Can’t Add IPTV M3U Link on Apple TV 4 Please Help
Introduce yourself here
jonnisbett
Post by jonnisbett » 10 Aug 2019, 20:46
Hello I have downloaded the mrmc app on Apple TV 4 and on my iPhone and I’m trying to setup my iptv on it.
I have added the pvr simple client and added my m3u list it says it’s added all the channels but then says 0% pvr manager is starting up, loading channels from client. Nothing happens. Please any help much appreciated. I’m using the lite version do I need to use paid to make it work? The screenshot I provided is on my iPhone but I get same thing on Apple TV.
Re: Can’t Add IPTV M3U Link on Apple TV 4 Please Help
Post by amet » 11 Aug 2019, 06:34
You don’t need the full version for it to work.
Please make sure that the url is working correctly and avoid copy/pasting it as that was the issue in past on Apple TV when using iPhone to enter the text.
jonnisbett
Post by jonnisbett » 12 Aug 2019, 03:58
Thank you for finally replying. I have entered in manually at least 10 times. It does load all the channels but then remains at 0%?
jonnisbett
Post by jonnisbett » 12 Aug 2019, 03:59
I would also like to add my Plex account once I figure this out and would be more then happy to pay for the app and contribute but I need to see the iptv work first.
Post by amet » 12 Aug 2019, 07:03
I know it works as I use it daily, we need to figure out why it doesn’t work for you :)
Once 3.9.0 is out there will be a way to pull debuglog out from lite versions.
jonnisbett
Post by jonnisbett » 12 Aug 2019, 15:24
Is it possible that it’s my channel amount? My m3u URL playlist has 31,000 channels in it?
jonnisbett
Post by jonnisbett » 12 Aug 2019, 23:20
Could you kindly verify this is the only process to install IPTV,
Open the MrMC media center
Go to settings
Select TV
Select generall and click on Activated
Click OK when the “No PVR Add-On” dialog box appears
Scroll down and select PVR IPTV Simple Client
Select Configure
Under General select Location: Remote Access (Internet Address)
Fill in the link you received for your subscription in URL to M3U playlist
Unmark Buffer m3u on local space
Click OK
Click Activate
Start on MrMC / Apple TV
Start the MrMC media center and wait until all channels are loaded
Done! You can find all channels under TV in the menu of MrMC
I’m assuming I don’t have to have kodi running anywhere or have my iPhone or Apple TV jail broken?
This is driving me nuts lol. I even tried on Firestick same result will load all channels but then 0% waiting for client.
Post by amet » 12 Aug 2019, 23:43
I would go to media sources -> pvr clients -> simple Iptv - > settings -> add url and hit OK -> back out to home and TV section should be there
That’s how it works for me... 3.8.1 lite version has a limitation on webui which is needed to get the debuglog unfortunately. Without debuglog it’s difficult to say what’s wrong with it :(
Post by amet » 12 Aug 2019, 23:44
jonnisbett wrote:
12 Aug 2019, 15:24
It’s possible, I have 2-3000 max and no issues there... 31k is a bit excessive :)
jonnisbett
Post by jonnisbett » 13 Aug 2019, 18:29
My iptv provider has everything all in one m3u. It loads everything live tv channels, movies and TV Series. Not sure if there is an easy way to break it down to just my favourites and try? Or maybe I could try finding a smaller m3u link and try. When do you anticipate release of newer version with debugging?
Thanks for all the help so far!
