
19:41:49.862 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in metadata.tvdb.com has been installed.'
19:41:49.862 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.allmusic.com has been installed.'
19:41:49.862 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.omdbapi.com has been installed.'
19:41:49.862 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in metadata.artists.universal has been installed.'
19:41:49.862 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.he_il has been installed.'
19:41:49.862 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in xbmc.python has been installed.'
19:41:49.863 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.imdb.com has been installed.'
19:41:49.863 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in pvr.hts has been installed.'
19:41:49.863 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.be_by has been installed.'
19:41:49.863 T:180530943216   DEBUG: ADDON: cpluff: 'Plug-in resource.language.es_es has been installed.'
19:41:49.863 T:180530943216   DEBUG: ADDON: cpluff: 'Not all directories were successfully scanned.'
19:41:49.878 T:180530943216    INFO: CKeyboardLayoutManager: loading keyboard layouts from special://xbmc/system/keyboardlayouts...
19:41:49.879 T:180530943216   DEBUG: CKeyboardLayoutManager: keyboard layout "Lithuanian AZERTY" successfully loaded
19:41:49.879 T:180530943216   DEBUG: CKeyboardLayoutManager: keyboard layout "Lithuanian QWERTY" successfully loaded
19:41:49.880 T:180530943216   DEBUG: CKeyboardLayoutManager: keyboard layout "French AZERTY" successfully loaded
19:41:49.880 T:180530943216   DEBUG: CKeyboardLayoutManager: keyboard layout "Spanish QWERTY" successfully loaded
19:41:49.880 T:180530943216   DEBUG: CKeyboardLayoutManager: keyboard layout "Swedish QWERTY" successfully loaded
19:41:49.881 T:180530943216   DEBUG: CKeyboardLayoutManager: keyboard layout "German QWERTZ" successfully loaded
19:41:49.881 T:180530943216   DEBUG: CKeyboardLayoutManager: keyboard layout "Bulgarian ЯВЕРТЪ" successfully loaded
19:41:49.882 T:180530943216   DEBUG: CKeyboardLayoutManager: keyboard layout "Bulgarian АБВ" successfully loaded
19:41:49.885 T:180530943216   DEBUG: CKeyboardLayoutManager: keyboard layout "Norwegian QWERTY" successfully loaded
19:41:49.885 T:180530943216   DEBUG: CKeyboardLayoutManager: keyboard layout "Danish QWERTY" successfully loaded
19:41:49.886 T:180530943216   DEBUG: CKeyboardLayoutManager: keyboard layout "Romanian QWERTY" successfully loaded
19:41:49.886 T:180530943216   DEBUG: CKeyboardLayoutManager: keyboard layout "Turkish QWERTY" successfully loaded
19:41:49.887 T:180530943216   DEBUG: CKeyboardLayoutManager: keyboard layout "English QWERTY" successfully loaded
19:41:49.887 T:180530943216   DEBUG: CKeyboardLayoutManager: keyboard layout "English AZERTY" successfully loaded
19:41:49.887 T:180530943216   DEBUG: CKeyboardLayoutManager: keyboard layout "English ABC" successfully loaded
19:41:49.887 T:180530943216   DEBUG: CKeyboardLayoutManager: keyboard layout "Chinese BasePY" successfully loaded
19:41:49.888 T:180530943216   DEBUG: CKeyboardLayoutManager: keyboard layout "Chinese BaiduPY" successfully loaded
19:41:49.888 T:180530943216   DEBUG: CKeyboardLayoutManager: keyboard layout "Arabic QWERTY" successfully loaded
19:41:49.888 T:180530943216   DEBUG: CKeyboardLayoutManager: keyboard layout "Russian ЙЦУКЕН" successfully loaded
