Not applicable
Montoya
Not applicable
Post by Montoya » 06 May 2019, 23:59
Never mind
Re: Emby server 4.2.0.4 beta breaks MrMC access
Post by amet » 07 May 2019, 08:54
4.2.0.4 doesn't work and 4.2.0.1 works, and somehow we broke it? :)
Montoya
delete
Post by Montoya » 07 May 2019, 09:12
delete
Montoya
delete
Post by Montoya » 22 May 2019, 09:24
delete
Post by amet » 22 May 2019, 11:03
I honestly don't know how to play that game, if they didnt break anything between .1 and .4 then all should work fine. :)
what error are you seeing? manual sign-in works fine here using http
Montoya
delete
Post by Montoya » 22 May 2019, 11:47
delete
Post by amet » 22 May 2019, 11:56
comment is not about your games, I never assumed you played any games :)
its about emby api games... anyway "emby/system/info/public" stopped reporting "OperatingSystem" in manual sign in, still reports it in pin sign in... go figure.
"fix" is in and will be available in next TF/Beta/release
Montoya
Re: Not applicable
Post by Montoya » 22 May 2019, 12:04
Thanks, cooling down now ;-)
