Emby Manual sign-in is broken with latest Emby Server 4.0.0.0 beta.
Pin request sign-in only works now. Did a back check with previous Emby beta 3.6.0.84 and manual sign-in works in this version.
Could you guys take a look at this, because Emby Server 4.0.0.0 is about to go out of beta in the next couple of days, so all MrMC users who are on Emby stable release channel, will be affected (who are using manual sign-in for the Emby Client service in MrMC).
Latest API changes in Emby: https://emby.media/community/index.php? ... g-changes/
New Emby Server 4.0.0.0 breaks MrMC Client access Topic is solved
- Montoya
Re: New Emby Server 4.0.0.0 breaks MrMC Client access
ok, thanks for the heads up.Montoya wrote: 10 Jan 2019, 23:21 Emby Manual sign-in is broken with latest Emby Server 4.0.0.0 beta.
- Montoya
To add to that:
Emby Pin request sign-in does NOT work in MrMC on my iOS devices (on tvOS pin request sign-in does work), so Emby access is completely broken in MrMC on iOS devices
installed 4.0.0.1 on my qnap
manual sign in works from iOS
pin sign in works from iOS
manual sign in works from tvOS
pin sign in works from tvOS
server:
Secure connection mode:
Preferred, but not required
server:
- Montoya
Hmm, I think I found the reason In Emby server 4.0.x branch why MrMC refuses manual sign-in...
Something must be changed in 4.0.x branch when external access is set to "No access" in Emby server, which now prevents MrMC to let the Emby Client service to log in manually.
My Emby Server is always set to "No external access" (only when needed) and when I allow external access in Emby server, manual sign-in from MrMC works (only tested iOS, so I assume tvOS also works).
I hope this info rings some bells @Amet
Allow remote connections to this Emby Server.
If unticked, all remote connections will be blocked.- Montoya
Yes, with remote access disabled, LAN access previously in pre Emby 4.0.x branch, MrMC Emby access was always possible with manual sign-inamet wrote: 14 Jan 2019, 17:17that one?Code: Select all
Allow remote connections to this Emby Server. If unticked, all remote connections will be blocked.
not sure what to tell you, still works here
4.0.0.1 server, iOS , tvOS and OSX... all good
- Montoya
Than your fresh Emby install will have solved itamet wrote: 14 Jan 2019, 17:22 not sure what to tell you, still works here
We had this problem previously in the Emby tvOS app long long time ago, so I'm afraid existing Emby users with no fresh install may experience the same now.
Will test now what the solution was to the Emby tvOS app not connecting to local Emby server problem:
https://emby.media/community/index.php? ... ntry557151
just to be clear, I upgraded my server from 3.8.*(I think) to 4.0.0.1