19:41:49.889 T:180530943216   DEBUG: CKeyboardLayoutManager: keyboard layout "Russian АБВ" successfully loaded
19:41:49.889 T:180530943216   DEBUG: CKeyboardLayoutManager: keyboard layout "Greek QWERTY" successfully loaded
19:41:49.890 T:180530943216   DEBUG: CKeyboardLayoutManager: keyboard layout "Polish QWERTY" successfully loaded
19:41:49.890 T:180530943216   DEBUG: CKeyboardLayoutManager: keyboard layout "Hungarian QWERTZ" successfully loaded
19:41:49.890 T:180530943216   DEBUG: CKeyboardLayoutManager: keyboard layout "Czech QWERTZ" successfully loaded
19:41:49.891 T:180530943216   DEBUG: CKeyboardLayoutManager: keyboard layout "Hebrew QWERTY" successfully loaded
19:41:49.891 T:180530943216   DEBUG: CKeyboardLayoutManager: keyboard layout "Hebrew ABC" successfully loaded
19:41:49.892 T:180530943216   DEBUG: CKeyboardLayoutManager: keyboard layout "Ukrainian ЙЦУКЕН" successfully loaded
19:41:49.892 T:180530943216   DEBUG: CKeyboardLayoutManager: keyboard layout "Ukrainian АБВ" successfully loaded
19:41:49.892 T:180530943216   DEBUG: CKeyboardLayoutManager: keyboard layout "Korean ㄱㄴㄷ" successfully loaded
19:41:49.893 T:180530943216   DEBUG: CKeyboardLayoutManager: keyboard layout "Portuguese (Portugal) QWERTY" successfully loaded
19:41:49.895 T:180530943216    INFO: CWinSystemAndroidEGL : fetchDisplayModes : found 10 modes
19:41:49.895 T:180530943216   DEBUG: CWinSystemAndroidEGL: maximum/current resolution: 3840x2160
19:41:49.895 T:180530943216   DEBUG: CWinSystemAndroidEGL: selected resolution: 0x0
19:41:49.895 T:180530943216  NOTICE: CWinSystemAndroidEGL: window resolution: 1920x1080
19:41:49.895 T:180530943216  NOTICE: CWinSystemAndroidEGL: Current resolution: 1920x1080 3840x2160 @ 59.940060 - Full Screen
19:41:49.895 T:180530943216   DEBUG: CWinSystemAndroidEGL: ProbeResolutions: 1920x1080
19:41:49.896 T:180530943216  NOTICE: CWinSystemAndroidEGL: Current resolution: 1920x1080 3840x2160 @ 59.940060 - Full Screen
19:41:49.896 T:180530943216  NOTICE: Found resolution 1920 x 1080 for display 0 with 3840 x 2160 @ 59.940060 Hz
19:41:49.896 T:180530943216  NOTICE: Found resolution 1920 x 1080 for display 0 with 3840 x 2160 @ 30.000000 Hz
19:41:49.896 T:180530943216  NOTICE: Found resolution 1920 x 1080 for display 0 with 3840 x 2160 @ 25.000000 Hz
19:41:49.896 T:180530943216  NOTICE: Found resolution 1920 x 1080 for display 0 with 3840 x 2160 @ 24.000000 Hz
19:41:49.896 T:180530943216  NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 24.000000 Hz
19:41:49.896 T:180530943216  NOTICE: Found resolution 1920 x 1080 for display 0 with 3840 x 2160 @ 50.000000 Hz
19:41:49.896 T:180530943216  NOTICE: Found resolution 1920 x 1080 for display 0 with 3840 x 2160 @ 60.000004 Hz
19:41:49.896 T:180530943216  NOTICE: Found resolution 1920 x 1080 for display 0 with 3840 x 2160 @ 29.970030 Hz
19:41:49.896 T:180530943216  NOTICE: Found resolution 1920 x 1080 for display 0 with 3840 x 2160 @ 23.976025 Hz
19:41:49.896 T:180530943216  NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 23.976025 Hz
19:41:49.896 T:180530943216  NOTICE: Found (1920x1080@59.940060) at 16, setting to RES_DESKTOP at 16
19:41:49.896 T:180530943216  NOTICE: Checking resolution 16
19:41:49.897 T:180530943216   DEBUG: CWinSystemAndroidEGL: SetNativeResolution: 17: 1920x1080 3840x2160@59.940060
19:41:49.903 T:180530943216   DEBUG: Previous line repeats 1 times.
