Fire tv audio output transcoding
Dave_O
Post by Dave_O » 08 Aug 2019, 02:14
I’m testing a Sonos Playbar driven by optical out from a Samsung TV. The playbar does not support DTS. I’ve found that DTS movies will play if I enable Passthrough and deselect audio capabilities above Dolby digital.
Am I correct that MRMC is transcoding DTS to Dolby Digital? Is this a supported feature, and are there any issues you see?
Dave
Re: Fire tv audio output transcoding
Post by koying » 08 Aug 2019, 15:21
"Enable Dolby Digital (AC3) transcoding" is the (obviously supported) setting that does the magic.
Dave_O
Post by Dave_O » 08 Aug 2019, 16:48
I never needed this before, but I do now, thanks.
In MRMC, I don't see the ""Enable Dolby Digital (AC3) transcoding" option that I do in Kodi.
Post by davilla » 09 Aug 2019, 00:30
Dave_O wrote:
08 Aug 2019, 16:48
set channels to 2.
Dave_O
Post by Dave_O » 09 Aug 2019, 03:24
Thanks. Does it matter if IEC packed is checked. I get sound from DTS movies either way.
