libtool error when building
Development talk only
bikeseat
Post by bikeseat » 17 Feb 2019, 09:55
Building mrmc for tvos on macos 10.13.6.
When making after running these commands:
cd $HOME
git clone git://github.com/mrmc/mrmc.git MrMC
cd $HOME/MrMC
cd tools/depends
./bootstrap
./configure --host=arm-apple-darwin --with-cpu=arm64 --with-platform=tvos
make
I would get the same error from libtool regarding a version mismatch. This must have happened nearly a dozen times.
Couldn't figure out how to properly handle it, so at every instance, I commented out the function call for "func_check_version_match" in the libtool file in the build directory, for example: "libflac/appletvos12.1_arm64-target/libtool"
I did try autoreconf and similar to no avail, but even if that worked, I would have had to run it each time after the libtool version mismatch error caused making to die.
What is the proper way to handle this? Is there a problem with the build scripts?
Snipped for brevity:
config.status: executing libtool commands
/Applications/Xcode.app/Contents/Developer/usr/bin/make -j 1 -C appletvos12.1_arm64-target/src
/bin/sh ../libtool --tag=CXX   --mode=compile /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang++ -DHAVE_CONFIG_H -I. -I.. -I../include  -fheinous-gnu-extensions -no-cpp-precomp -fembed-bitcode -ftree-vectorize -pipe -Wno-trigraphs -fpascal-strings -O3 -Wreturn-type -Wunused-variable -fmessage-length=0 -gdwarf-2 -Wno-error=implicit-function-declaration -arch arm64 -mappletvos-version-min=10.2  -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/AppleTVOS.platform/Developer/SDKs/AppleTVOS12.1.sdk -isystem /Users/Shared/mrmc-depends/appletvos12.1_arm64-target/include   -DTIXML_USE_STL -no-cpp-precomp -fembed-bitcode  -arch arm64 -mappletvos-version-min=10.2 -std=c++11 -stdlib=libc++ -g -O2 -std=c++11 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/AppleTVOS.platform/Developer/SDKs/AppleTVOS12.1.sdk -isystem /Users/Shared/mrmc-depends/appletvos12.1_arm64-target/include  -MT tinystr.lo -MD -MP -MF .deps/tinystr.Tpo -c -o tinystr.lo tinystr.cpp
libtool: Version mismatch error.  This is libtool 2.4.6, revision 2.4.6,
libtool: but the definition of this LT_INIT comes from revision .
libtool: You should recreate aclocal.m4 with macros from revision 2.4.6
libtool: of libtool 2.4.6 and run autoconf again.
make[3]: *** [tinystr.lo] Error 63
make[2]: *** [appletvos12.1_arm64-target/src/.libs/libtinyxml.a] Error 2
make[1]: *** [tinyxml] Error 2
make: *** [target/.installed-appletvos12.1_arm64-target] Error 2
~/mrmc/tools/depends ❯
Re: libtool error when building
Post by davilla » 17 Feb 2019, 15:22
which Xcode version ?
bikeseat
Post by bikeseat » 19 Feb 2019, 04:29
Version 10.1 (10B61)
Post by davilla » 19 Feb 2019, 16:22
This is my build of libflac after make distclean in that dir
https://pastebin.com/YuTjZjcn
Same xcode/osx version as you.