19:41:49.903 T:180530943216   DEBUG: CreateWindow: Created surface of size 1920x1080
19:41:49.933 T:180530943216   DEBUG: CWinSystemAndroidEGL::OnResetDevice
19:41:49.935 T:180530943216    INFO: InitRenderSystem: GLES version 302
19:41:49.935 T:180530943216  NOTICE: GL_VENDOR = NVIDIA Corporation
19:41:49.935 T:180530943216  NOTICE: GL_RENDERER = NVIDIA Tegra
19:41:49.935 T:180530943216  NOTICE: GL_VERSION = OpenGL ES 3.2 NVIDIA 415.00
19:41:49.935 T:180530943216  NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 3.20
19:41:49.935 T:180530943216   DEBUG: GLES: Extension Support Test - GL_NVX_gpu_memory_info NO
19:41:49.935 T:180530943216  NOTICE: GL_EXTENSIONS = GL_EXT_debug_marker GL_EXT_base_instance GL_EXT_blend_func_extended GL_EXT_blend_minmax GL_EXT_buffer_storage GL_EXT_clear_texture GL_EXT_clip_control GL_EXT_clip_cull_distance GL_EXT_color_buffer_float GL_EXT_color_buffer_half_float GL_EXT_conservative_depth GL_EXT_copy_image GL_EXT_debug_label GL_EXT_discard_framebuffer GL_EXT_disjoint_timer_query GL_EXT_draw_buffers_indexed GL_EXT_draw_elements_base_vertex GL_EXT_external_buffer GL_EXT_float_blend GL_EXT_frag_depth GL_EXT_geometry_point_size GL_EXT_geometry_shader GL_EXT_gpu_shader5 GL_EXT_map_buffer_range GL_EXT_multi_draw_indirect GL_EXT_multisample_compatibility GL_EXT_occlusion_query_boolean GL_EXT_polygon_offset_clamp GL_EXT_post_depth_coverage GL_EXT_primitive_bounding_box GL_EXT_protected_textures GL_EXT_raster_multisample GL_EXT_render_snorm GL_EXT_robustness GL_EXT_separate_shader_objects GL_EXT_shader_group_vote GL_EXT_shader_implicit_conversions GL_EXT_shader_integer_mix GL_EXT_shader_io_blocks GL_EXT_shader_non_constant_global_initializers GL_EXT_shader_texture_lod GL_EXT_shadow_samplers GL_EXT_sparse_texture GL_EXT_sparse_texture2 GL_EXT_sRGB GL_EXT_sRGB_write_control GL_EXT_tessellation_point_size GL_EXT_tessellation_shader GL_EXT_texture_border_clamp GL_EXT_texture_buffer GL_EXT_texture_compression_bptc GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map_array GL_EXT_texture_filter_anisotropic GL_EXT_texture_filter_minmax GL_EXT_texture_format_BGRA8888 GL_EXT_texture_mirror_clamp_to_edge GL_EXT_texture_norm16 GL_EXT_texture_rg GL_EXT_texture_sRGB_R8 GL_EXT_texture_sRGB_decode GL_EXT_texture_storage GL_EXT_texture_view GL_EXT_draw_transform_feedback GL_EXT_unpack_subimage GL_EXT_window_rectangles GL_KHR_context_flush_control GL_KHR_debug GL_EXT_memory_object GL_EXT_memory_object_fd GL_KHR_parallel_shader_compile GL_KHR_no_error GL_KHR_robust_buffer_access_behavior GL_KHR_robustness GL_EXT_semaphore GL_EXT_semaphore_fd GL_KHR_texture_compression_astc_ldr GL_KHR_texture_compression_astc_sliced_3d GL_NV_bgr GL_NV_bindless_texture GL_NV_blend_equation_advanced GL_NV_blend_equation_advanced_coherent GL_NV_blend_minmax_factor GL_NV_conditional_render GL_NV_conservative_raster GL_NV_copy_buffer GL_NV_copy_image GL_NV_draw_buffers GL_NV_draw_instanced GL_NV_draw_texture GL_NV_draw_vulkan_image GL_NV_EGL_stream_consumer_external GL_NV_explicit_attrib_location