This is germany calling!
Introduce yourself here
Kerbel
Post by Kerbel » 12 Mar 2019, 14:32
Hi everybody,
I'm the new one. :mrgreen:
I'm using MrMC on my Atv4 since Dec 2016, Version 2.8-1.
Is it possible to update to Version 3.8.0 or do i have to buy it new?
Thanks for your help
Kerbel
Und an alle Deutschen hier - Guude!
Re: This is germany calling!
Post by davilla » 12 Mar 2019, 15:40
Kerbel wrote:
12 Mar 2019, 14:32
Hi everybody,
Kerbel
should be present as an update on your AppleTV4. maybe you have updates turned off.
Kerbel
Post by Kerbel » 12 Mar 2019, 18:45
Auto-update is on. I checked the installed apps at the app store - MrMC isn't shown.
If i try to buy the latest version, there is only the open button. :?
Post by davilla » 12 Mar 2019, 21:47
Kerbel wrote:
12 Mar 2019, 18:45
maybe already updated ? check version in MrMC
Post by amet » 13 Mar 2019, 03:53
Is Apple TV using the same Apple ID as in 2016?
Kerbel
Post by Kerbel » 13 Mar 2019, 13:49
Hi, Apple ID is the same, version in MrMC is 2.8-1.
Post by amet » 13 Mar 2019, 14:28
have you tried removing it and downloading again? Note that doing that would remove your internal MrMC database and settings
Kerbel
Post by Kerbel » 13 Mar 2019, 15:42
I removed MrMC and now i have do buy it new! :evil:
Post by cosmoxl » 13 Mar 2019, 16:28
Kerbel wrote:
13 Mar 2019, 15:42
There's got to be a screwup with apple id or maybe app store region?
Montoya
Post by Montoya » 13 Mar 2019, 16:37
Kerbel wrote:
13 Mar 2019, 15:42
Apple sends receipts of all your Store purchases to your email used with your Apple id.
Find that receipt and contact Apple, so they can investigate and fix your issue.
Apple TV 4K 64GB tvOS 12.3 - Win10 Pro x64 1903 build 18362.116
DVBLink server 6.0.0 build14499 - TVMosaic server build 17550 - Emby server build 4.2.0.1 beta
