LiveTV not working on Mibox and Shield
bighick
Post by bighick » 29 Nov 2018, 02:41
I can't get liveTV to work on my mibox or shield. I have tried the latest stable release and updated to the beta. They worked previously but haven't used either in a while. It is working fine on my AppleTV running MrMC and Raspberry Pi running Libreelec.
Here is the log https://pastebin.com/DigzNQLV
Firgured I would post the old log too. https://pastebin.com/rJaT2pZe
Quick edit: They will both show "NextPVR PVR Client Tuner no longer available"
bighick
Re: LiveTV not working on Mibox and Shield
Post by bighick » 30 Nov 2018, 16:22
So if i disable timeshifting it works. According to NextPVR this is a Plugin issue. Does MrMC use the same plugin that Kodi does? Trying to figure out where to go so the developer can look into it as the issue/fix is the same on kodi & mrmc.
Post by davilla » 30 Nov 2018, 18:52
bighick wrote:
30 Nov 2018, 16:22
same pluging but https://github.com/MrMC/pvr.nextpvr/tre ... r_api3.0.0