GL_NV_fbo_color_attachments GL_NV_fill_rectangle GL_NV_fragment_coverage_to_color GL_NV_fragment_shader_interlock GL_NV_framebuffer_blit GL_NV_framebuffer_mixed_samples GL_NV_framebuffer_multisample GL_NV_generate_mipmap_sRGB GL_NV_geometry_shader_passthrough GL_NV_instanced_arrays GL_NV_internalformat_sample_query GL_NV_gpu_shader5 GL_NV_image_formats GL_NV_occlusion_query_samples GL_NV_non_square_matrices GL_NV_pack_subimage GL_NV_packed_float GL_NV_packed_float_linear GL_NV_path_rendering GL_NV_path_rendering_shared_edge GL_NV_pixel_buffer_object GL_NV_polygon_mode GL_NV_read_buffer GL_NV_read_depth GL_NV_read_depth_stencil GL_NV_read_stencil GL_NV_sample_locations GL_NV_sample_mask_override_coverage GL_NV_secure_context GL_NV_shader_atomic_fp16_vector GL_NV_shader_noperspective_interpolation GL_NV_shadow_samplers_array GL_NV_shadow_samplers_cube GL_NV_sRGB_formats GL_NV_texture_array GL_NV_texture_barrier GL_NV_texture_border_clamp GL_NV_texture_compression_latc GL_NV_texture_compression_s3tc GL_NV_texture_compression_s3tc_update GL_NV_timer_query GL_NV_viewport_array GL_NV_viewport_array2 GL_NV_viewport_swizzle GL_KHR_blend_equation_advanced GL_KHR_blend_equation_advanced_coherent GL_OES_compressed_ETC1_RGB8_texture GL_EXT_compressed_ETC1_RGB8_sub_texture GL_OES_depth24 GL_OES_depth32 GL_OES_depth_texture GL_OES_depth_texture_cube_map GL_OES_copy_image GL_OES_draw_buffers_indexed GL_OES_draw_elements_base_vertex GL_OES_texture_border_clamp GL_OES_tessellation_point_size GL_OES_tessellation_shader GL_OES_texture_buffer GL_OES_geometry_point_size GL_OES_geometry_shader GL_OES_gpu_shader5 GL_OES_shader_io_blocks GL_OES_texture_view GL_OES_primitive_bounding_box GL_OES_EGL_image GL_OES_EGL_image_external GL_OES_EGL_image_external_essl3 GL_OES_EGL_sync GL_OES_element_index_uint GL_OES_fbo_render_mipmap GL_OES_get_program_binary GL_OES_mapbuffer GL_OES_packed_depth_stencil GL_OES_rgb8_rgba8 GL_OES_sample_shading GL_OES_sample_variables GL_OES_shader_image_atomic GL_OES_shader_multisample_interpolation GL_OES_standard_derivatives GL_OES_surfaceless_context GL_OES_texture_cube_map_array GL_OES_texture_npot GL_OES_texture_float GL_OES_texture_float_linear GL_OES_texture_half_float GL_OES_texture_half_float_linear GL_OES_texture_stencil8 GL_OES_texture_storage_multisample_2d_array GL_OES_vertex_array_object GL_OES_vertex_half_float GL_OES_viewport_array GL_OVR_multiview GL_OVR_multiview2 GL_ANDROID_extension_pack_es31a
19:41:49.936 T:180530943216   DEBUG: GLES: Extension Support Test - GL_EXT_texture_format_BGRA8888 YES
19:41:49.936 T:180530943216   DEBUG: GLES: Extension Support Test - GL_IMG_texture_format_BGRA8888 NO
19:41:49.936 T:180530943216   DEBUG: GLES: Extension Support Test - GL_APPLE_texture_format_BGRA8888 NO
19:41:49.936 T:180530943216   DEBUG: GLES: Extension Support Test - GL_EXT_unpack_subimage YES
19:41:49.937 T:180530943216   DEBUG: GUI Shader [guishader_frag_default.glsl]- Initialise successful : 0x2a0ac1fdc0
19:41:49.938 T:180530943216   DEBUG: GUI Shader [guishader_frag_texture.glsl]- Initialise successful : 0x2a0ac20180
