Poor picture quality 720p
RoosterX
Post by RoosterX » 10 Mar 2019, 17:42
So first my HW, having a brand new Sony 65XF9005(US - x900f) setup with an old Shield TV I had lying around since this TV's Android TV is so sluggish I prefer the Shield TV.
Have set up that MRMC changes Hz and also resolution to match whatever the video source is, unfortuately I can't get it to just change Hz without also changing resolution(let the TV do the upscale) most material works very well, especially 1080p/4k incl. HDR, really!! satisfied with the quality. But as always with technology there is a big but.. If i start a tv show or something in 720P the picture quality is so bad, it's just plain terrible, looks like it's heavily oversharpened(edge?!).
So my question is, is this the fault of the TV, since it is supposed to actually do the upscale, or is it some setting in MRMC in which I simply can't find nor figure out?
Is there a way to disable resolution change for some material, like let the Shield TV/MRMC do the upscale on all content 720p and less?
Re: Poor picture quality 720p
Post by koying » 11 Mar 2019, 05:32
Does resolution change to 720p?
What's the quality if you disable "also change resolution"?
RoosterX
Post by RoosterX » 11 Mar 2019, 07:26
Yes the resolution do change to 720p, but I am starting to think this is all down to my TV sharpening etc with same settings applied like it do when using higher quality material(1080p, 4k etc), was tinkering around with the TV settings and it got much better, wouldn't say perfect though, but had to change it back, so the settings is correct for all the other resolutions that I play. So unless there is a way to make exception for changing resolution on only 1080p, and let Shield TV upscale lower resolutions, OR if I could just change framerate without changing resolution?!
I'm guessing it's like everything else, always a compromise. To be fair the PQ in my opinion when I let the Shield TV do the upscale is pretty decent.