19:41:49.938 T:180530943216   DEBUG: GUI Shader [guishader_frag_multi.glsl]- Initialise successful : 0x2a0ac20220
19:41:49.939 T:180530943216   DEBUG: GUI Shader [guishader_frag_fonts.glsl]- Initialise successful : 0x2a0ac20400
19:41:49.940 T:180530943216   DEBUG: GUI Shader [guishader_frag_texture_noblend.glsl]- Initialise successful : 0x2a0ac202c0
19:41:49.941 T:180530943216   DEBUG: GUI Shader [guishader_frag_multi_blendcolor.glsl]- Initialise successful : 0x2a0ac204a0
19:41:49.941 T:180530943216   DEBUG: GUI Shader [guishader_frag_rgba.glsl]- Initialise successful : 0x2a0ac20900
19:41:49.942 T:180530943216   DEBUG: GLES: Extension Support Test - GL_OES_EGL_image_external YES
19:41:49.942 T:180530943216   DEBUG: GUI Shader [guishader_frag_rgba_oes.glsl]- Initialise successful : 0x2a0ac205e0
19:41:49.943 T:180530943216   DEBUG: GUI Shader [guishader_frag_rgba_blendcolor.glsl]- Initialise successful : 0x2a0ac207c0
19:41:49.944 T:180530943216   DEBUG: GUI Shader [guishader_frag_rgba_bob.glsl]- Initialise successful : 0x2a0ac20a40
19:41:49.944 T:180530943216   DEBUG: GLES: Extension Support Test - GL_OES_EGL_image_external YES
19:41:49.944 T:180530943216   DEBUG: GUI Shader [guishader_frag_rgba_bob_oes.glsl]- Initialise successful : 0x2a0ac20c20
19:41:49.945 T:180530943216  NOTICE: CWinSystemAndroidEGL: Current resolution: 1920x1080 3840x2160 @ 59.940060 - Full Screen
19:41:49.945 T:180530943216   DEBUG: CWinSystemAndroidEGL::CreateNewWindow: No need to create a new window
19:41:49.945 T:180530943216    INFO: GLES: Maximum texture width: 16384
19:41:49.945 T:180530943216   DEBUG: static void CXBMCApp::CalculateGUIRatios()(gui scaling) - 1.000000, 1.000000
19:41:50.217 T:180530943216    INFO: load keymapping
19:41:50.220 T:180530943216    INFO: Loading special://xbmc/system/keymaps/appcommand.xml
19:41:50.220 T:180530943216    INFO: Loading special://xbmc/system/keymaps/customcontroller.SiriRemote.xml
19:41:50.221 T:180530943216    INFO: Loading special://xbmc/system/keymaps/gamepad.xml
19:41:50.223 T:180530943216    INFO: Loading special://xbmc/system/keymaps/joystick.xml
19:41:50.224 T:180530943216    INFO: Loading special://xbmc/system/keymaps/keyboard.xml
19:41:50.228 T:180530943216    INFO: Loading special://xbmc/system/keymaps/mouse.xml
19:41:50.229 T:180530943216    INFO: Loading special://xbmc/system/keymaps/remote.xml
19:41:50.232 T:180530943216    INFO: Loading special://xbmc/system/keymaps/touchscreen.xml
19:41:50.236 T:180530943216    INFO: GUI format 1920x1080, Display 3840x2160 @ 59.940060 - Full Screen
19:41:50.236 T:180530943216   DEBUG: guilib: Fill viewport on change for solving rendering passes
19:41:50.236 T:180530943216    INFO: CLangInfo: loading resource.language.en_gb language information...
19:41:50.237 T:180530943216   DEBUG: trying to set locale to en_US.UTF-8
19:41:50.238 T:180530943216    INFO: global locale set to en_US.UTF-8
19:41:50.239 T:180530943216    INFO: CLangInfo: loading resource.language.en_gb language strings...
19:41:50.247 T:180530943216   DEBUG: POParser: loaded 3877 strings from file resource://resource.language.en_gb/strings.po
19:41:50.248 T:180530943216   DEBUG: LoadMappings - loaded node "Motorola Nyxboard Hybrid"
19:41:50.248 T:180530943216   DEBUG: LoadMappings - loaded node "CEC Adapter"
19:41:50.248 T:180530943216   DEBUG: LoadMappings - loaded node "Pulse-Eight CEC Adapter"
19:41:50.248 T:180530943216   DEBUG: LoadMappings - loaded node "iMON HID device"
19:41:50.248 T:180530943216   DEBUG: bool CXBMCApp::EnableWakeLock(bool): true
19:41:50.251 T:180607763696  NOTICE: Running database version Addons20
19:41:50.252 T:180607763696   DEBUG: Initialize, updating databases...
19:41:50.253 T:180607763696  NOTICE: Running database version ViewModes6
19:41:50.255 T:180607763696  NOTICE: Running database version Textures13
19:41:50.260 T:180607763696  NOTICE: Running database version MyMusic60
19:41:50.268 T:180607763696  NOTICE: Running database version MyVideos107
19:41:50.271 T:180607763696  NOTICE: Running database version TV29
19:41:50.273 T:180607763696  NOTICE: Running database version Epg11
19:41:50.275 T:180607763696   DEBUG: Initialize, updating databases... DONE
19:41:50.275 T:180530943216   DEBUG: bool CXBMCApp::EnableWakeLock(bool): false
19:41:50.276 T:180530943216    INFO: DPMS: not supported on this platform
19:41:50.318 T:180530943216   DEBUG: Activating window ID: 12997
19:41:50.318 T:180530943216   DEBUG: ------ Window Init () ------
19:41:50.318 T:180530943216    INFO: load splash image: /mnt/expand/df7d3279-49e5-4d9d-8210-4453306ce7ef/user/0/tv.mrmc.mrmc/cache/apk/assets/media/Splash.png
19:41:50.320 T:180530943216    INFO: Unloading old skin ...
19:41:50.326 T:180530943216    INFO:   load skin from: /mnt/expand/df7d3279-49e5-4d9d-8210-4453306ce7ef/user/0/tv.mrmc.mrmc/cache/apk/assets/addons/skin.amber (version: 2.2.3)
19:41:50.326 T:180530943216    INFO:   load fonts for skin...
19:41:50.327 T:180530943216    INFO: Loading fonts from /mnt/expand/df7d3279-49e5-4d9d-8210-4453306ce7ef/user/0/tv.mrmc.mrmc/cache/apk/assets/addons/skin.amber/1080i/Font.xml
19:41:50.393 T:180530943216   DEBUG: POParser: loaded 121 strings from file /mnt/expand/df7d3279-49e5-4d9d-8210-4453306ce7ef/user/0/tv.mrmc.mrmc/cache/apk/assets/addons/skin.amber/language/English/strings.po
19:41:50.393 T:180530943216    INFO: Loading skin includes from /mnt/expand/df7d3279-49e5-4d9d-8210-4453306ce7ef/user/0/tv.mrmc.mrmc/cache/apk/assets/addons/skin.amber/1080i/Includes.xml
19:41:50.437 T:180530943216    INFO:   load new skin...
19:41:50.439 T:180530943216    INFO: Loading user windows, path /mnt/expand/df7d3279-49e5-4d9d-8210-4453306ce7ef/user/0/tv.mrmc.mrmc/cache/apk/assets/addons/skin.amber/1080i
19:41:50.451 T:180530943216   DEBUG: Load Skin XML: 14.69ms
19:41:50.451 T:180530943216    INFO:   initialize new skin...
19:41:50.452 T:180530943216   DEBUG: guilib: Fill viewport on change for solving rendering passes
19:41:50.452 T:180530943216    INFO: Loading skin file: Pointer.xml, load type: LOAD_ON_GUI_INIT
19:41:50.454 T:180530943216   DEBUG: OpenBundle - Opened bundle /mnt/expand/df7d3279-49e5-4d9d-8210-4453306ce7ef/user/0/tv.mrmc.mrmc/cache/apk/assets/addons/skin.amber/media/Textures.xbt
19:41:50.454 T:180530943216    INFO: Loading skin file: DialogVolumeBar.xml, load type: LOAD_ON_GUI_INIT
19:41:50.456 T:180530943216    INFO: Loading skin file: DialogKaiToast.xml, load type: LOAD_ON_GUI_INIT
19:41:50.457 T:180530943216    INFO: Loading skin file: DialogMuteBug.xml, load type: LOAD_ON_GUI_INIT
19:41:50.458 T:180530943216    INFO: Loading skin file: DialogSeekBar.xml, load type: LOAD_ON_GUI_INIT
19:41:50.463 T:180530943216    INFO: Loading skin file: DialogBusy.xml, load type: LOAD_ON_GUI_INIT
19:41:50.464 T:180530943216    INFO: Loading skin file: DialogExtendedProgressBar.xml, load type: LOAD_ON_GUI_INIT
19:41:50.468 T:180530943216    INFO: Loading resource://resource.uisounds.mrmc/sounds.xml
19:41:50.492 T:180530943216    INFO:   skin loaded...
19:41:50.492 T:180530943216   DEBUG: Activating window ID: 12997
19:41:50.492 T:180530943216   DEBUG: ------ Window Init () ------
19:41:50.502 T:180530943216   DEBUG: JSONRPC: JSON schema type definition references an unknown type Setting.Details.Setting
19:41:50.502 T:180530943216 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
19:41:50.503 T:180530943216    INFO: JSONRPC: Adding type "Setting.Details.SettingList" to list of incomplete definitions (waiting for "Setting.Details.Setting")
19:41:50.503 T:180530943216    INFO: JSONRPC: Resolving incomplete types/methods referencing Setting.Details.Setting
19:41:50.512 T:180530943216   ERROR: JSONRPC: Missing implementation for method "VideoLibrary.GetInProgressTvShows"
19:41:50.520 T:180530943216    INFO: JSONRPC v6.32.5: Successfully initialized
19:41:50.520 T:180530943216   DEBUG: ADDON: Starting service addons.
19:41:50.520 T:180530943216   DEBUG: Activating window ID: 12999
19:41:50.520 T:180530943216   DEBUG: ------ Window Init (Startup.xml) ------
19:41:50.521 T:180530943216    INFO: Loading skin file: Startup.xml, load type: LOAD_EVERY_TIME
19:41:50.522 T:180530943216  NOTICE: ActiveAE DSP - starting
19:41:50.522 T:180530943216    INFO: removing tempfiles
19:41:50.524 T:180530943216   DEBUG: ADDON: Starting service addons.
19:41:50.524 T:180530943216  NOTICE: initialize done
19:41:50.524 T:180530943216  NOTICE: Running the application...
19:41:50.525 T:180530943216   DEBUG: Activating window ID: 10000
19:41:50.526 T:180530943216    INFO: GLES: Enabling VSYNC
19:41:50.526 T:180530943216    INFO: GLES: Selected vsync mode 10
19:41:50.527 T:180530943216   DEBUG: ------ Window Deinit (Startup.xml) ------
19:41:50.527 T:180530943216   DEBUG: ------ Window Init (Home.xml) ------
19:41:50.528 T:180530943216    INFO: Loading skin file: Home.xml, load type: KEEP_IN_MEMORY
19:41:50.563 T:180530943216   DEBUG: CGUIWindowHome::SetupServices() - !g_SkinInfo->IsDynamicHomeCompatible(), skin = Amber
19:41:50.564 T:180607763696   DEBUG: CHomeShelfJob::UpdateMusic() - Running HomeShelf screen update
19:41:50.564 T:180530943216   DEBUG: NetworkMessage - Starting network services
19:41:50.565 T:180530943216  NOTICE: starting zeroconf publishing
19:41:50.565 T:180608799984   DEBUG: ZeroconfEmbedded - processing...
19:41:50.565 T:180530943216  NOTICE: WebServer: Started the webserver
19:41:50.566 T:180530943216  NOTICE: starting upnp client
19:41:50.566 T:180609836272   DEBUG: ZeroconfMDNS: identifier: servers.webserver type: _http._tcp name:SHIELD port:8080
19:41:50.566 T:180609836272   DEBUG: ZeroconfMDNS: identifier: servers.jsonrpc-http type: _xbmc-jsonrpc-h._tcp name:SHIELD port:8080
19:41:50.569 T:180607763696   DEBUG: CHomeShelfJob::UpdateVideos() - Running HomeShelf screen update
19:41:50.571 T:180530943216    INFO: JSONRPC Server: Successfully initialized
19:41:50.571 T:180617090288  NOTICE: ES: Starting UDP Event server on 127.0.0.1:9777
19:41:50.571 T:180617090288  NOTICE: UDP: Listening on port 9777
19:41:50.571 T:180609836272   DEBUG: ZeroconfMDNS: identifier: servers.jsonrpc-tpc type: _xbmc-jsonrpc._tcp name:SHIELD port:9090
19:41:50.573 T:180619162864   DEBUG: CEmbyServices::Process bgn
19:41:50.576 T:180632929520   DEBUG: ZeroconfMDNS: identifier: servers.eventserver type: _xbmc-events._udp name:SHIELD port:9777
19:41:50.593 T:180633965808   DEBUG: CurlFile::Open(0x2a0e9f9148) https://mrmc.tv/feed/
19:41:50.596 T:180633965808    INFO: easy_aquire - Created session to https://mrmc.tv
19:41:51.068 T:180633965808   DEBUG: Got rss feed: https://mrmc.tv/feed/
19:41:51.069 T:180633965808   DEBUG: RSS feed encoding: UTF-8
19:41:51.070 T:180633965808   DEBUG: Parsed rss feed: https://mrmc.tv/feed/
19:41:51.323 T:180619162864    INFO: easy_aquire - Created session to http://www.msftncsi.com
19:41:51.397 T:180619162864   DEBUG: CEmbyServices::Process has gateway1
19:41:51.397 T:180619162864   DEBUG: CurlFile::Open(0x2a0dbdabb8) http://192.168.234.10:8096/emby/system/info/public
19:41:51.397 T:180619162864    INFO: easy_aquire - Created session to http://192.168.234.10
19:41:51.567 T:180608799984   DEBUG: ZeroconfMDNS: SHIELD._http._tcp.local. registration removed
19:41:51.569 T:180608799984   DEBUG: ZeroconfMDNS: SHIELD._xbmc-jsonrpc-h._tcp.local. registration removed
19:41:51.569 T:180608799984   DEBUG: ZeroconfMDNS: SHIELD._xbmc-jsonrpc._tcp.local. registration removed
19:41:51.570 T:180608799984   DEBUG: ZeroconfMDNS: SHIELD._xbmc-events._udp.local. registration removed
19:43:23.169 T:180557608176   DEBUG: CUtil::GetMatchingSource: no matching source found for [special://xbmc/system/playlists/video/]
19:43:23.172 T:180557608176   DEBUG: Previous line repeats 4 times.
19:43:23.172 T:180557608176   DEBUG: CUtil::GetMatchingSource: no matching source found for [special://xbmc/system/playlists/mixed/]
19:43:23.172 T:180557608176   DEBUG: CUtil::GetMatchingSource: no matching source found for [special://xbmc/system/playlists/music/]
aaaMMMaaa
Post by aaaMMMaaa » 31 Jul 2019, 06:55
Have the same problem.
Just upgraded from 4.1.1.0, to 4.2.0.40 and the emby integration has becomed corrupt.
Does the previous version 4.2.0.36 work?
Or which was the last version which worked?
Running MrMC 3.8.1 on Atv4K-TvOS 12.4
aaaMMMaaa
Post by aaaMMMaaa » 31 Jul 2019, 07:59
4.2.0.36 also does not work.
I found out also this version is a beta.
Now testing 4.3.0.0
aaaMMMaaa
Post by aaaMMMaaa » 31 Jul 2019, 09:14
Emby Server 4.3.0.0 beta also not working.
100% a problem with newest MrMC 3.8.1
Please fix for MrMC 3.9.1 release
Post by amet » 31 Jul 2019, 09:31
It has been fixed on 3.9.0, you can accept beta test on google play and test/use that until 3.9.0 pops out.
aaaMMMaaa
Post by aaaMMMaaa » 31 Jul 2019, 09:57
Oh thank you.
What about TvOS?
